Frontend noise
Old Feb 6, 2014 | 09:39 PM
Blanco56's Avatar
Blanco56
Default Frontend noise
After checking all areas that were mentioned by forum, my front end is still making a noise like something is loose. Sometime when I turn and when I more forward.
Old Feb 7, 2014 | 10:47 PM
Blanco56's Avatar
Blanco56
Sorry about the lack of info. It's a 2001 C5 that makes a clunk noise when I first drive off and sometimes when I turn. I've checked sway bar, a-arms and shocks but still seem to make noise. I have torqued everything to spec.
Old Feb 10, 2014 | 10:14 AM
Blanco56's Avatar
Blanco56
Originally Posted by 8VETTE7
If the car has the early year plastic sway bar end links, they can be the source of lots of noises. The break down with age as does most plastic. Later year cars got metal end links. Many owners with the plastic ones replace them with the metal ones. If you have metal links a little lube never hurts........
Here are a few threads from the Forum about "clunking steering" that may give you some additional things to check out:
http://forums.corvetteforum.com/c5-t...-steering.html
http://forums.corvetteforum.com/c5-t...ing-clunk.html
http://forums.corvetteforum.com/c5-t...nk-or-pop.html
http://forums.corvetteforum.com/c5-t...ack-fixed.html
Thanks a bunch. Replaced both end links with new ones (moog), torqued to 50 ft-lbs and no more clunk. I'll drive for few weeks and then re-torque. I do have one question, Some say 50ft-lbs and some say 59ft-lbs. What is the true torque on sway-bar end links? and on bushing bracket bolts? Thanks in advance.
Old Feb 10, 2014 | 10:53 AM
CactusCat's Avatar
CactusCat
Blanco56, as you've found, 8Vette7 knows his stuff. We have several extremely knowledgeable users here on CF and you've just ran into one. Glad you got your problem resolved. From the research I did quickly, looks like end link torque is 53 ft/lbs. Good luck with all.
To Frontend noise
