I don't know how to look this up because I don't know what the part is called. I don't recognize it on a schematic of the front suspension on the C5 but I'm probably missing it.
I had my car lowered awhile back and put it back up the other day. Under the adjustment stud/bolt is what I'd call a stop plate/rubber stop that was badly deformed. It appears to have two circular metal plates about the size of a 50ct piece engulfed in rubber which also sandwiches the plates.
Here is a link to the page where I think it lives:
It's not available. All you can do is either get a piece of rubber and stick it in there or buy aftermarket lowering bolts. Bad part is the bushings parts on the aftermarket lowering bolts don't last long either.
I doubt anything lasts too long as they are compressed anyway. Is there a problem with using nothing? I worry it will hit the lower control arm and eventually crack or fracture it. Is that something to consider? Is there anything say like a piece of sidewall that can be or should be used?
The steel end of the bolt will rub against the a-arm and you get loud squeaks when you go over bumps. Any piece of rubber in between will fix it. I've never seen a bushing sold to go over the end of that bolt.
It's not a bump stop. That bolt in the spring pushing down on the a-arm is what holds the front of the car up. So, no chance it will hit the arm since it's always pressing on the arm.
You're right. Not a bump stop because the car rides on it and compresses it. I suppose a piece of sidewall will do. They make aftermarket stuff like Eibach. The problem is you have to do a little disassembly and I'd prefer not to dismount the wheels. You can't buy just the bushing but the entire kit. I think I'll look into putting a bit of rubber under it. Thanks.
