Can't spin my tires?
Old Jul 13, 2002 | 07:43 PM
buzzme's Avatar
buzzme
Default Can't spin my tires?
I can't get the tires to spin on my A-4.
I have tried turning off the active handling and have tried putting it into competitive mode. Still no wheel spin. It seems like the car performs well except that I think it should be able to spin it’s wheels.
The only performance mod that I have is a Blackwing.
Is this normal? Any ideas? What am I doing wrong?
Old Jul 13, 2002 | 07:56 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Can't spin my tires? (buzzme)
The Computer Management program wont let you "burn off the tires" on your automatic... If you get over zealous with a 6 speed it too intrudes on your good time... :(
Maybe some of the A4 Gurus will post here and enlighten you with more tech info as to why that is the case. :yesnod:
vetterdstr :cheers:
Old Jul 13, 2002 | 08:10 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: Can't spin my tires? (vetterdstr)
If you turn off the traction control and AH, you will be able to spin your tires. (If your car is making enough HP)
My guess is that you may have the 2.73 rear in your A4, thus making it tough to spin your tires, even from a stop.
When I had my 2.73s, sometimes I could not even spin them. The solution is more mods... First thing I would do is a gear and converter change at the same time to save on labor costs. The gears will really help and the converter will turn your car into a monster.
You will be able to spin your tires no problem with just those 2 mods (along with a computer program for the gear change).
Hope this helps and go to http://www.converter.cc for some info on torque converters if you are not familiar with them.
Old Jul 13, 2002 | 08:31 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Can't spin my tires? (2000^C5)
turn off TC and AH :D......AND a line lock does wonders :D:D:D
http://forums.corvetteforum.com/zerothread?id=336238
Old Jul 13, 2002 | 08:48 PM
Mitch C's Avatar
Mitch C
Default Re: Can't spin my tires? (Mean Green 2000)
My car had 3.15 gears and I could not spin the tires when I first got my car. I changed the converter and went to 3.42 gears now I can roast the tires at will even from a roll.
98 A4
Poqwerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 gears
:cheers:
[Modified by Mitch C, 6:50 PM 7/13/2002]
Old Jul 13, 2002 | 09:19 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Can't spin my tires? (Mitch C)
in a few days I'lll be posting my one year anniversary in the C5 General section. I will have a video of a take off that might interest you.
If you have a 2.73 rear ratio, you will probably need to powerbrake a little to get the tires to turn over.
Old Jul 13, 2002 | 09:46 PM
robsvette's Avatar
robsvette
Default Re: Can't spin my tires? (Mike Mercury)
ok danielsan! :D when i first got my C5 too with 3:15 gears i could not spin them either. all u need is 3:42 gears and a nice 3000 stall TC and u will burn them up. i wish i had traction NOW!!! was at e-town today spinning out my drags radials all the way through even in second gear. managed one 11.8 with a 1.8 60ft.
don't look forward too much into killing ur $300 plus @ rear tires either :eek:
Old Jul 13, 2002 | 10:33 PM
6spdNavy99's Avatar
6spdNavy99
:yesnod: :yesnod: :yesnod:
Old Jul 13, 2002 | 11:47 PM
buzzme's Avatar
buzzme
Default Re: Can't spin my tires? (6spdNavy99)
Thanks everybody for the relies.
How do I tell what gear I have?
Old Jul 14, 2002 | 03:04 AM
Oh Cool's Avatar
Oh Cool
Check the codes on the Service Parts Identification tag under the rear center hatch cover. Look for Code G90= 3.15 rear. Code for 2.73 rear is GU2. Hope that helps....
Old Jul 14, 2002 | 03:12 AM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
Can't help you here, I'm an MN6 owner!
Old Jul 14, 2002 | 07:42 AM
Mitch C's Avatar
Mitch C
Default Re: Can't spin my tires? (Noggles)
Buzzme, The code for 3.15s is G92 not G90, I am not sure what it is for 2.73s. In 97-98 Vettes check the under side of the cover for the passenger side storage compartment check and see if G92 is among the codes. In later Vettes look inside the glove box for the codes. If you have the use of a lift check the serial # on the rear if it has an " A" in the number it is a 2.73 rear if it has a "C" it is a 3.15 rear if it has a "B" you have hit the jack pot the rear is a 3.42.
:cheers:
[Modified by Mitch C, 5:52 AM 7/14/2002]
Old Jul 14, 2002 | 08:13 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
:yesnod: :yesnod: :yesnod: Yep, I can roast 'em this way...even with my puny .273 gears!!!!
Old Jul 14, 2002 | 11:13 AM
buzzme's Avatar
buzzme
Default Re: Can't spin my tires? (Drop_Top_Dave)
looks like i have 2.73 :U
Old Jul 14, 2002 | 11:28 AM
90 droptop's Avatar
90 droptop
3.42's + SY3500 = tire smoke
Old Jul 14, 2002 | 12:41 PM
robsvette's Avatar
robsvette
Default Re: Can't spin my tires? (90 droptop)
3:73's + vig4000 2.25str = tire melt(1st gear) tire smoke(2nd gear) :yesnod:
Old Jul 14, 2002 | 01:22 PM
Oh Cool's Avatar
Oh Cool
Actually my car has both codes. I don't know why they separate the codes but they're both on my Service ID. According to a 1998 Corvette C5 Production listing that I have the G90 code is for Rear Axle Ratio - 3.15 and G92 is for Rear Axle Ratio - Performance, GU2 is for 2.73, and GU6 is for 3.42 .
To Can't spin my tires?
Old Jul 14, 2002 | 08:18 PM
90 droptop's Avatar
90 droptop
Default Re: Can't spin my tires? (robsvette)
I stand corrected :cheers:
Old Jul 14, 2002 | 08:38 PM
robsvette's Avatar
robsvette
:lol:
Old Jul 14, 2002 | 09:07 PM
NewfieC5's Avatar
NewfieC5
I have 3.15, PL and Vortex. Need to involve the brakes to get the desired effect! Only hear tires at WOT going into second or with downstifts at higher rpms. Look at it this way, you are saving valuable rubber!
:cheers:
