Traction Control System Codes "help"
Old Dec 28, 2013 | 01:10 PM
Brian O's Avatar
Brian O
Default Traction Control System Codes "help"
I was going to send my ABS/ TC Module control out to get serviced because both ABS & TC lights come on. I ran the codes before I was going to take it apart. This is what I have showing and not sure if the module is bad. Can anyone point out if I still need to send it out or look else for the problem.
My errors come up most of the time when I first start the car, after it runs for a while (Up to tempurature), shut the car off and restart its good the rest of the time I'm driving with no errors.
28-TCS Codes: C1225 & C1226 Excessive wheel speed variation (Not sure what this is). C1243 BPMV Pump motor stalled.
Old Dec 28, 2013 | 06:35 PM
xzo124's Avatar
xzo124
thats what mine was , replaced senser and hub assembly and no more codes . first check senser connections , clean and make sure the mounting clip is good and tightly set . reset the codes ,drive and if it poppes the code change hub assemblies ....xzo
Old Dec 30, 2013 | 06:38 PM
Brian O's Avatar
Brian O
Thanks for responding. I will check everything and clear the codes and see what happens.
Old Dec 30, 2013 | 06:41 PM
xzo124's Avatar
xzo124
AutoZone has a pretty good price on them...xzo
Old Dec 31, 2013 | 08:35 PM
Brian O's Avatar
Brian O
Originally Posted by 8VETTE7
In most cases it is NOT necessary to replace the hub when these codes are stored. Most often it is the wiring to/from the wheel speed sensor portion of the hub or the contact surfaces in the connector.
Remove the two front wheels and examine the wiring for the wheel speed sensors for damage. Separate the connector halves for the sensor to car connection and examine the connector contact surfaces for corrosion or deformation. Correct as needed. Clear all the codes, take the car for a spin and see what codes have come back when you return from your ride.
The pump motor stalled problem (C1243) can often be corrected without having to replace the pump.
Read the post by Bill Curlee ( #6) in the following thread. He quotes the shop manual on C1217 and C1243. May help you out.
http://forums.corvetteforum.com/c5-t...trol-unit.html
Here are a couple additional threads on how to "exercise" the BPMV:
http://forums.corvetteforum.com/c5-t...-best-fix.html
http://forums.corvetteforum.com/c5-t...r-display.html Post #6
Certainly worth a try before spending any $$$$
Once you clear the BPMV problem exercise your anti-lock brakes regularly to prevent it from coming back.
Thank you! I'm going to check everything out this weekend. I will let you know how I make out. This information is a big help.
HAPPY NEW YEAR TO ALL OF YOU!!
Old Dec 31, 2013 | 10:22 PM
SPEED750's Avatar
SPEED750
Has the car been sitting for a long time or very low mileage. My 97 set for months before I bought it. It would throw the ABS/TRACTION CONTROL code every time I hit a big bump in the road. I cleaned the grounds and the more I drove it the less the codes popped up. Haven't had a code come back in the last 4 months.
To Traction Control System Codes "help"
