Help me identify this wire
Old Jan 31, 2014 | 05:01 PM
ZeeOSix's Avatar
ZeeOSix
Looks like a ground wire. There is a grounding lug on the frame located between the battery box and the fuse box (if you're looking straight down on the frame rail). On my 2002 Z06, there are 3 ground wires connected to the lug, and one of those wires looks similar to yours, and it runs over to a larger wire harness that goes into the cabin.
Old Feb 1, 2014 | 09:20 AM
dadaroo's Avatar
dadaroo
In my 2001 FSM there are a couple of single lug ground wires (black and white) that are in that area. One goes to G104 (I believe this is the one shown above) and the other to G106 in that same area. I found these by looking in the Volume 2 engine electrical and controls schematics this morning.
The only one that goes back into the passenger compartment is the one going to G104 but it goes to a splice pack S208 that services grounding a number of things like the instrument panel among others.
The other one going to G106 provides grounding for things like the PCM and the MAF.
I am puzzled, but it definitely appears to be a factory ground wire and lug. Unconnected, if it were serving either of these 2 above functions you should have a bunch of problems.
Your only other option is to look in the I/P fuse box area and try to find where it goes. A real PITA.
Old Feb 1, 2014 | 06:41 PM
ATLZ16's Avatar
ATLZ16
This is exactly what i needed! Thank you so much. When I looked at mine I had the big gauge wire and the wire with the black insulation on it on that ground post. I also had another wire that you didn't have. Turns out it was the ground terminal from the retrofitted fog lights. I was missing the third naked black/white stripe wire you had on your ground post. What I think happened was during the retrofit someone just forgot to put that ground back on. After seeing that pic and the condition my car was in I feel safe saying that my unidentified wire should be on that post. I put it on the post put the battery back in and all is fine with the car so I think mystery solved. Thanks all for the help everyone!
Old Feb 1, 2014 | 08:30 PM
ZeeOSix's Avatar
ZeeOSix
... glad I could help and the mystery is solved.
Old Feb 2, 2014 | 08:01 AM
dadaroo's Avatar
dadaroo
Glad you are happy. I agree with 99.9% assurance it is a factory ground wire with lug. I am still curious if everything worked, where does this wire go?
Old Feb 2, 2014 | 10:06 AM
lionelhutz's Avatar
lionelhutz
Yup, a ground wire that goes to that stud which is G104. When you see what it grounds it is surprising the car worked as well as they did. All the stuff on SP208 is connected to that wire.
Old Feb 2, 2014 | 10:38 AM
ATLZ16's Avatar
ATLZ16
I bought the car with ~ 9k on it and have put another 2k on it myself in about 3-4 months. It hasn't had the slightest problem. Right now my gauge cluster is out because the previous owner had those red gauge ring bezels on the cluster. They are epoxied on so I am looking for a low mileage replacement and trying to find out how I can get the new one flashed w/ my mileage. With that said I haven't yet seen the cluster react to the new ground and I haven't been able to drive it but I feel very confident that ground is in its correct home and was probably forgotten during the fog light retrofit. Is so weird my car acted perfectly fine with that wire disconnected. I am eager to get my hands on a pristine gauge cluster so I can crank her up and take her for a spin.
Old Feb 2, 2014 | 10:40 AM
ATLZ16's Avatar
ATLZ16
Also from the above picture that stud has 1 large gauge wire and 2 small gauge wires. You cannot tell from the above picture but that wire with the large black heatshrink on it near the lug is actually an identical black/white stripe wire that goes directly underneath the engine bay fuse panel. Is the black/white stripe wire that comes from the passenger compartment the one that services SP208?
Old Feb 2, 2014 | 11:02 AM
lionelhutz's Avatar
lionelhutz
That's what my manual says for SP208 - "Instrument panel harness, RH side of instrument panel, grounded to G104 (CKT 851)"
I couldn't find a picture of it but it's saying SP208 is under the dash and it hooks to G104 out beside the battery so that wire has to be ground for it.
Old Feb 2, 2014 | 12:15 PM
ATLZ16's Avatar
ATLZ16
I believe you are correct. The only thing that worries me now is how were all of those things functioning without a ground. Makes me wonder what other type of rigging my car is hiding.
Old Feb 2, 2014 | 12:19 PM
dadaroo's Avatar
dadaroo
I just sent another person info on swapping the IPC board that houses the mileage from one IPC to another. I assume they are correct. I am not at home now but made a note to provide that when I do. It is not the mother board but a smaller board.
Old Feb 2, 2014 | 02:38 PM
ATLZ16's Avatar
ATLZ16
That would be great if I could avoid a trip to the dealer. I have a line on a one in good condition but mileage unknown. Once I get that taken care of I can button everything back together and go for a ride!
Old Feb 3, 2014 | 07:57 AM
  #33
dadaroo's Avatar
dadaroo
Here is the link on transferring the circuit board that stores the mileage. Refer to Post #5 and 11 specifically.
http://forums.corvetteforum.com/c5-t...e-cluster.html
Old Feb 3, 2014 | 02:26 PM
  #34
ATLZ16's Avatar
ATLZ16
I did some research of my own before you gave me that link and came across this post.
https://www.corvetteforum.com/c5-tec...ansferred.html
Here they say the bigger board houses the mileage. Are they wrong? Thanks again for your time.
Old Feb 4, 2014 | 07:23 AM
  #35
dadaroo's Avatar
dadaroo
I sent a PM to chevy406 since was a contributor to both Threads. Will let you know.
Old Feb 4, 2014 | 09:02 AM
  #36
dadaroo's Avatar
dadaroo
I heard from chevy409. He confirmed it is the big board in the IPC. He actually did a swap with another IPC and the odometer mileage DID MOVE by just transferring that one board. Given you just want to undo the previous bezel work done, just get another IPC and swap the board. The previous link I provided should provide enough info for the board swap. Good luck. Let us know how it goes.
Old Feb 6, 2014 | 07:43 PM
  #37
ATLZ16's Avatar
ATLZ16
So I got the cluster replaced and installed and all is good with the mileage and with the extra ground wire connected. I don't actually don't see a difference but it makes me feel better.
I do have one problem I am hoping I can get some help with. The Speedometer is off by 10 mph. When I am parked (car off or on) it reads 10 mph and when it sweeps when the key is turned to the on position it only goes to about 185-190. Could the needle just be in the wrong place or is their some adjustment? When driving it is a consistent 10 mph off the entire time.
To Help me identify this wire
Old Feb 8, 2014 | 01:53 AM
  #38
ZeeOSix's Avatar
ZeeOSix
How does the digital HUD speed readout compare to the dash gauge readout when you're going down the road?
Old Feb 8, 2014 | 07:53 AM
  #39
ATLZ16's Avatar
ATLZ16
The HUD seems to be right on. It shows 0 when I am stopped (speedo shows 10). If the HUD shows I am going 55 the speedo is reading slightly over 65 maybe 68ish. Didn't have this problem before the swap. I swapped all my old internals to the new cluster. Main board, power supply, and speaker. I did a ton of searching and couldn't really find anyone else with that issue. Can I swap the actual speedo gauge from my old cluster?
Old Feb 8, 2014 | 08:24 AM
  #40
dadaroo's Avatar
dadaroo
Yes, you can swap out any of the gauges. Never done it, but the speedo shops do it every day to fix the gauges. Will try and find any info I can.
You might try and see if you can move the needle on the armature to re-zero it. I would guess it is a press fit.
PS: No luck on my searches for the actual gauge removal.
