Torque Converter ?????
Old Jul 15, 2002 | 12:35 AM
Lynn2008's Avatar
Lynn2008
Default Torque Converter ?????
I drive a 00 verted A4 and I'm about to install a Vig 2800 or yank 3000. I'm wondering something, I know it will send me off the line faster but if I'm going 40 and gun it after the TC is installed will I get to 60 faster or will there be no difference?
Thanks Eric :cheers:
Old Jul 15, 2002 | 02:27 AM
Lynn2008's Avatar
Lynn2008
Default Re: Torque Converter ????? (ericg320)
I can't believe that 11 c5 owners read this and had zero answers. Give me some help here. I'm new to the game.
Thanks again. :cheers:
Old Jul 15, 2002 | 03:17 AM
bparker's Avatar
bparker
In theory - yes you will get to 60 quicker..
Old Jul 15, 2002 | 03:31 AM
JackAttack's Avatar
JackAttack
Default Re: Torque Converter ????? (bparker)
I would say talk to the TC mfrs., they may have at least some empirical data before and after 0-60, 40-100 etc.
Good Luck,
Jack
Old Jul 15, 2002 | 04:47 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Yes, I would guarantee you would get there much quicker! On these So. Cali freeways it is hard to experiment, since they have new white unmarked patrol cars. Reminds me of the days back in the early 90's.
Old Jul 15, 2002 | 08:59 AM
tscales's Avatar
tscales
St. Jude Donor '07
Default Re: Torque Converter ????? (wallstAL)
Hmm, I would have said the difference would be small, if any. Isn't the point of a higher stall to let the engine build to a better point in the HP/TQ curve before applying power to the wheels? At 40, aren't you already closer to that point, so the value of a higher stall is small?
Tom
who has a Vigilante 2800 and never thought about this before.
Old Jul 15, 2002 | 09:35 AM
RWhite's Avatar
RWhite
Default Re: Torque Converter ????? (tscales)
With my 3500 Vigilante, I definitely feel the difference from zero to whatever, and can still feel the difference at a punch although not as dramatic. I admit I do not do a lot of "punch driving" but I say it will definitely help. I think most guys get the mod just for the start to whatever acceleration. I love my Vigilante and now that I have used my LS1_Edit to set the shift points and firmness, it is a blast to drive. Under normal acceleration, you do not know it's there. Best and first mod for the A4’s. Don’t waste time on exhaust, etc. Spend the same amount of money on the converter and install. You will not regret it!
Old Jul 15, 2002 | 09:45 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Depends on how you got to 40. :) If your're just cruising around, you're likely around 15-1600 RPM so it will help, even allowing for the downshift. (One way to look at it is that you don't necessarily have to hammer the throttle.) If your just passing through, you might be at like 6200 or less but climbing if you've just shifted.
The efficiency of the converter begins to matter more if you care about sustained high speed runs.
Old Jul 15, 2002 | 08:53 PM
jw02's Avatar
jw02
Default Re: Torque Converter ????? (RWhite)
RWhite
Debating the torque converter. What are your 60ft times with it installed?
jw02
Old Jul 15, 2002 | 10:22 PM
RWhite's Avatar
RWhite
Default Re: Torque Converter ????? (jw02)
jw02, here are my 60 ft times with the converter (with run flats and with the BFG DR's). We have only gone to the track once with the DR's, but I am impressed with the 1.82 we got the first time. We are going to have to experiment with launch rpm's, but we are having so much fun with the LS1_Edit and EASE that launch techniques will have to wait.
Vigilante 3500 with Run flats: 1.91 to 2.20 (15 runs) 2.08 average
Vigilante 3500 with BFG DR's: 1.82, 1.94, 1.90 sec.
Roger
Old Jul 15, 2002 | 10:41 PM
jw02's Avatar
jw02
RWhite
Thanks for the info. Mines an 02 A4, 3:15, Blackwing, Corsa Indy exhaust, run flats.. Best 60ft of 2.06. FLP Headers and Comp Cam going on Friday.
Sure like the sound of that 1.82 60ft! .25 at 60ft should be .40 at the 1/4.
jw02
Old Jul 15, 2002 | 11:00 PM
y2kredauto's Avatar
y2kredauto
Seat of the pants, this converter is HUGE from launch! What a difference! When down-shifting, though, it actually softens the crisp downshift, making the car not seem as powerful.
From 40, when I punch it, my car is not willing to drop to first, so it feels pretty weak, both before and after putting in the TC. From 35, however, it's another story. The car drops into 1st and launches hard! But again, it did this both before and after the install.
Old Jul 15, 2002 | 11:38 PM
Trevor D.'s Avatar
Trevor D.
Yes, it will help you when punching it from a roll. Sure, the higher stalls will hit harder, but don't forget that they'll put/keep you higher up in the powerband as well. You'll be able to tell a difference (how much will depend on the stall) when going from a roll. As soon as you nail it, the converter will put you higher up in your powerband, so you'll be using more of your power. I'm sure you've experienced the severe lag that you experience when you get stuck in the bottom of a gear from a roll. You won't have that, at least near as bad, with an aftermarket converter.
Both Yank and Precision Ind. make great converters. We carry the Vigilantes at L.G. Motorsports, so call and ask for me at the store if I can help you out.
[Modified by Trevor D., 3:41 AM 7/16/2002]
Old Jul 16, 2002 | 12:24 AM
Chris@SD's Avatar
Chris@SD
If you want, we are going to be insalling a PI conveter in a customers car tomorrow. We should be done late tomorrow or in the early afternoon on Wednesday. I can't guarantee it, but I bet this guy would be willing to take you out for a spin so you can see how it feels first hand. :)
Old Jul 16, 2002 | 08:51 AM
MaxPower's Avatar
MaxPower
Default Re: Torque Converter ????? (Chris@SpeedDemon)
:yesnod: I am pretty sure he would be more than happy to let you take it for a spin and see if you like it.
Old Jul 16, 2002 | 09:46 AM
ToplessTexan
In the spirit of "give 'em an inch and they'll take a mile" :blueangel: if you take these guys up on their offer of a ride, I suggest trying to get a before ride also. That would give you a much better baseline for understanding what exactly changed. It's hard enough sorting out what's attributable to converter vs gears vs tuning. Ideal would be rides before, after install but before tuning, and then after tuning (and again later after tuning has stabilized.)
Old Jul 16, 2002 | 08:59 PM
MaxPower's Avatar
MaxPower
Default Re: Torque Converter ????? (ToplessTexan)
Good point Topless, but I think we could skip the before ride. Just think Honda civic and that will give you a pretty good idea how slow my car is. Hopefully after the converter it will be a little better.
To Torque Converter ?????
Old Jul 16, 2002 | 10:37 PM
AP's Avatar
AP
Default Re: Torque Converter ????? (y2kredauto)
SOTP is great!!!
Old Jul 16, 2002 | 11:28 PM
ToplessTexan
Default Re: Torque Converter ????? (MaxPower)
It can't be that bad. Chris will fix you up.
Old Jul 17, 2002 | 04:59 AM
Lynn2008's Avatar
Lynn2008
No one "technically" answered my question. 40 to 60 quicker or not?
