C5 Z06 Fog Lights Installation
Old Dec 3, 2013 | 02:09 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default C5 Z06 Fog Lights Installation
First I'd like to say thank you to Mark/Toque, and FourG63 97GST.
Mark's Fog Light DIY
Ordered regular C5 fog lights, and 6000K HID bulbs, hardware, and C5 coupe
trunk/fog switch.
As I mentioned before, I'm a 3-time C4 owner, but noticed the C5 doesn't have
a headlight motor **** for it to be raised or dropped manually. I removed the dust
boot, and found it has the same mechanism, but it uses an allen bit. This made it easier, and
save the back and forward trip to the cockpit.
Remove the 4-torque bolts, and 3-philip screws per headlight.
Removed two-10mm nuts from the fuse box
Realized it was easier to work that out by removing the battery.
The box came out quite easier by removing the battery, and loosing up the fuse box's
bottom plastic box.
The infamous purple wire.
This was too easy, so damn easy that I triple check it Remove the Z06 trunk release
switch using a plastic pry bar
Install the C5 Coupe trunk/fog light switch
IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRXZ06/Fog%20Lights%20Z06/Z06Fog11.jpg[/IMG]
I could not find a T-10 long screwdriver or bit long enough to reach the adjuster bolt.
I bought two flat bolts
Speednuts, and bolts
It works perfect
I tested it, and it works perfect for it's ground.
First look
Both forum members assured me that by splicing the purple wire, and connecting a
wire to both ballast would be no problem I took another route. I installed a HD relay for headlights. Created positive+ wiring connection from
the B+ wiring for the relay connection.
It was a good thing to remove the battery. The old battery was leaking, and the
positive terminal was totally corroded. Both terminal were cleaned up, and coated them
with dielectric grease.
Lights on!
Fogs
Fogs and low beam
High Beams
Working on the C5Z was easier than working on a C4. This is the first time I haven't get my arms cut or bled at all.
Old Dec 3, 2013 | 02:49 AM
MonolithMonolith's Avatar
MonolithMonolith
I was talking to my buddy about doing this yesterday. What'd it cost you out the door?
Old Dec 3, 2013 | 05:55 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Nicely done ! ! !
Glad it worked out for you !
I have a spare pair of C5 Fog lamps (with 6000K HID's in them)..... if anyone needs a set.
Toque
Old Dec 3, 2013 | 08:08 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Fog Light Switch:-----$ 38
Fog Lights:-----------$139
HID:------------------$ 31
Hardware:----------+/-$ 30
Old Dec 4, 2013 | 12:07 AM
MonolithMonolith
That's a hell of a lot better from some of the plug and play kits I've seen. Thanks.
Old Dec 5, 2013 | 09:02 AM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
Very nice how-to! Looks great and thanks for taking the time to take pics and share
Old Dec 5, 2013 | 05:07 PM
TXGS507's Avatar
TXGS507
Mark is cool like that... Had a mod party at my house once... He helped me do mine too...
Old Dec 5, 2013 | 10:15 PM
sami85L98's Avatar
sami85L98
I have collected Fog light complete setup and as well collected info how to install them but your thread will greatly help me even more so. Looks great man and good write up.
Old Dec 5, 2013 | 10:46 PM
JETninja's Avatar
JETninja
WA Events Coordinator
Toque
What do you want for them? I'd love to put a set on my Z....and since moving up here I have lots of winter time to do mods. Ha Ha...
Nice write up OP!
Old Dec 6, 2013 | 12:06 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
http://forums.corvetteforum.com/c5-z...-in-a-z06.html
Old Dec 6, 2013 | 05:15 PM
Toque's Avatar
Toque
Nice write up OP!
Sending a PM
Toque
Old Dec 6, 2013 | 07:09 PM
momo20's Avatar
momo20
where did you get those fog lights they look brand new..the ones I keep finding are OEM and are all well aged
Old Dec 6, 2013 | 07:23 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Found them on ebay.
Old Dec 6, 2013 | 11:56 PM
Z06Brucey's Avatar
Z06Brucey
Very nice install man!
Old Dec 8, 2013 | 03:10 PM
FourG63 97GST's Avatar
FourG63 97GST
nice work, turned out great
Old Dec 22, 2013 | 05:35 PM
JoeJ's Avatar
JoeJ
PRLX/Torque - Thanks for the detailed write ups. I tacked this project yesterday with great success. I picked up all the parts, including the complete OEM wiring harness from a salvage yard for just over $200. With the OEM harness I was able to separate all the weather-tite plugs and terminate the connections without cutting or splicing a single wire, and that made me very happy. There are actually two open positions in the terminal block which connect to the fog light relay, you do not have to splice into the purple wire, all you need is the factory harness or the GM terminal ends. With it done this way it is very hard to tell it's not a factory install.
Old Dec 22, 2013 | 05:59 PM
PLRX's Avatar
PLRX
2017 C4 of Year
To C5 Z06 Fog Lights Installation
Old Dec 25, 2013 | 03:59 AM
AngelDeath's Avatar
AngelDeath
Greets Guys,
Just joined the forums, but have been reading alot over the last 6 months since finally becoming a corvette owner after 25 years of waiting.
I wanted to thank PLRX for the write up & pics, it helped my installation of stock fogs into my C5 (not a Z06) but I took a different approach for the wiring since they weren't HIDs.
But now seeing that I upgraded the bulbs to 885 (50w) and they still for a lack of a better word suck, I wanted to switch them to HID's. But my question is I see Toque's write up and yours for the 6000K, but what watt ballast did you guys go with? 35 or 55? I was looking at the 55w but I was unsure if this would be too much for the fog light housing as far as heat.
I have read some say its fine, other say you shouldn't, but I'd like a clear answer, personally, I'd like to go with the 55w ballast opposed to the 35w.
Thanks for the Response and Merry Christmas
Old Dec 25, 2013 | 11:36 AM
PLRX's Avatar
PLRX
2017 C4 of Year
Mine were ordered as 55W.
Old Dec 25, 2013 | 01:56 PM
Toque's Avatar
Toque
Originally Posted by AngelDeath
Greets Guys,
What I'm hearing is that 35W is best for the stock C5 GM plastic fog light HID housing. I heard some say that 55 is a little hot for the plastic housing. Just what I heard.... no experience....
I lucked into a set of the C5 GM Euro metal fog light HID housings. I may go with a 55w in them one day. Thats why I got the GM Euro Fogs.
Toque
Here are my 35W on a wall in my garage.
