Mileage from EMTs
Old Jul 12, 2002 | 02:15 AM
RacerChris's Avatar
RacerChris
Default Mileage from EMTs
My C5 is about 18 months old and has 14000 miles. I am disappointed to see that my tires are seriously worn, but fairly even. I run about 28 psi all the time. They look alot like my friend's 98 with 30k+ miles on his. I don't drive hard, except at the four autocrosses I have attended. But even then, I don't do burnouts or squeal tires.
Is anyone else experiencing so few miles from there Goodyears? Could there have been something wrong with them from the factory? :cheers:
Old Jul 12, 2002 | 03:35 AM
GmasterB's Avatar
GmasterB
Default Re: Mileage from EMTs (RacerChris)
I got about 20k out of my stock Goodyear EMT's, no track time at all, just street use. I now run Yokohama EMT's.
Old Jul 12, 2002 | 03:59 AM
AFVETTE's Avatar
AFVETTE
Hard to provide an exact answer since there are so many variables. Some folks have gotten over 40K on the EMT's while other's were lucky to get 10K. I have 17K and they were just measured at 5/32nd's (new is 11/32nd's).
Tom
USAF Retired
Old Jul 12, 2002 | 08:07 AM
Tom/99's Avatar
Tom/99
I have 12,000 miles on my EMT's. They still look like new.
Old Jul 12, 2002 | 08:31 AM
RyanC7's Avatar
RyanC7
Default Re: Mileage from EMTs (Tom/99)
A friend of mine got 18k out of them.
:seeya
Old Jul 12, 2002 | 09:15 AM
ROD BROWN's Avatar
ROD BROWN
I just replaced the rear tires at 40000 miles.I keep 32lbs. in the front and rear.I don't know if this is the reason I got such good mileage off the tires but I am doing the same air pressure as I did with the original tires.Another thing I did,was balance the tires every 10000 miles.My friend owns a tire shop and he balanaced them at a very reasonable price,so I just do it. :chevy :chevy :flag :chevy :chevy
Old Jul 12, 2002 | 09:25 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Sounds like you're running a bit low on the pressure. It should be closer to 30-34 (cold to hot).
Old Jul 12, 2002 | 01:57 PM
REDLYNER's Avatar
REDLYNER
Default Re: Mileage from EMTs (Scissors)
I just put Nitto 555's on last night, replaced the my EMT's at 44,000 miles! Of course, I had cords showing on the front tires. (I don't recommend this!)
Old Jul 12, 2002 | 02:11 PM
jimman's Avatar
jimman
Default Re: Mileage from EMTs (REDLYNER)
Had 46,000 on rears and 60K on the fronts on my 00
Old Jul 12, 2002 | 02:43 PM
rim98's Avatar
rim98
Default Re: Mileage from EMTs (jimman)
I got 26k out of them. The fronts could've gone another 5-7k more but the car was getting too slippery for my taste, especially on wet roads. :eek: :eek:
Old Jul 12, 2002 | 02:54 PM
COOL Z06's Avatar
COOL Z06
I had 35,000+ on mine and they still had tread left :eek: but I wanted to put on my Z06 wheels and Pilot Sports, so....... away they went! :D
Old Jul 12, 2002 | 03:34 PM
Jerry Kane's Avatar
Jerry Kane
The previous owner of my car replaced them at 43,xxx miles. She must have driven it very gently (of course, I get 26mpg city and 32 highway, so I must be driving it very gently too!).
Old Jul 12, 2002 | 03:44 PM
CALVette's Avatar
CALVette
Cruise-In IV Veteran
Cruise-In V Veteran
29,000 and lots of rubber left.
Old Jul 12, 2002 | 04:16 PM
ncvetteman's Avatar
ncvetteman
30+k miles... fronts look like new but backs have started to show wear in the center. Your tires will last longer if run at a higher pressure in most cases... mine are normally 32psi cold. I drive a fair about on the highway.
Old Jul 12, 2002 | 06:13 PM
Just replaced the front and rear OEM tires with Goodyear Supercar tires. Sold the fronts, and they still had about 7.5/32nds of tread left on them after about 13,500 miles. The rears were getting pretty thin. This was with normal driving (i.e., no track time, no autocrossing, etc.).
Was hoping they would get better mileage out of them.
Old Jul 12, 2002 | 07:51 PM
muscle cars's Avatar
muscle cars
At 9,000 miles my 2001 has 5/32nd on the rear and 8/32nd on the front at 30psi. I believe this may be due to hard acceleration that didn't induce traction control but allowed a small amount of wheelspin many times over. You can believe I am much gentler now on the accelerator since it's hard to feel/hear the wheelspin. It never mattered before with my other cars but these EMT's are not tossaways at over $300 a pop. :eek: Raul
To Mileage from EMTs
