Climate Control Problem
Old Feb 15, 2014 | 12:13 PM
Doug9C1's Avatar
Doug9C1
Default Climate Control Problem
I just purchased a 98 coupe with 47K miles and have the following issues with the climate control:
- Climate control display is black not just dim.
- I have full heat on all setting.
- AC compressor will not come on, light blinks a couple of times when you push the AC button.
- It will change modes (floor, dash and defrost) but still full heat.
I have searched the forum for solutions but could not find the same issues. thanks in advance.
Doug
Old Feb 15, 2014 | 01:32 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Pull the codes. Check this link
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old Feb 16, 2014 | 01:40 AM
BigGun's Avatar
BigGun
Doug
Got to get the display working to do any work on the system.
Old Feb 16, 2014 | 10:04 AM
dadaroo's Avatar
dadaroo
I am surprised you did not find at least 2 dozen hits on the HVAC display and fix. I had to do that on mine since it was black also, not just dim. Here is one of them I used.
Let us know what your codes are.
Old Feb 16, 2014 | 02:04 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
If compressor not coming on might be low on freon or something wrong with compressor. Pull code to see if compressor issue. Have a pressures checked to see if low on freon.
To Climate Control Problem
