what HP will i get on dyno?
Old Nov 27, 2013 | 01:06 PM
Kreeess's Avatar
Kreeess
Default what HP will i get on dyno?
im scheduled for a dyno tune for my 98coupe today wondering what you folks think I would get my mods are the following.
stock ls6 intake
K&N filter with aftermarket bridge
ls2 MAF
stock ls6 heads
228ish cam with 114lsa
160thermo (don't know if this makes a difference lol )
LG superpro LT headers
Corsa Extreme
I will post dyno numbers after I get it done but for the meantime what do you guys think the kind of numbers I will pull?
Old Nov 27, 2013 | 01:15 PM
Bluefire's Avatar
Bluefire
stock ls6 intake
ls2 MAF
stock ls6 heads
Corsa Extreme
My guess is 410 - 420 rwhp.
Old Nov 27, 2013 | 01:17 PM
Kreeess's Avatar
Kreeess
sounds good! hoping to get closer to that 420 number but we shall see!
Old Nov 27, 2013 | 06:30 PM
NukeC5's Avatar
NukeC5
Its an auto I take it? 410 is a good guess. What kind of dyno?
Old Nov 27, 2013 | 09:26 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Don't want to pop your bubble, I guess 380ish.
Old Nov 27, 2013 | 09:34 PM
Blow Torch's Avatar
Blow Torch
A4 - 395-405
m6 - 420-430
Old Nov 27, 2013 | 09:49 PM
Last C5's Avatar
Last C5
385 + - . Heads will increase that by 40 at least.
Old Nov 27, 2013 | 10:13 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Old Nov 27, 2013 | 10:58 PM
Supercharged111's Avatar
Supercharged111
He'd do 380 without the cam, my initial guess was 420 and I'm sticking to it.
Old Nov 28, 2013 | 05:04 AM
MY1STPEWTER
The reason for my guess. When my car was a six speed (before auto conversion) I had Ghl Bullets, LG Pro Longtubes, 282/232 110LSA and made 386/382. After Vengeance Racing installed Trickflow 220 as cast heads and underdrive pulley I went to 430/418.
Unless he has a factory freak I see NO WAY to hit 420 with what he
has listed. Especially if his is an auto. This is JMHO. I wish him the best of luck reaching his number. Of course we all know how much dyno's can be different.
Old Nov 28, 2013 | 07:40 AM
baxsom's Avatar
baxsom
my setup on my 00
vararam
ported FAST 78
228R cam
underdrive pulley
TSP headers
PRC 5.3 heads milled to give 11:1 compression
MN6
on a mustang dyno came in at 440rwhp
Old Nov 28, 2013 | 07:41 AM
Blow Torch's Avatar
Blow Torch
That's Z06 territory.
Old Nov 28, 2013 | 09:32 AM
Supercharged111
Well he does have Z06 heads and intake, so basically a Z06 engine. The 228R seems to make around 420 from the searching I've done and is a popular cam, hence my guess.
Old Nov 28, 2013 | 03:58 PM
Bluefire's Avatar
Bluefire
completely. My build is very similar. Started with a stock '03 LS1 w/LS6 intake. I added:
stock 243 heads
224R/230R .581/.588 113 LSA
AR Headers
Vararam intake
ATI 10% UD Pulley
Made 420rwhp 392rwtq on a Mustang dyno.
Old Nov 28, 2013 | 04:26 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Old Nov 28, 2013 | 04:52 PM
Kreeess's Avatar
Kreeess
Here are my results on 91 winter blend STD 412/402 SAE 396/386
Cold start and first run
Second pull
All and all I'm very happy with my result considering it's a 98 with the 3pin MAF ... Next on mod list is AI or WCC ported 243 with a MAF swap ...
Old Nov 28, 2013 | 05:07 PM
bob22z06's Avatar
bob22z06
Car sounds great ...good run!!
To what HP will i get on dyno?
Old Nov 28, 2013 | 05:28 PM
Kreeess's Avatar
Kreeess
Thanks! For a 98 with 95k miles I must say it's not too shabby at all!! Def need head work for next mod!
Old Nov 28, 2013 | 07:57 PM
Mattie Num Nums's Avatar
Mattie Num Nums
My 99 needed valves like crazy.
Old Nov 28, 2013 | 09:49 PM
Supercharged111
Sweet. 412 Is close enough to 420 for me to consider myself correct.
