'99 LED Tails Blink Too Fast.
Old Jul 9, 2002 | 10:55 PM
gregrey_miller's Avatar
gregrey_miller
Cruising
Default '99 LED Tails Blink Too Fast.
I installed 4 'JamStrait 3157-HR' LED tail lights in my C5 the other night. Now the left and right blinker speed is way too fast. That is the only thing abnormal. The hazard lights, when activated, blink at a normal speed.
Has anyone run into this before? Is there a simple fix (module) that I can just plug in somewhere?
I know the car doesn't have an individual blinker relay after looking in the factory service manual. Everything seems to run through the hazard switch up by the center vent.
Can anyone give me some advice? Thanks!
-Greg
Old Jul 9, 2002 | 11:16 PM
intel55's Avatar
intel55
Default Re: '99 LED Tails Blink Too Fast. (gregrey_miller)
hmmm not sure about the LED's but I have a front right turn signal light out and that makes the right side blinkers blink super fast. That is they way they tell you, you have a light out...not sure about the LED's, but make sure all your signals and such are working. :cheers:
Old Jul 10, 2002 | 12:27 PM
wt2ga's Avatar
wt2ga
Adjure, Inc.
6423 E. Washington Blvd
Commerce, CA 90040
1-888-966-9333
Makes an Electronic Flasher (FLSH-101) $25.95 and a Flasher wire harness (CV101-4/C5) $24.95 plus $5.00 S/H
It installs under the Dash near the IP with a PIGTAIL
They Have a website also.
I have found the the 'JamStrait 3157-HR' LED tail lights do not provide enough light to fill the Tailight cavity. If you want to go ahed with the Adjure fix E-Mail me and I will give you install Instructions....Bill
Old Jul 10, 2002 | 03:33 PM
LT4POWR's Avatar
LT4POWR
Hey Greg!!!
Post #1, welcome to the forum!!!
Old Jul 11, 2002 | 07:23 PM
gregrey_miller
Cruising
Default Re: '99 LED Tails Blink Too Fast. (LT4POWR)
Ty- Thanks! Congrats to you on the recent announcement!
Bill- Thanks for that info. I will definitely check into the Adjure site!
Chicago- All lights work, so it's not a bulb out. By the way, is that a pic of your silver C5 with european red/clr? What did you do with your original rear lamp housings? I would like to find an extra set for about $50 to do a little custom work on.
Old Jul 11, 2002 | 09:54 PM
intel55's Avatar
intel55
yeah I think I have mine a box somewhere. Pay the shipping +$10 and they are all yours. I think I have them in two boxes...hmmmm
Old Jul 14, 2002 | 11:02 PM
gregrey_miller
Cruising
Default Re: '99 LED Tails Blink Too Fast. (intel55)
If you can find them, I'll buy them from you. Check your AOL mail for how to contact me. Thanks.
To '99 LED Tails Blink Too Fast.
