supercharger question
My V2 is set for a maximum of 7psi boost. The boost can be changed with different hubs diameters.
Make sure you add both a boost/vacuum gauge and a fuel pressure gauge. Mine are mounted on a gauge pod on the windshield pillar.
I would recommend having a blower kit installed professionally especially if you don't have a lot of hands-on experience. For example, my Vortec system requires relocation of the alternator to the right side, drilling holes in the oil pan for a return line, extended power steering hoses and some relocation of the brake lines from the MC to the ABS unit. This system also includes a water-cooled intercooler. The install instruction booklet is 36 pages!
Also, consider any other components you want to add and do them first. Things like headers and free-flow exhaust can impact the configuration of a custom tune.
Having said all that, my '02 dyno'd at 450 RWHP, 410 ft-lbs torque and still delivers 30 MPG in 6th gear at 70MPH!
once you pick out a kit then you will be able to get a better answer then "Maybe"
"TINBIRD02"
The Vortec A&A kits fit under stock hood, the Magnuson "Maggie" Charger does require a different hood.
S
