Fooling the Low Washer Fluid sensor
Old Mar 1, 2014 | 11:07 PM
Dcollins3208's Avatar
Dcollins3208
Default Fooling the Low Washer Fluid sensor
Does anyone know of a way to set the low washer fluid message to not go off? Tank has a leak at the gasket where the pump goes into the tank and I don't care to fix it as I never use washer fluid anyways. Or, I guess if anyone has a washer tank gasket lying around or if you know where I can get one ill fix it
Old Mar 1, 2014 | 11:15 PM
4DRUSH's Avatar
4DRUSH
Try unplugging the sensor or remove it & tape it straight
Old Mar 2, 2014 | 02:11 AM
racebum's Avatar
racebum
you know what i did? ordered a new one from amazon
this sensor comes with a new gasket and is less than 20 dollars
16.63 to be exact
Amazon.com: ACDelco D6332E Windshield Washer Solvent Level Switch Kit: Automotive Amazon.com: ACDelco D6332E Windshield Washer Solvent Level Switch Kit: Automotive
Old Mar 2, 2014 | 03:08 AM
LoneStarFRC's Avatar
LoneStarFRC
GM 22039457 Grommet
Old Mar 2, 2014 | 10:18 AM
Dcollins3208
Originally Posted by LoneStarFRC
GM 22039457 Grommet
Exactly what I was looking for thanks!
Old Mar 2, 2014 | 10:14 PM
racebum's Avatar
racebum
except that damn grommet via gm is half the cost or more of the entire ac delco replacement. i swear the old scaled over sensors are more likely to cause that annoying message on the DIC
Old Mar 2, 2014 | 10:27 PM
LoneStarFRC
Grommet LIST price is $1.65 ea
Which ACD replacement are you speaking of? The pump? It sells for $16-$18(~).
Also, he said his tank is leaking because of the grommet. Leak = low fluid level, hence the warning message.
Old Mar 3, 2014 | 02:40 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Rotate the sensor 180 degrees. Then the float can't fall to show low level.
Old Mar 3, 2014 | 09:12 PM
lionelhutz's Avatar
lionelhutz
Odd, I read that it's leaking around the pump with 2 or 3 replies to fix the leak around the level sensor????
Yes, either try unplugging the sensor or turning it over.
Old Mar 3, 2014 | 11:19 PM
Dcollins3208
Originally Posted by lionelhutz
Odd, I read that it's leaking around the pump with 2 or 3 replies to fix the leak around the level sensor???? Yes, either try unplugging the sensor or turning it over.
You are correct that I was talking about leaking around the pump (from grommet that pump goes in to) and NOT at the sensor. I've ordered a grommet as suggested above that should solve this issue, hopefully!
Old Mar 4, 2014 | 09:35 PM
Sox-Fan's Avatar
Sox-Fan
if you unplug the sensor until you get the grommet it'll stop annoying you until you can fix it.
To Fooling the Low Washer Fluid sensor
