Supercharger thoughts--which is best?
Old Dec 24, 2013 | 03:54 PM
leetownreb's Avatar
leetownreb
Default Supercharger thoughts--which is best?
Any thoughts on the best type of supercharger? Would appreciate any input. Thinking of a Magnacharger. Thanx.
Old Dec 24, 2013 | 04:27 PM
Kmcoldcars's Avatar
Kmcoldcars
What is best kind of depends on what you want to do with the car and whether or not you want to get a different hood? Give us more information.
Old Dec 24, 2013 | 08:02 PM
leetownreb's Avatar
leetownreb
Low RPM torque and no hood mods.
Old Dec 25, 2013 | 01:06 AM
Tech's Avatar
Tech
You have 3 choices. A&A, ECS or Procharger. Roots-style blowers (like Maggies) require aftermarket hoods. Centrifugal do not.
Old Dec 25, 2013 | 09:02 AM
Solofast's Avatar
Solofast
Yes, and centrifugal superchargers have no low end, they don't make any power down low...
You need a Roots type blower if you want low end...
Either that or get a bigger motor in the first place.
Old Dec 25, 2013 | 08:55 PM
leetownreb's Avatar
leetownreb
Appreciate responses. Thanx.
Old Dec 25, 2013 | 10:58 PM
c5austin's Avatar
c5austin
I don't want to get into the Centri Vs. Roots blower as this has been beat to death but, what I will say is if you are looking for a blower with no other mods like a hood. You have 2 main company's to look into, both are great company's with great tech support. ECS and A&A are both top notch. The MAIN question you have to ask yourself is who is going to install and tune it. This is the absolute most important part to a long- surviving LS. Next question would be do you have any state wide rules (A&A blowers are CARB legal, meaning legal in states like CA etc).
PS-if anyone tells you that a centri has no low end torque is full of it!!! Ask 4DRUSH in the FI section ( check out his thread of a wheelie) with a centri
Old Dec 26, 2013 | 08:14 AM
Mattie Num Nums's Avatar
Mattie Num Nums
No low end? Just throw in a cam problem solved! You can still pass emissions with a 224/232/116. I have 635 on pump and my smile never disappears. Only my fuel!
Old Dec 26, 2013 | 08:47 AM
C5Natie's Avatar
C5Natie
I have a vortech from A&A and im very happy with it. They dont make as much torque as the twin screws but the top end power is great. Theyre more compact, lighter and keep the weight lower for a lower center of gravity vs twin screws. Just my $0.02
Old Dec 26, 2013 | 08:59 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I have an A&A and I'm very happy with it.
You'll lose about 1-1.25 inches of ground clearance since the stock kit drops the rad cradle but it's pretty easy to cut and reweld the pads that the rad sits on so you can put the cradle back in the stock position.
You'll also then have to move the intercooler up an inch or so but the pressure pipe should still clear the hood.
If it doesn't it's thin metal and you can flatten it down a bit with a mallet.
Old Dec 26, 2013 | 11:53 AM
zeevette's Avatar
zeevette
Don't rule out turbocharging. IMO, it's the best TQ producer, other than spray, in the choices of FI. It's also the most expensive. (in most systems)
I too, have an A&A setup, and couldn't be happier with the power curve. With our motors, low end torque is abundant enough to limit traction, even stock. Choice of transmission and gearing is a factor, too.
Old Dec 26, 2013 | 04:49 PM
NEvetteMAN's Avatar
NEvetteMAN
I just purchased my first vette (1998 Coupe) and it is equipped with a procharger and I have yet to find a need for more power, low or high end. I don't know much about the other options, but this one seems to be nice and compact for sure and does the job.
Old Dec 27, 2013 | 04:43 PM
StatmanRN's Avatar
StatmanRN
If you want instant throttle response and low end torque, you can't beat a roots type blower.I say ride in both before you choose.
Old Dec 27, 2013 | 06:04 PM
lsxvette's Avatar
lsxvette
im happy with my a&a so far
Old Dec 27, 2013 | 06:10 PM
85corvettec4's Avatar
85corvettec4
Twin Screw and Ram Air hood
Old Dec 28, 2013 | 01:11 PM
Tech's Avatar
Tech
This is misleading. They may not make as much power at 2,000 rpms as a roots-style blower, but they still make plenty of power from 3k up. If you're racing at 2k RPMs (or even participating in some spirited back roads driving at 2k), you're doing it wrong.
As others have said, usable power is what matters. That is, unless you just like doing donuts and burnouts. If that's the case, don't upgrade anything except for the transmission and rear end.
Old Dec 29, 2013 | 10:46 AM
IntoC5's Avatar
IntoC5
6th Gear
I put a Procharger on my 98 plus Kooks LT headers and Magnaflow exhaust as well as injectors and modified fuel system and got 506 RWHP. I am very pleased with the Procharger. Low end is definitely not a problem.
Old Dec 29, 2013 | 12:29 PM
Mattie Num Nums
Plus, that allows you to actually drive the car and tame it down when you want. My car is very easy to drive when you want it to be.
To Supercharger thoughts--which is best?
