Sway Bar End Links
Old Nov 23, 2013 | 04:58 PM
cookie7's Avatar
cookie7
Default Sway Bar End Links
Is there any trick to replacing the swaybar links?;Mine are popping like hell and the boot is torn on one. Removing the weight off the suspension or just un-bolting? ;Never did this before and would like to keep all my teeth and fingers until the holidays are over.Thanks in advance
Old Nov 23, 2013 | 06:13 PM
LoneStarFRC's Avatar
LoneStarFRC
No special trick. Very straightforward. The anti-roll bars do not support the weight of the vehicle in the at-rest position. I would suggest making sure the car is level when swapping. If you can reach them OK with the car on the ground you'll be OK, or you can back partway up some ramps and chock the front wheels too for a little more clearance.
HTH
Old Nov 23, 2013 | 06:24 PM
Zorlac's Avatar
Zorlac
Here's a thread with a link to a guy that upgraded his bars & links with pics and torque specs. Maybe it'll be beneficial.
https://www.corvetteforum.com/c5-tec...end-links.html
To Sway Bar End Links
