Help! Brake Noise
Old Jul 11, 2002 | 07:18 PM
Dale RED 98's Avatar
Dale RED 98
Default Help! Brake Noise
I have just installed new rotors(Baer),Z06 calipers,Hawk pads and brake lines.(300 miles on them) Everything seemed fine until I have developed a snapping or cracking noise when stopping the car.I only notice this at slow speeds really only when I am backing or pulling out of the garage or in to a parking place. I replaced all the hardware (spring clips or anti rattle pieces) today thinging the pads were slipping around but this did not help.Any ideas on what is wrong? It sounds like the noise is coming from the right rear. Thank's for any help! :cheers:
[Modified by Dale RED 98, 6:22 PM 7/11/2002]
Old Jul 11, 2002 | 08:56 PM
Dale RED 98
Default Re: Help! Brake Noise (Dale RED 98)
ttt :confused: Anybody have a clue? :cheers:
Old Jul 12, 2002 | 08:14 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
I would check all your torque settings once again and make sure that they are within specifications... If they seem to be OK you might want to check out your wheel bearings for they can make a similar noise if faulty... I don't want to be an alarmist but it just would be prudent to do so IMHO...
Old Jul 12, 2002 | 08:23 AM
Patches's Avatar
Patches
Dale,
Before you installed your new calipers, did you check to see if they slide freely relative to the caliper bracket pins? If they are not lubed properly and are binding, I could see this as one source of the noise. Also, the bolts that hold the brackets to the calipers need to be torqued to 30 ft.lbs.
Ed
Old Jul 12, 2002 | 06:13 PM
Dale RED 98
Default Re: Help! Brake Noise (Patches)
Nick and Ed! Thank's for the repley's. I will double check the torque setting's. Ed I had a shop do the work and I don't know about bracket pin's sliding freely or the lube. This guy said he's done alot of work on C5 's (brakes) but I'm beginning to wonder! :confused: Thank's again! Ed do you have any pictures showing these pin's and where the lube should be I guess I will give this a try myself. :eek: :cheers:
Old Jul 13, 2002 | 10:53 AM
Patches's Avatar
Patches
You have mail. :) Oh, and ttt. :D
To Help! Brake Noise
