Low coolant sensor and sensor pigtail(connector) missing ???
Old Jan 18, 2014 | 04:29 PM
always faster's Avatar
always faster
Default Low coolant sensor and sensor pigtail(connector) missing ???
While i was taking some pics to help Toque on another thread, i told myslef that i could unbolt my coolant surge tank and drain it.This way i would be ready to install the new one when it will be shipped.
But here is the bottom of my tank :
It seems that it got no sensor in it, and the other things that bothers me is that nothing was connected to the tank, no pigtail or connection.After some searching i couldnt even find the low coolant sensor wire
I got the car for 3 years now and i never had any low coolant light or dic message or code...Does anyone got a pics of the pass side engine bay to show me what to look for (connector) ???But i can swear after a hole our of looking with good lighting that there is no connector what so ever...
Or maybe its just me and everything is wireless(sarcasm )
Eric
Old Jan 18, 2014 | 05:24 PM
Cutlassmaster's Avatar
Cutlassmaster
Depends on your year. The newer models don't have it. If I recall correctly, 2000 - 2001 and later don't have them.
Chris
Old Jan 18, 2014 | 05:35 PM
always faster
Chris
I got a 01 c5z ,can anyone confirm that info
Old Jan 18, 2014 | 05:47 PM
Cutlassmaster
From what I found, 2000 forward didn't use a sensor. So you don't have one.
Chris
Old Jan 18, 2014 | 05:54 PM
always faster
Chris
Well thank you sir
Now debating on putting a oem back or a superbe moroso aluminium one
Old Jan 19, 2014 | 08:26 AM
dadaroo's Avatar
dadaroo
I have a 2001 and the FSM. I had thought there was a sensor but when I helped a friend with a coolant issue a year ago I was surprised to see there was no sensor. Hope you were drinking beer for the hour you looked. I would hate to think you wasted a whole hour just looking.
Old Jan 20, 2014 | 02:11 AM
always faster
Thanks for all the info
Now that i know that the tank got no sensor, im now wondering:
If i ever miss some coolant,what would tell my pcm that i got a low coolant level if there is no sensor in the tank and no sensor in the rad ???
Old Jan 21, 2014 | 09:23 AM
always faster
Old Jan 24, 2014 | 08:44 AM
dadaroo's Avatar
dadaroo
The PCM just monitors the actual coolant temperature and sends a message to the IPC if the temperature exceeds 256 F. Not sure why they deleted the level sensor unless it was to save a few pennies. The FSM still shows the low level input to the IPC for this except it says "not used".
To Low coolant sensor and sensor pigtail(connector) missing ???
