Tire Sensor Errors
Old Jul 13, 2002 | 09:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Tire Sensor Errors
For the first year/20,000 miles, the DIC tire pressure readouts were always the same as my Radio Shack digital TP gauges. The 3 different Radio Shack gauges still agree with each other, but the DIC readings have "drifted". Now, the Radio Shack gauges will show both rear tires at 31.5 psi, but the DIC will show the left rear as 30 and the right rear as 33. The 3 psi difference definitely catches my attention. I tried retraining the sensors using the magnet procedure, but that made no difference. I'm not aware of anything else that can be done except to replace both ensors, and that seems kinda extreme. Any other ideas?
Old Jul 13, 2002 | 10:18 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Tire Sensor Errors (Gearhead Jim)
I've noticed pretty much the same thing for a long time. I now basically just use the DIC numbers as a guide. For accurate readings I use my tire pressure gauge (dial type). It's a whole lot less expensive than four TPS's. :)
[Modified by Tx99FRC, 8:18 PM 7/13/2002]
[Modified by Tx99FRC, 8:19 PM 7/13/2002]
Old Jul 13, 2002 | 10:31 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
that's a tough one jim.
i've noticed with mine, the readings are pretty accurate within the first 10 to 15 minutes of driving. (30psi) if i check the readings between 30 to 60 minutes of driving, they are usually off somewhat. 31psi LF, 29 psi RF. the two rear ones will read 29/29 or 30/30. i don't worry about it as long as i get accurate readings starting out.
Old Jul 14, 2002 | 12:12 AM
H-T's Avatar
H-T
How can I retrain my tire sensors? The car was sitting for a while and now they appear to be dead. Sounds like you have done it.
Old Jul 14, 2002 | 02:58 PM
Gearhead Jim
St. Jude Donor '13
Default Re: Tire Sensor Errors (John Lardner)
John-
You can read (and print out to keep in the car) the reset procedure in the Tech Tips section, C5.
Interestingly, my monitors seem to give their slightly erroneous readings at random, no correlation I can see to tire temp or car motion. Oh well.....
Old Jul 15, 2002 | 11:08 AM
lostsoulny's Avatar
lostsoulny
just checked all mine after leaving the track saturday with a digital gauge and when driving home it seems that the rears read lower on the DIC and the fronts Higher by about 1psi both directions :crazy:
To Tire Sensor Errors
