Connectors above the BCM
Old Dec 4, 2013 | 08:05 PM
robberyc5's Avatar
robberyc5
Default Connectors above the BCM
I was looking at the fuse box on the passenger side floor board because I have the Blinking AC light and it is not blowing cold air. I read some posts about pulling some fuses. While doing that I noticed that there are two connectors above the BCM. One of mine is not connected. The connector with 2 orange, 1 purple, 1 white, and 1 green. Does anyone know what that connector is for?
Old Dec 4, 2013 | 09:03 PM
robberyc5's Avatar
robberyc5
Yes I have the LMC5 but I did not install it. I still get the Pull Key for 10 Second message.
Old Dec 4, 2013 | 11:16 PM
Chicago1's Avatar
Chicago1
On the a/c note. Mine did the same thing had low refrigerant come to find out I had a hole in the rubber a/c line that was by the header. You need to refill. You can have it checked at most places for free and diy.
To Connectors above the BCM
