Need help with oil leak
Old May 31, 2018 | 09:43 PM
  #61
thundertruck's Avatar
thundertruck
Default Don't shoot the messenger...
Originally Posted by ls1k5
After it's been sitting overnight I'll start it up and it takes at least a minute or two for it to start dripping, not sure if that helps with the diagnosis but for someone who's had this problem before maybe it will help.
Hate to be the bearer of BAD news, but I am 99.99% sure that it is the rear cover gasket that has blown out, and not the cam sensor O-ring leaking. The oil leak in your picture is exactly the same as the one I had. The rear cover/gasket/seal kit fixed it right up. My son and I did it on the ground without a lift. Bought a heavy duty transmission jack from H**bor F***ght, and rolled the entire rear suspension, diff, trans, and torque tube assembly out. Also used a regular floor jack on the front of the torque tube. The transmission jack was a bit of overkill since it is rated for 2000 lbs, but it was nice and sturdy, rolled smoothly, and made maneuvering the whole thing much easier. Cost about $300.00 regular price, but you can get 20% off coupons all over the place. Saved way more than that v/s having the stealership do it for me, and I get to keep the jack.
Old Jun 1, 2018 | 11:31 AM
  #62
ls1k5's Avatar
ls1k5
Default Thanks, I didn't think it was possible for the cam sensor o-ring to leak that badly.
I was pretty sure that it was the rear cover but hoping for a quick fix. Looks like I know what I'm doing this weekend.
