where does this plug go?
Old Nov 29, 2013 | 07:40 PM
corvette8189's Avatar
corvette8189
Default where does this plug go?
thanks
Edit- blue plug is for temp sensor on mn12 trans mn6 doesn't have it on u.s. Cars
corvette8189
its blue plug with orange and yellow wires
Old Nov 29, 2013 | 07:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Skip shift solenoid plug?
Old Nov 29, 2013 | 08:07 PM
corvette8189
i have all 3 sensors on trans plugged in
Old Nov 29, 2013 | 08:13 PM
LoneStarFRC
Hmm, FSM shows Org/Blk and Yel/Blk wires going to Trans Temp Sensor, but you say it's plugged in too?
Old Nov 29, 2013 | 08:51 PM
corvette8189
white goes to skip shift idk where blue goes its connected together
Old Nov 29, 2013 | 08:59 PM
69's Avatar
69
Cruise-In VI Veteran
Just checked your profile, is this a ZO6? if so, you should have 4 plugs on the Trans/Diff
(1) Reverse Inhibit Solenoid
(2) Skip Shift Solenoid
(3) Vehicle Speed Sensor (VSS)
(4) Tran Temp Sensor
Old Nov 29, 2013 | 09:11 PM
corvette8189
Yes it it but the trans is a mn6 so will there be one not plugged in
Old Nov 29, 2013 | 09:12 PM
corvette8189
I have the diff plugged in the 3 on trans one on top 1 left and 1 right side
Old Nov 29, 2013 | 09:32 PM
LoneStarFRC
Z06 trans is an M12, not MN6, and should have 4 plugs:
1. Skip shift
2. Backup lights
3. Reverse lockout
4. Trans temp
Is that the original transmission in the car?
Old Nov 29, 2013 | 09:54 PM
69's Avatar
69
Temp Probe location on Z06 and Export C5's
Old Nov 29, 2013 | 10:00 PM
LoneStarFRC
That's why I'm thinking it's not the original transmission, as the fill-port does not have the temp sensor installed. It has the regular fill-port plug like the non-Z06 cars.
You can see it in his picture here:
Old Nov 29, 2013 | 10:03 PM
corvette8189
No it's not the original trans. So the mn6 doesn't have the temp sensors?
Old Nov 29, 2013 | 10:11 PM
69's Avatar
69
The MN6 Trans will only have the Temp sensor installed on Export C5's only. As you have the Z06 with the wiring for this Temp Sensor, you may want to consider installing this Temp Sensor...
Goose
Old Nov 29, 2013 | 10:18 PM
LoneStarFRC
No. Not the U.S. units. Only export cars.
In the U.S., M12s all have it as that's the Z06 transmission. The gear ratios 1 thru 4 are different than the MN6 trans also.
Buy a sensor, screw it in and plug up your connector. Btw, the sensor does not give you actual temps readings. It only causes a "Trans Overtemp" warning to display on your DIC if the trans overheats.
HTH
Item # 5:
GM part number 12451818. The ACDelco part number is the same.
Old Nov 29, 2013 | 10:32 PM
corvette8189
Cool thanks guys
To where does this plug go?
