clutch problem solved!!!!!
Old Jul 12, 2002 | 08:54 AM
howardl's Avatar
howardl
Default clutch problem solved!!!!!
Installed a new heavy duty (McLeod) master cylinder last night and now I have plenty of engagement room instead of way down on the floor. My old master cylinder was slowly getting worse (bypassing) what a plastic piece of crap. I can imagine a lot of people thinking they have transmission trouble and all it is a bad master cylinder.
Old Jul 12, 2002 | 10:15 AM
rfgoss1's Avatar
rfgoss1
Default Re: clutch problem solved!!!!! (howardl)
Howard
I went through some problems with Master Cylinders on my car. Do you have any pics of the McLeod? Lou at LGM had to fab a new one for me because the Cartek rod bent. I am not putting down the Cartek! But Lou and I didnt want to run any risk of repeat failures.
Randy Goss :cheers:
Old Jul 12, 2002 | 01:19 PM
howardl's Avatar
howardl
Default Re: clutch problem solved!!!!! (rfgoss1)
There is a pic on this thread http://forums.corvetteforum.com/zerothread?id=330719
It's a nice solid unit..
Old Jul 12, 2002 | 01:55 PM
jmX's Avatar
jmX
Anybody that has ANY disengagement problems should try the mcleod master. I got one of the first units ages ago and it was definitly the product that ended all the aftermarket LS1 clutch woes.
To clutch problem solved!!!!!
