Dynoed again this weekend: #'s inside
Old Jul 15, 2002 | 11:36 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Dynoed again this weekend: #'s inside
Dynoed my car in Gardena this weekend at R&D Dyno.......pulled a very respectable 379 rwhp/373 rwtq SAE in 93 degree weather and very high humidity. All this with mods in sig - still have stock LS1 heads, a very streetable Thunder 220 cam, full catalytics, and stock tuning :yesnod:
Old Jul 15, 2002 | 11:52 AM
shftn6's Avatar
shftn6
Default Re: Dynoed again this weekend: #'s inside (OliverM5)
Wow, better than my car with Stage II heads, more aggressive cam and no cats.
:cheers:
Old Jul 15, 2002 | 12:27 PM
KDubb's Avatar
KDubb
add tuning and youll be closer to me ;)
Old Jul 15, 2002 | 12:31 PM
OliverM5's Avatar
OliverM5
Default Re: Dynoed again this weekend: #'s inside (KDubb)
I'd say the 19 hp difference between our cars is due to your better flowing LS6 heads...........
Old Jul 15, 2002 | 01:00 PM
O-Ace's Avatar
O-Ace
Default Re: Dynoed again this weekend: #'s inside (shftn6)
:cheers:
Old Jul 15, 2002 | 02:33 PM
Miles in Michigan's Avatar
Miles in Michigan
Awesome results.
Do you ever have to play around with the MAFT, or does the tuning seem to 'stick' since it was first adjusted? Did they take air fuel ratios, by any chance?
Old Jul 15, 2002 | 02:39 PM
OliverM5's Avatar
OliverM5
Default Re: Dynoed again this weekend: #'s inside (Miles in Michigan)
Tuning has stuck since I autotapped and adjusted the MAFT.....my O2's were reading about .89
Old Jul 15, 2002 | 02:48 PM
MyFirst's Avatar
MyFirst
Any idea what the ASP pulley was worth? Which one did you go with. The three pulley set, or the two pulley set?
Old Jul 15, 2002 | 02:53 PM
OliverM5's Avatar
OliverM5
Default Re: Dynoed again this weekend: #'s inside (MyFirst)
One main pulley........
Old Jul 15, 2002 | 02:55 PM
RHILL's Avatar
RHILL
Nice seeing you again at R & D ....... I agree yours was one of the best running C5 I've seen todate :yesnod: :cool: :cheers:
Old Jul 15, 2002 | 02:57 PM
Vette-Racer's Avatar
Vette-Racer
Wow very impressive :eek: must be a strong motor :cheers:
Old Jul 15, 2002 | 03:12 PM
MyFirst's Avatar
MyFirst
Default Re: Dynoed again this weekend: #'s inside (Vette-Racer)
Thanks for the info, but do you know how much hp/trq the main crnak pulley was worth?
Old Jul 15, 2002 | 03:25 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
I beleive you add about 50 to 60 HP if you measure at the Crank.
Old Jul 16, 2002 | 12:37 AM
Chris@SD's Avatar
Chris@SD
Default Re: Dynoed again this weekend: #'s inside (pjazz)
:rolleyes: :rolleyes:
Oliver,
Not bad, when can I set you up with a set of heads? :eek: :D :eek:
[Modified by Chris@SpeedDemon, 10:38 PM 7/15/2002]
To Dynoed again this weekend: #'s inside
