idle relearn procedure
Old Jul 10, 2002 | 01:56 PM
blue98coupe's Avatar
blue98coupe
Default idle relearn procedure
I have a 98 A4 , what is the idle relearn procedure . Thanks Guys :cheers:
Old Jul 10, 2002 | 02:27 PM
Jim Shearer's Avatar
Jim Shearer
Default Re: idle relearn procedure (blue98coupe)
From the 2000 Service Manual:
Perform the following procedure in order to return the learned idle to the correct position:
Automatic Transmission
1. Turn OFF the ignition.
2. Restore the PCM battery feed.
3. Turn OFF the A/C controls, radio, and any other accessories
4. Set the parking brake and block the drive wheels.
5. Start the engine.
6. Ensure that the engine coolant temperature is more than 176°F (80°C).
7. Shift the transmission into Drive.
8. Allow the engine to idle for 5 minutes.
9. Shift the transmission into Park.
10. Allow the engine to idle for 5 minutes.
11. Turn OFF the engine for 30 seconds.
Manual Transmission
5. Place the transmission in Neutral.
6. Start the engine.
7. Ensure that the engine coolant temperature is more than 176°F (80°C).
9. Turn OFF the engine for 30 seconds.
