what is my ls1 engine worth?
Old Jan 4, 2014 | 09:47 AM
andy9743's Avatar
andy9743
Default what is my ls1 engine worth?
hey guys,
looking for some assistance with pricing on my engine that i recently pulled. it is a 99 model block with approx 100k on it. heads, cam, double roller, oil pump, springs, lifters, lifter trays, 42 lb fast injectors have sub 1k miles (with receipts from install @ Mike Norris's shop http://www.mikenorrismotorsports.com/)
-tpis ls6 intake mani with 90mm tb
-cam (custom grind that Mike recomended, very mild manners with tune)
-cnc ported 853 heads done by landspeed in Il http://www.landspeedheads.com/LandSpeed/
-42 lb FAST injectors
i'll reuse my oil pan on my stroker that is going in along with my accessories. car made 426/414 through a 6 speed with longtubes (have dyno sheets) could also pull the tune off of car with hp tuners and install on another car. not sure where to start with advertising it?
suggestions? thanks for the help guys!
andy
Old Jan 4, 2014 | 05:30 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Be a pita, but prob make more money parting it out. I would say 2k tops for it as a long block, and you could make more by selling it all separate. The cam, lifters, pushrods, alone could net you 400+
