Royal Purple ?????
Old Mar 8, 2014 | 08:35 AM
Pumba's Avatar
Pumba
Originally Posted by leadfoot4
FWIW, I put some 0W-40 Castrol Edge in my car just before I put it away for the winter. I like to start the car 2-3 times during the winter, just to circulate the oil, wet the seals, etc, and thought the "0" would circulate quicker in the colder temps. I put the oil in, fired up the engine to take the car for one last ride, and the engine was "noisier"....like more lifter clatter. I was dumbfounded.
As much as I hated to do it, I dumped $50 worth of oil, and refilled the car with Pennzoil Ultra, an oil I had used a couple of years ago, when I got 6 quarts of it for free, and was impressed on how it seemed to quiet the engine's "sewing machine" sound. And yes, after dumping the 0W-40, and refilling with 5W-30, the engine returned to it's normally quiet state....
Several years ago Mobil sued Castrol over Castrol's use of the word synthetic. Mobil stated in their suit that Castrol was not a true synthetic oil. The judge deciding the case ruled in favor of Castrol. In his opinion he stated that Castrol could use the word synthetic if they wanted, even though their oil was not a true synthetic.
Notice that I did not list Castrol.
Old Mar 8, 2014 | 09:46 AM
C5Natie's Avatar
C5Natie
Mobil is not a true synthetic either, it's group III base oil. The true ssynthetics I know of are Redline and Amsoil. These are group IV and V base ester oils. Still a high quality group III will get the job down. Btw this definition of synthetic only applies in the US. In Europe it must be a group IV or V to be labeled synthetic.
Old Mar 8, 2014 | 02:02 PM
strand rider's Avatar
strand rider
I wanted to thank c66 racing for adding some facts to the discussion. Obviously, experience and knowledge is a powerful combination.
I wish the subject of oil cooling in use of the engine could be explored with different oils. More engines failures are from cooling than lubrication system failures, I know I am overlapping functions between systems, making the question difficult to answer, but that is the situation in actual use.
Not trying to hang on to what might seem a small point for personal validation, just trying to get a better understanding , working towards a better selection in street use.
When I called the Mobil 1 helpline ,long ago, I asked about the zero viscosity oil that had just hit the stores. They advised it had no benefits outside of Arctic service
Old Mar 8, 2014 | 06:50 PM
LSOHOLIC's Avatar
LSOHOLIC
MOTOR OIL “WEAR PROTECTION” RANKING LIST
by 540RAT
With over 22,000 “views” worldwide!!
(Information last updated on 2-20-14)
Before we get into motor oil tech, let’s briefly touch on a little background info. I’m a working Professional Degreed Engineer, as well as a U.S. Patent holder. Engineering is what I do for a living. But, as you will see below, the following write-up is not intended to be a chapter out of an Engineering textbook. And the intended audience is not other Engineers. There are no formulas, equations, charts or graphs. The intended audience is Automotive Enthusiasts, Gearheads, Hotrodders, Racers and Engine builders. So, it is written in normal everyday spoken language, rather than overly technical jargon. That way, it will be the easiest to follow and understand by the widest possible audience.
THE SINGLE MOST IMPORTANT thing a motor oil does for your engine, is prevent wear. Everything else it does for your engine, comes AFTER that. But, I have found that there is a tremendous amount of misinformation and misunderstanding about motor oil. The worst of all is that a lot of people, even those at Cam Companies, blindly accept the MYTH about needing high levels of zinc in motor oil in order to have sufficient wear protection. But, that line of thinking is NOT based on technical fact, and is simply FALSE. So, at the beginning of 2012, I began Tribology Research using motor oil “Wear Testing” equipment, to explore the facts regarding the wear prevention capabilities of motor oil. For those not familiar with the terminology, Tribology means the study of friction, lubrication, and wear between moving surfaces.
I’m a total perfectionist when it comes to technical issues. And those who know me personally, know that I would never jeopardize my reputation or my integrity, by posting test data that would turn the Hobby/Industry on its ear, unless I was absolutely sure about the data I put out there. Of course I’ve always known my carefully generated data is completely accurate. And to make that clear to world, you will see below that my test data exactly aligns with real world Race Track experience.
