Weird Brake Lights Issue....Or Not??
Old Jan 7, 2014 | 03:35 AM
LIGHTNING's Avatar
LIGHTNING
Default Weird Brake Lights Issue....Or Not??
C5 in garage...engine off...key not in ignition....I stepped on brake pedal....
friend standing in back pointed out that the 2 left brake lights were out...just right 2 & center light were on. Couldn't figure out why. Then realized turn signal stem was in "left" position. I moved it to neutral/center position & all brake lights came on when I stepped on brake. So I tried it again, this time moving turn signal stem to "right" position. Now the right 2 brake lights were out & left 2 were on. Also tried it with stock bulbs....same thing.
Thing is, I have no idea if it was always like this, or has something to do with my recently installed LED taillights, turn signal sequencer, & hyperflash harness. And how would turn signal indicator effect brake lights if ignition is off?
Old Jan 7, 2014 | 06:52 AM
65GGvert's Avatar
65GGvert
It's normal. There's no turn signal flash with ignition off and brake voltage to that side is interrupted. The flasher is not powered with key off.
Old Jan 7, 2014 | 06:54 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
100% correct!
Thanks,Matt
Old Jan 7, 2014 | 11:08 AM
LIGHTNING's Avatar
LIGHTNING
Makes sense....thanks!
Old Jan 7, 2014 | 11:40 AM
dadaroo's Avatar
dadaroo
Here is why:
The yellow wire from the Multifunction switch is the one for the rear driver side turn signals and brake lights.
The 3rd brake light goes around all this directly from the brake petal switch.
To Weird Brake Lights Issue....Or Not??
