LS 6 engine block repair(s)
Old Jan 19, 2014 | 02:15 AM
charlie808's Avatar
charlie808
Cruising
Default LS 6 engine block repair(s)
My 2003 Z06 (LS6) engine fell victim to the batch of bad valve springs GM used and sucked a valve causing extensive damage to the cylinder. The steel sleeve was penetrated and the aluminum block broken/cracked. Car is up and running again with donor engine, but I am going to try to save the original block. I have it pretty much torn down and will attempt to attach a photo here. I have been doing some research on aluminum welding repairs, but was just wondering if anyone has had some personal experience with repairs of this nature and what success you have had.
Old Jan 19, 2014 | 05:37 PM
tlove32's Avatar
tlove32
Not worth it in my opinion. I think that block is scrap metal
Old Jan 19, 2014 | 05:43 PM
racebum's Avatar
racebum
scrap
blocks are cast aluminum, a weld would never hold the same or be able to penetrate. sleeving also would be expensive
you can buy a complete ls6 from a wrecked car with excellent compression for $3000 or so complete.
get one of those and sell that block for scrap after you salvage all the usable parts
to even attempt a repair you would have to go to a shop that sleeves engines, press that sleeve out, then tig weld the cracked area if it's only the place that's visible. then you would have to bore the aluminum to true that weld up, then press a new sleeve
that's just to save the block, not a build, not boring, not a hone, not anything. could be a lot of $$ for a block that's been weakened
Old Jan 19, 2014 | 05:54 PM
ZeeOSix's Avatar
ZeeOSix
Ouch ... that sucks. Anyone who still has the OEM valve springs in their 2002 & 2003 LS6, best read this thread and swap out those springs.
http://forums.corvetteforum.com/c5-z...-failures.html
Old Jan 19, 2014 | 08:51 PM
YELLO C5's Avatar
YELLO C5
I'm thinking about turning my old block into a wine rack.
Old Jan 19, 2014 | 09:46 PM
racebum's Avatar
racebum
epic idea
To LS 6 engine block repair(s)