OIL TEST DATA AND RACE TRACK EXPERIENCE ARE IDENTICAL
An oval track dirt racer (his class is extremely competitive, so he asked that his name be left out) on the SpeedTalk Forum runs a 7200 rpm, solid flat tappet, 358ci Small Block Chevy motor, with valve spring pressures of about 160 on the seat and 400 open, that are shimmed to .060” from coil bind. The rules and the combination of parts, were causing him to experience repeated cam failures while using high zinc, semi-synthetic 10W30 Brad Penn, Penn Grade 1 motor oil. Lab Report Data from testing performed by Professional Lab, “ALS Tribology” in Sparks, Nevada, showed that this oil contains 1557 ppm zinc, 1651 ppm phosphorus, and 3 ppm moly. In spite of this being a high zinc oil, that most folks would “assume” provides excellent wear protection, he experienced wiped lobe cam failure about every 22 to 25 races.
A race consists of one 8 lap (a lap is typically 3/8 mile) heat race and one 20 lap feature race, plus any caution laps. If you add it all up, 25 races only total about 281 miles at the point of cam failure. So, that is a perfect example of what I’ve been saying all along about high zinc levels being absolutely NO GUARANTEE of adequate wear protection. And my test data on this 10W30 Brad Penn, Penn Grade 1 motor oil, shows that it produces a wear protection capability of only 71,206 psi, which puts it in the MODEST wear protection category, and it ranks a very disappointing 96th out of 129 oils tested so far. That means of course that there are 95 different oils I’ve tested that provide better wear protection.
So, my test data ACCURATELY PREDICTED EXACTLY what he experienced during racing. And that is, that this oil does not provide high enough wear protection capability to provide a sufficient margin of safety for this engine’s operating conditions. Looking at my “Wear Protection Ranking List” and choosing a much higher ranked oil, would have prevented all those cam failures. Repeatedly suffering cam failures in motors with so little time on them, may have been considered by some folks to be a normal consumption of parts back in the ‘60’s or ‘70’s. But, in the 21st Century that we live in now, by any measure, that is for sure premature failure. We no longer have to accept that as the cost of doing business, because we can do far better now.
So, he switched to the super micro polished billet lifters from PPPC and the cam life went up to 40 races, which was an improvement since he could now go 450 miles between failures. But, that was still clearly unacceptable. Then 2 years ago he started using “Oil Extreme Concentrate” as an additive to the 10W30 Brad Penn, and he’s never lost a lobe on a cam since. Adding the “Oil Extreme Concentrate” completely eliminated his premature wiped lobe cam failures. Now the motor has now gone 70+ Races without issue, and is still doing fine. This “Oil Extreme Concentrate” is one additive that actually works as advertised, and makes low ranked oils far better than they were to begin with. And that is PRECISELY WHAT MY MOTOR OIL TEST DATA PREDICTED as well.
Here’s how. I also added “Oil Extreme Concentrate” to 10W30 Brad Penn, Penn Grade 1 semi-synthetic, as part of my motor oil “Dynamic Wear Testing Under Load” research. And with 2.0 OZ of “Oil Extreme Concentrate” added per qt, which is the amount intended for racing, its wear protection capability shot up by a BREATH TAKING 56%, to an amazing 111,061psi, which puts it in the INCREDIBLE wear protection category, and now ranks it a jaw dropping 5th out of 129 oils tested so far. So, it moved up a whopping 91 ranking positions, just by adding the “Oil Extreme Concentrate”. This totally accounts for the reason all his cam lobe failures were eliminated.
In addition to this, a NASCAR team sent me three high zinc synthetic Mobil 1 Racing Oils for testing. Because they were having wear problems when using these oils (more on that below). Lab Report Data from testing performed on these oils by Professional Lab, “ALS Tribology” in Sparks, Nevada, showed that on average, these oils contained 1774 ppm zinc, 1658 ppm phosphorus, and 1444 ppm moly. And because these were all high zinc oils, most folks would “assume” that they’d provide sufficient wear protection. However, the results of my testing showed that these oils only provided POOR WEAR PROTECTION CAPABILITY. So, they were NOT a good choice for their racing application, which confirmed why they had wear problems. This is yet another perfect example of what I’ve been saying about high zinc levels being NO GUARENTEE of adequate wear protection. And this example clearly showed once again that my test data EXACTLY MATCHED what this race team had experienced on the track.
