1998 turns over will not start
Old Feb 18, 2014 | 08:57 PM
FL835's Avatar
FL835
2nd Gear
Default 1998 turns over will not start
I am new to the forum but have been reading as much as possible on all the threads. Problem,engine turns over but will not fire. I could cycle the ignition key 4 or 5 times then it would start. Then it would not fire period. Checked all that I could, nothing. Had it towed to Garage after checking found out that the fuel pump relay bad. Replaced it and no problem, starts every time. Thanks to all for the great information in the forum.
Old Feb 19, 2014 | 10:40 PM
Paul Wood's Avatar
Paul Wood
Weak battery. Have it tested. These cars are ultra sensitive to voltage. Goog luck
