Phantom battery draw
Old Dec 14, 2013 | 03:26 PM
Lstawick's Avatar
Lstawick
8th Gear
Default Phantom battery draw
There are similar posts regarding this issue but might goes a bit further. I have a 99 model 6 spd. Owned for over 3 years. Recently the battery started going dead when idle for 3 or more days. Had local mechanic look at it (very experienced). Connected amp meter and routinely disconnected each fuse one by one. Could not get the draw below .13 amps. Also checked alternator and checked out ok. Any other thoughts or ideas on where my battery power is going? I'm using a trickle charger now whenever it is parked but that is getting to be a pain since it is my everyday car, although it does frequently sit for 3-5 days without being driven. Any thoughts or ideas would be appreciated.
Larry
Old Dec 14, 2013 | 03:28 PM
VinnyT's Avatar
VinnyT
Larry
I have heard the power seat motors would run and cause a drain. I would try unplugging it and seeing if the drain still occurs.
Old Apr 9, 2014 | 12:04 PM
adamgl's Avatar
adamgl
Ever figure it out? I have the same thing I'm trying to fix.
Old Apr 9, 2014 | 12:09 PM
c4gone's Avatar
c4gone
same thing on my 99. red top is great and checks perfect but if it sits for a couple days then its dead. I personally think its my connections because the second I hook up the cables to my truck it cranks right away. I just haven't had a chance to check because I work a lot. but if that isn't it then im in the same boat as you. keep us updated
Old Apr 9, 2014 | 12:30 PM
Lstawick's Avatar
Lstawick
8th Gear
Nope. I've resigned to the daily connection to a trickle charger.
Old Apr 9, 2014 | 02:05 PM
adamgl's Avatar
adamgl
I'll let ya know If I get mine figured out. Might get lucky and be the same thing. My LS1 camaro could sit for months and start right up.
Old Apr 10, 2014 | 12:25 AM
Bubbletop409's Avatar
Bubbletop409
Had a similar situation in my 99 GMC dually. Turned out one of the hinges on the courtesy mirror in my sun visor was broke and not completely turning off the light when the cover was closed.
Found it by accident while cleaning the interior and could feel how warm the cover was, a rubber band around the cover solved the problem.
Old Apr 10, 2014 | 08:04 AM
Biotex's Avatar
Biotex
Where is the headlight control module located? I'd like to see if this is what's causing my drain.
Old Apr 10, 2014 | 09:30 AM
Smoken1's Avatar
Smoken1
The module is located under the right headlamp from what I have read. Here is a post about it.
http://forums.corvetteforum.com/c5-t...e-bad-why.html
Old Apr 10, 2014 | 11:41 AM
dadaroo's Avatar
dadaroo
Here is a simple way to try and see if the drain is via the engine or the I/P fuse box circuits.
At the right side rear of the engine fuse box is a stud. This is where power from the battery goes to the engine fuse box. Also on the stud is the power feed to the I/P fuse box. Both are large RED wires.
Disconnect the I/P power feed and see if that eliminates the drain. If it does then your issue in in that circuit. If not then the problem is in the engine fuse box circuits. Could be there is some drain from each but not as likely. If you disconnect the I/P box feed and the drain only goes down some, then you have a drain going on in both circuits.
Old Apr 10, 2014 | 01:19 PM
Biotex's Avatar
Biotex
Good to know. Thanks for the tip. Sounds like an easy way to divide the problem in half, and shorten the diagnostic time. Am I correct in assuming I could put my amp meter in series with the two different cables and thus measure the current drain on either or both?
Old Apr 10, 2014 | 01:20 PM
Biotex's Avatar
Biotex
Thanks for the answer. I had read that post you linked to just before i asked the location. I didn't see anywhere in it that pointed to it's hiding place. There were clues though...
I just loaded AllData on my PC, so I should be able to figure more of this stuff out myself now.
Old Apr 11, 2014 | 07:02 AM
dadaroo's Avatar
dadaroo
Yes you could put the ammeter anywhere in the circuit. Just be careful by using a positive side lead so you don't accidently ground the circuit.
Old Apr 11, 2014 | 08:20 AM
TA427's Avatar
TA427
5th Gear
Make sure to leave the ammeter in place for 20 to 30 minutes, before pulling anything, as some modules take a while to go to sleep
To Phantom battery draw