So, these examples PROVE once and for all, that my test data EXACTLY MATCHES REAL WORLD RACE TRACK EXPERIENCE, and that my test data is the spot on REAL DEAL, just as I’ve said all along. This completely confirms that my test results WILL ACCURATELY PREDICT what we can expect from motor oils in running engines on the track or on the street, EVEN if those oils are high zinc oils. So, that should be more than enough proof to satisfy anyone who was skeptical of how well my test data compares to the real world. And if anyone thinks my data comes from flawed methodology, they are not paying attention, and need to reread everything again more carefully.
Not only does my oil testing methodology and the resulting data match up exactly with real world Race Track experience, but it has also been endorsed by the following well respected sources:
1. An Engineering Ph.D. who is the most highly respected Engineer, Car builder and Tech Guru on a popular Automotive Forum, asked me if he could include my Oil Testing Info in a list of Tech Papers written by well respected Industry authors, that he makes available to enthusiasts. And he told me, “I’m 100% on board with backing you with my endorsement on your testing: I run a Propulsion Testing Laboratory for a major Aerospace Company, so I’m in the testing business. Your methods and approach are in accordance with sound engineering testing methods, and are not arguable by intelligent people”. He also said this about my Oil Testing info, “This is excellent stuff, and I’ve already sent copies of this to my engineering colleagues”.
Then later, even though he had no direct connection to my oil testing, he received hate mail and threats for backing me. This behavior came from disrespectful people who are on the wrong side of the facts. They are high zinc level “believers”, even though the facts have proven over and over again that the whole idea of depending on high zinc levels for wear protection, is only an outdated myth. Sadly, discussing motor oil can become emotionally charged just like Religion and Politics. But, Engineering test data is NOT determined by emotion, it is determined by the facts that come out of the Physics and Chemistry involved. After this ordeal, he’d had enough, and asked that I no longer use his name in connection with my oil testing. Of course I respect his wishes and will no longer mention his name here. I feel bad that he was subjected to this totally uncalled for behavior. However, these shameful events will have no affect on my ongoing oil testing. For me, there is no emotion involved with the oil testing I perform. I simply report the results exactly the way they came out, good or bad.
2. A NASCAR engine supplier out of North Carolina (they did not want their name associated with any Internet motor oil arguments that may come up, so they asked that their name be left out, which I honored) was so impressed with the motor oil “Wear Protection Capability Testing” I perform, that they sent me 3 NASCAR Racing Oils they use, for testing. They valued my testing efforts enough to include me in what they do, which is quite an endorsement, considering the Professional level of Racing they are involved in. They had been seeing some wear issues with those oils, and wanted to see if I could shed any light on that by testing them. I did test those oils for them, and the test results showed that those oils did not provide acceptable wear protection capability, which accounted for the wear problems they were having. So, they have selected other oils to use, and their wear problems have gone away. If I had tested those oils before they started using them, I could have saved them time, money and grief.
3. The “Oil Extreme” Oil Company was so impressed with the detail and accuracy of my oil testing, that they wanted to hire me to perform product development research testing for them. That was clearly a major endorsement of the testing I perform. But, I declined taking any money from them, because I won’t be tied to any Oil Company by money. That way I can maintain my independent and unbiased status. I report the test results just how they come out, good or bad. And there is no way I’d allow any Oil Company to influence anything I report. I did however, agree to perform testing for them for free, along with other testing I perform. And those results will be posted along with other test results.
In addition to that, my oil test data has also been validated and backed-up by a total of FOUR other independent Industry sources. They are as follows:
1. Well known and respected Engineer and Tech Author David Vizard, whose own test data, largely based on real world engine dyno testing, has concluded that more zinc in motor oil can be damaging, more zinc does NOT provide today’s best wear protection, and that using zinc as the primary anti-wear component, is outdated technology.
2. The GM Oil Report titled, “Oil Myths from GM Techlink”, concluded that high levels of zinc are damaging and that more zinc does NOT provide more wear protection.
3. A motor oil research article written by Ed Hackett titled, “More than you ever wanted to know about Motor Oil”, concluded that more zinc does NOT provide more wear protection, it only provides longer wear protection.
4. This from the Brad Penn Oil Company:
There is such a thing as too much ZDDP. ZDDP is surface aggressive, and too much can be a detriment. ZDDP fights for the surface, blocking other additive performance. Acids generated due to excessive ZDDP contact will “tie-up” detergents thus encouraging corrosive wear. ZDDP effectiveness plateaus, more does NOT translate into more protection. Only so much is utilized. We don’t need to saturate our oil with ZDDP.
