C5 Headlight Problem
Old Dec 26, 2013 | 12:25 PM
rafaelyzulma's Avatar
rafaelyzulma
2nd Gear
Default C5 Headlight Problem
My 04 vette is doing crazy things with the lights and hopefully somebody can help me with it. The headlamp module was bad, so I replaced it with a used one I bought on ebay (I actually bought 2 and saved one). After that, the lights were working perfectly. I tested both modules to ensure they were both working properly. While I was washing the vette yesterday, the left light popped up on its own. Then it lowered, and the right one popped up. It did that a couple of times and stopped. I took the module out and realized the module had been oppened and repaired previously but not sealed properly, so the water got in it. I replaced it with the other one. Now the lights open properly when turned on. When I turn off the lights, both lights close but the left light comes out again. I closed it manually and tried it several times, but it continues doing the same thing.
Old Dec 26, 2013 | 08:13 PM
kabluie's Avatar
kabluie
It sounds to me like you have another bad module, I could be wrong. Sometimes it is worth it to pay the price at the dealer.
Old Jan 6, 2014 | 03:28 PM
rafaelyzulma
2nd Gear
Appreciate the input. I do think that is what the problem is. I guess I was worried that it could be something else that got damaged with the water short. I won't be able to test the theory until I get back home. I'll be away from Texas here at Missouri until March. Talk about timing... I just got the snow storm.
To C5 Headlight Problem
