Re: Electronic Concern or Window Valet? (SDFVETTEMAN)
I've had the windows come back down a couple of times. After resetting the option, though, it's worked fine. I think the variation of having the top off & on confuses it sometimes (it thinks there's an obstruction).
I have not had your problem.
I suggest the you repeat the calibration routine.
I believe that the window needs to be full down, before the close feature will work properly.