Those who are familiar with my test data, know that my test results came up with the exact same results stated by all four of those independent sources. So, this is an example where motor oil “Dynamic Wear Testing Under Load” using oil testing equipment, engine dyno testing, Motor Oil Industry testing, and proper motor oil research using only the facts, from a total of five (including my own) independent sources, all converged to agree and come to the same exact conclusion. Back-up validation proof, doesn’t get any better than this.
So, with all those sources in total agreement, that should provide more than enough proof to anyone, that my data is absolutely correct, and that it DOES NOT come from flawed methodology, as some have said simply because they didn’t like or didn’t understand the results. The fact is, scientific test data is not determined by emotion, it is determined by the facts that are a result of the Physics and Chemistry involved. And anyone questioning any one of those sources, questions them all, as well as the Physics and Chemistry that determined all those identical results. And no sensible person would try to argue against Physics and Chemistry. Because that is a battle no man can win.
Of course, many folks, including Enthusiasts, Hotrodders, Racers, Builders, Cam Companies, etc, have always been conditioned to believe that high zinc levels in motor oil are a must for sufficient wear protection in High Performance engines. And of course there are a number of oils available that say something along the lines of “Extra Zinc for Extra Protection”. So, a lot of those folks just cannot bring themselves to accept the fact that high zinc levels are NOT what they are cracked up to be. They feel compelled to believe the claims on those bottles of oil and the Marketing/Advertising claims made by the Oil Companies that provide those high zinc oils.
But, people need to consider the following. Those Oil Companies are in business to make money. That’s it. So, they put a product on the market that they feel there is a demand for, and will make them money. As a result, they will say “ABSOLUTELY ANYTHING”, to move that product, which will help their bottom line. So, high zinc loving people need to stop and consider that for a moment. The Oil Companies have a vested interest in telling people what they want to hear, so they will buy their oil. Misleading claims and false advertising are as old as the exchange of money. And every person alive has seen false advertising many, many times in their life.
Oil Company claims about the benefit of high zinc levels in motor oil, only amounts to false advertising, because that is NOT based on actual fact. Extra zinc cannot physically provide extra wear protection, because zinc simply DOES NOT work that way. Zinc is used up a little at a time as it is sacrificed to help protect against wear. More zinc will take longer to become depleted, simply because there is more there to use up. It’s the same idea as more gas in your tank will take longer to run out, but more gas in your tank cannot physically make more HP.
These high zinc motor oil producing Oil Companies NEVER provide any test data to prove that their high zinc oils provide better wear protection than ordinary modern street oils do. They can’t do it, because it’s NOT TRUE. So, high zinc believers are only embracing smoke and mirrors, nothing else. And the actual test results referenced above, PROVE that the need for high zinc levels is simply NOT TRUE. That is why I started testing motor oil, so that I could separate the facts from the fiction.
Motor Oil Company Advertising claims are only hype and hot air, but actual test data is the real thing. If I test a modern low zinc API certified oil against a high zinc oil, and the modern API certified low zinc oil clearly outperforms the high zinc oil in terms of wear protection, how can the high zinc lovers honestly believe that the high zinc oil is better? How could that high zinc oil magically perform better in an engine, when it was worse in testing? And if I test two high zinc oils, and one does well and one does not, how can the high zinc lovers believe that all high zinc oils are always good?
So, high zinc lovers need to do a little soul searching and ask themselves why they want to believe something that does NOT stand-up to real world testing? Keep in mind that testing is so important and valuable, that multi-million dollar corporate decisions are made, based on test data. Not only that, but Racers test engine and chassis setups at the track all the time. And they believe what the test results tell them, because that’s the only way they have to know what really works and what doesn’t. So, it makes no sense to disregard oil testing, when virtually all other types of testing are taken as Gospel.
It’s been said that I’m the motor oil Police, because I discover and expose false motor oil claims and misleading motor oil advertising, with my test results that show the FACTS. I don’t sell motor oil, so it doesn’t make any difference to me, what oil people choose to run. But, people need to understand that some high zinc oils provide good wear protection, while many high zinc oils do not. And without looking at the test data, you cannot tell which is which, until perhaps it’s too late. In fact, MANY WIPED FLAT TAPPET LOBES COULD HAVE BEEN AVOIDED, INCLUDING DURING BREAK-IN, if people had not blindly believed that all high zinc oils provide all the wear protection they need. Because nothing could be further from the truth.
