HELP! throttle body bypass install
Old Jul 12, 2002 | 09:52 PM
RWBJR's Avatar
RWBJR
Default HELP! throttle body bypass install
Ok, first let me startup by saying I'm not very mechanically inclined (as you'll see) I installed the tb bypass, started the car and and antifreeze all of the floor. I believe it is spraying out of the the bottom opening of the throttle body where the hose once was. Are you suppose to plug the two openings? Help! :confused:
Old Jul 12, 2002 | 10:28 PM
RWBJR's Avatar
RWBJR
Default Re: HELP! throttle body bypass install (RWBJR)
Is there anyone out there can lend a hand? I would greatly appreciate it!
Old Jul 13, 2002 | 01:08 AM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
YOU ARE SUPPOSED TO PULL OFF BOTH LINES AND THE BYPASS CONNECTS THE TWO HOSES TOGETHER. THE NIPPLES ON THE TB CAN STAY OPEN.
PAUL
[Modified by COH PAUL, 11:09 PM 7/12/2002]
Old Jul 13, 2002 | 03:15 PM
carpe dm's Avatar
carpe dm
The hose (with "bypass") goes to the nipple on the pass. head. Both TB nipples are free of hoses and can remain open or be plugged as you wish. Just running a single hose from the radiator to the head seems better to me. :rolleyes:
Old Jul 13, 2002 | 05:43 PM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: HELP! throttle body bypass install (carpe dm)
All I did was get a 1/4" hose and run from the radiator to the head inlet tube. Works just fine.
Old Jul 13, 2002 | 05:51 PM
RWBJR's Avatar
RWBJR
Thanks for the replies. Before I attached the hoses I did NOT remove the radiator cap to allow it to depressurize. Does radiator fluid remain in the intake manifold or somewhere else while the car is not running? Could that cause the bottom "nipple", under the coupler, to leak antifreeze when I started it? :confused:
Also, did you guys just push the rubber hoses over the bypass tube so that the bypass tube was not showing at all?
Lastly, did you guys just tuck the hose under the coupler or did you fasten it down some how?
Thanks for your help, I've learned a lot from everyone in the forum. There's a great wealth of experience and knowledge. :cheers:
Old Jul 14, 2002 | 08:29 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Be very careful here. One of the two lines that the bypass goes to is hidden under the TB. Do not make the mistake that I made and hook the bypass up to the breather line coming out of the top of the TB or you will pump coolant into your motor oil!!! :eek: :eek: :eek:
Old Jul 14, 2002 | 09:37 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Default Re: HELP! throttle body bypass install (Drop_Top_Dave)
I still remember your post... Didn't you have a relative help you with that or something?
Old Jul 14, 2002 | 02:13 PM
kewlbrz's Avatar
kewlbrz
Good point.
I just helped a forum member that did this the other day, and pumped coolant into his oil. To reiterate, do NOT use the hose that is on the top passenger side of the throttle body. That is the PCV hose.
Old Jul 14, 2002 | 08:02 PM
Drop_Top_Dave
Kid Rock Fan
Default Re: HELP! throttle body bypass install (Smoke-N-Shot)
:lol: :lol: :lol: No. I had no one to blame but myself!!! :mad
Old Jul 15, 2002 | 04:15 AM
benelliwang's Avatar
benelliwang
Not worth it, put it back to stock. You won't notice any gain in power even if there is power to be gained.
By the way, I have it installed on my car :jester
To HELP! throttle body bypass install
