How to remove an entire door ??
Old Dec 6, 2013 | 11:07 AM
brrgrr951's Avatar
brrgrr951
Default How to remove an entire door ??
I need to replace the actual door shell on the drivers side. I have a painted replacement shell, so I just need so swap all the door "hardware" over to the new shell. First question, are there any tricks or watch- outs when removing the door from the car ? I'm assuming it's fairly heavy "fully dressed" - so it will be a two person job while I unbolt the brackets - and then I'm assuming there is a plug for the wiring....... I'm using the word Assuming a lot here....... that has me concerned. Any help is appreciated!
Old Dec 6, 2013 | 02:15 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
check out dream car customs video on you tube. it will help, i know your not doing the kit but it gives you the basics. hope this helps
Old Dec 6, 2013 | 03:30 PM
brrgrr951's Avatar
brrgrr951
Great - that actually helps quite a bit. Thanks !
To How to remove an entire door ??
