PRT install help
Old Jul 13, 2002 | 03:27 PM
BAD 99's Avatar
BAD 99
Default PRT install help
I had B&Bs touring on my car ,from the year 2000
my ? is can i use the over the axle pipe from the old mufflers
I did and now iam having trouble with the alignment
sould i start all over with new pipes over the axle ,or is the old pipes the same :crazy:
thanks
Old Jul 13, 2002 | 03:36 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: PRT install help (BAD 99)
Bad, I dont know the answer to your question... but I hope you get it all fixed up. :yesnod:
vetterdstr :cheers:
Old Jul 13, 2002 | 03:41 PM
BAD 99's Avatar
BAD 99
Default Re: PRT install help (vetterdstr)
vetterdstr :cheers:
THANKS STEVE :cheers: :cheers:
Old Jul 13, 2002 | 11:07 PM
John Wiz's Avatar
John Wiz
I would assume that the over axle pipes are the same. Dumb question, did you loosen the bolts on the flange to the intermediate pipe. When I put mine on, those needed to be loose until the tips were aligned then could be tightened. If you did not loosen those, that would be my guess.
Wiz
Old Jul 14, 2002 | 12:08 AM
BAD 99's Avatar
BAD 99
Default Re: PRT install help (John Wiz)
thanks ill try that sunday :cheers:
Old Jul 14, 2002 | 11:18 AM
Byter's Avatar
Byter
BAD 99,
I just did the same thing and found that I had to replace the over-the-axle pipes. The lengths are a little different and it seems the hang a little lower than the previous "overs".
Also, I dumped the clamps that come with the PRTs and used the standard 2 1/2 inch U-bolt muffler clamps. I found the BB ones never tightened enough to keep the mufflers from moving. The U-bolt ones worked great!
Good luck...
Old Jul 15, 2002 | 01:19 AM
Stilcrazee's Avatar
Stilcrazee
When I put BB Rte 66 Quads on an 00, I had to put shims under the hanger to allow it to hang down far enough to the fowl muffler so the quads were straight horizontally. I used 3/16th thick flat washers between the chassis and the top side of hanger. Did use the furnished clamps and air gunned them on, couldn't find 2.5" stainless U's.
To PRT install help
