My car is currently at my tuner/builder waiting to have my freshly done TSP stage 1 ls6 heads installed along with injectors. I have long tubes, tsp 233/239 cam and normal bolt ons. I also have an ls6 intake manifold with home polished tb. The car made 408 rwhp with stock 853 heads and the ls6 manifold. How much am I leaving on the table by not switching to a fast intake? Should I wait until I get the fast intake (which I can't afford at this time) or should I See decent gains even with the ls6 intake? Is it worth only doing heads at this time?
Maybe 20rwhp. In a $/hp analysis, not worth it at all. However, if you don't mind the cost then go for it. You'd gain even more on the FAST if you ported it
Mike i gained 23 rwhp just adding the fast 92 and ls2 throttle body.non ported yet,im porting it next week then going back up and seeing what i gained.
Did you gain the 23 going from LS6 intake to a fast? Or LS1 to fast?
from a ls6 i might have the old dyno vid let me look
couldnt find the 422 but heres 419 and it says ported throttle body but it was a new out of the box non ported.ive made more changes since then so cant wait to see what it puts down now.42lb injectors,heads milled again and comp. valve job,porting intake and throttle body.
