Installing the Depo projector beam kits
Also, some of the kits say that you have to modify the new lights to use your existing HID bulbs. Is there truth to this, or are they wanting to sell you their HID bulbs???
TIA
http://forums.corvetteforum.com/c5-t...l-in-here.html
should take about 10-15 minutes if that
Mine came with normal bulbs, but I went to an auction site and bought HID's for low, high and yellow fog lights. I also bought the kit that keeps the High, low, and fog on when you have the high beams on. With all 6 on at night it lights up everything in front of you.
There is no way you will want to go back to normal bulbs.
I will give you a tip, you need to seal up the 12v electrical connections to the ballasts because if not they will start giving you problems. I use clear silicone sealant.
Are you happy with the quality, fit, and overall appearance? Do the HID bulbs drop right in with no mods needed? What HID bulb do we use for the high beams?
I originally had the large ballasts which had seperate metal brackets for mounting but swapped them for the slim which are much easier to hide and have holes in them to mount them without brackets.
Just be sure the female plugs are tight before final install. each time you unplug them they loosen a bit. I used a small precision straight screwdriver and inserted a bit of aluminum foil on the side of one of mine that was not getting good contact. The connections from the bulb to the ballasts have never given any problems.
If you go with 55 watt HID's you may want to either add a relay kit or change your fuse to a 30 amp. They pull more power to start them but use much less than normal bulbs after the initial start-up
Use normal high beams if you do nt get the kit to allow the low to stay on with the high because it takes 15-30 seconds for them to come to full brightness when cold.
A vendor here sold me the kit 3/4 years ago I am not sure if he still does if not it is hard to make your own with a few fuse taps and common relays for fog lights..
