clutch peddle release
Old Dec 15, 2013 | 12:45 PM
PacecarHI's Avatar
PacecarHI
Default clutch peddle release
Looking for the answer to why my stock 1998 (54K) clutch peddle failed to release after a 2 mile hot parade.
Through out the parade i was playing with the clutch and gas, no problems.
at the end when I was stopped to let the passenger out the peddle did not want to "spring back". it only came back about a 1/4 of travel.
I pumped it a few times and nothing happened. Then all of a sudden it returned.
I drove around the corner parked and did a visual check, spring was in place tight, clutch fluid was full (might be considered HOT to the touch), nothing out of the usual.
I let the car sit for about 15 minutes, drove it home about 8 miles and didn't experience any problems.
Could the fluid have gotten too HOT and caused the peddle to act up? I've done many parades and haven't had that happen before.
Old Dec 15, 2013 | 12:56 PM
Ron222's Avatar
Ron222
Hey Pacecar, Check out this link, it may help. It's a very common problem, you may also want to try the tick master some find that, that has helped, or maybe it's just time for a new clutch....
http://www.rangeracceleration.com/Clutch_Care.html
Old Dec 15, 2013 | 04:18 PM
PacecarHI's Avatar
PacecarHI
Thanks...
sounds like the problem, looks like the problem, will do simple maintenance to try to resolve problem...
To clutch peddle release
