Is she lowered already
Old Dec 30, 2013 | 07:28 PM
danieloneil01's Avatar
danieloneil01
Default Is she lowered already
If not can I get it lower? I've heard people removing the rubber pieces but will this cause any issues?
Rear
Old Dec 30, 2013 | 10:31 PM
rbrumm's Avatar
rbrumm
You can cut the rubber in half. So it's half as tall. I would leave some rubber and then you can get a few More turns on the nut so that you have about 1 1/2 or so of threads showing that should get you a little over 1/2" lower
Old Dec 30, 2013 | 10:38 PM
danieloneil01
I thought it was supposed to be loosened to make it more lowered. I r stoopid.
Old Dec 31, 2013 | 12:09 AM
rbrumm's Avatar
rbrumm
You do loosen things up The picture looked like the bolt had a little left to loosen . if it doesn't, then the only thing left to do is cut the rubber bushing When you buy a lowering kit the bolt has little to no rubber with a longer threaded stud giving you a little more adjustment you can remove all the rubber and just put a thin nylon washer so you don't have metal to metal touching.
Old Dec 31, 2013 | 11:52 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
With only 2 threads left on the bolt .... its lowered the max on the stock bolts.
Toque
Old Jan 1, 2014 | 04:55 PM
RedZMonte's Avatar
RedZMonte
lowerd on stock bolts.. you can cut the rubber or just get a longer bolt for the rears. thats basically all the eibach and other kits are.
S
Old Jan 2, 2014 | 11:28 PM
GenerationX1's Avatar
GenerationX1
Here is a pretty good thread that I found a while back in help making my decisions on lowering. However, I do have aftermarket lowering bolts on my Z06.
Mark is correct about the amount of threads that are showing on your car.
http://forums.corvetteforum.com/c5-t...ng-the-c5.html
To Is she lowered already
