How to Replace Traction Control Button Bulb?
Old Nov 27, 2013 | 08:43 AM
LIGHTNING's Avatar
LIGHTNING
Default How to Replace Traction Control Button Bulb?
I'm replacing stock interior lights with LED's.
Not sure how to get to the Active Handling/Traction Control button light bulb. Also, for the Trunk Release button...just pop the cover for that bulb? Thanks.
Old Nov 27, 2013 | 12:52 PM
jamieo's Avatar
jamieo
The complete traction control console just pops off.Raise the center console door and just lift up on the rear of the switch plate and it will come right off.The trunk release switch will pop off easily also.When I did my LEDs I actually put the light in the rubber base of the traction control switch.Didn't illuminate very well with the lights in the stock position.Forum member Tstar has a great mod thread on the LED conversions with ALOT of usefull info and tips!
Old Nov 27, 2013 | 07:45 PM
LIGHTNING's Avatar
LIGHTNING
Thanks! I'll check it out.
Where exactly is the stock position of the light you're referring to? It can be moved?
Old Nov 27, 2013 | 11:16 PM
jamieo's Avatar
jamieo
It will be obvious once you remove the switch console.
To How to Replace Traction Control Button Bulb?
