Transmission not shifting
Old Dec 26, 2013 | 10:12 AM
illselek's Avatar
illselek
5th Gear
Default Transmission not shifting
MY 1998 C5 won't shift out of 2nd and rpms are higher than usual during acceleration. can anyone help??
Old Dec 26, 2013 | 10:16 AM
chaase's Avatar
chaase
St. Jude Donor '12
check for low transmission fluid and check for any codes. Unfortunately, your transmission may be on its way out though.
Old Dec 26, 2013 | 11:11 AM
illselek's Avatar
illselek
5th Gear
I forgot to mention there is a bit of smoke coming from the rear of the motor
Old Dec 26, 2013 | 11:27 AM
chaase's Avatar
chaase
St. Jude Donor '12
That might be an oil leak. However, the transmission is in the rear of a C5 so you might have two issues.
To Transmission not shifting