So, the folks who choose to use only high zinc oils NO MATTER WHAT the test result FACTS show us, are only fooling themselves. Of course everyone is entitled to their own opinion. But, ignoring the FACTS is their loss, and depending on the particular oil they choose, they are likely NOT getting the wear protection they THINK they are. If you value your engine, wouldn’t you prefer to choose the motor oil that can REALLY provide the best wear protection, based on test data FACTS, rather than the old incorrect high zinc MYTH? Don’t believe what the high zinc lovers say, because they are only trying to justify what they “believe”, even though they have NO PROOF what so ever, to backup what they say. On the other hand, I backup everything I say. So, read the FACTS, then make your own decision.
I was very dissatisfied with the ASTM test procedures I reviewed. Some called for testing at 100*F (NOT 100*C), which is too COLD and is therefore NOT realistic for oil in a running engine. An ideal oil sump temperature range in a running engine is between 215*F and 250*F, though oil temps are not entirely uniform throughout the engine (more on that below). This range is hot enough to quickly boil off normal condensation rather than letting it evaporate over time, which can allow it to dilute the oil. And this range is also low enough to provide sufficient cooling for internal components, all of which are directly oil cooled, while at the same time staying below the onset of thermal breakdown in nearly all motor oils. Other ASTM tests called for testing at 150*C (302*F), which is too HOT and therefore also NOT realistic. Because every oil I’ve ever tested for the onset of thermal breakdown, would already be at or beyond the threshold of thermal breakdown at 302*F.
So, the Official ASTM test procedures I reviewed for my application, were basically worthless for finding out the truth when it comes to wear protection capability of motor oil at realistic temperatures. Being a perfectionist, I was not willing to accept sub-par test procedures. So, I developed my own test procedure at a realistic 230*F, that works extremely well with my test equipment, and produces accurate and repeatable results which are essential for meaningful comparisons between different motor oils. My test procedure produces the most realistic and useful data available anywhere, which is why I have all those endorsements and validation back-ups, as well as race track data that exactly matches my test data. BOTTOM LINE: My test data WILL ACCURATELY PREDICT what we can expect from a motor oil in a running engine.
As mentioned above, motor oil is not the same temperature everywhere inside a running engine. Typical main bearing oil temps can be 55*-90*F higher than sump temps. However, main bearing oil under running conditions is not just a film of oil, it is a liquid wedge of flowing oil (that is why the cooling benefits of better flowing thinner oil are important here to avoid driving up bearing temps. See the section on viscosity selection immediately following my “Wear Protection Ranking List” below). Liquid oil is not compressible, therefore it completely prevents metal to metal contact (more on that below). My testing focuses on oil film strength, which is what is critical, and is the last defense against metal to metal contact. Even so, I also tested a dozen different oils at 275*F to see how their wear protection capability at that higher temp, compared to the 230*F that I normally test at.
The oils tested at 275*F consisted of different brands, different viscosities, some low zinc modern API certified oils, some high zinc Racing/Performance oils, some synthetic, some conventional, some semi-synthetic, some with low levels of detergent and some with high levels of detergent. As expected, the wear protection capability psi values dropped as the oils got hotter and thinner. But for most of the oils, the drop was not enormous. And the average psi drop for the whole group of oils, was only about 12% from their 230* values. What was also of interest here, was how the ranking of these dozen oils might change relative to each other, as they got hotter. The result was that there was some shuffling of the ranking order within the top 10 oils, but all of the top ten oils were still in the top 10.
It was also quite clear by looking at these results, that high zinc levels, high detergent levels, and heavy viscosities did NOT play any particular roll in how well a motor oil does or does not provide wear protection. The only thing that matters is the base oil and its additive package “as a whole”, with the primary emphasis being on the additive package, since the additive package is what contains the extreme pressure anti-wear components.
In addition to the testing at 275*F, I also tested a couple of those oils at a much higher 325*F to see how their wear protection capability might change at that temp. It turned out that their load carrying capacity leveled off and stayed approximately the same between 275* and 325*, and their ranking relative to each other did not change. So, it is comforting to know that you don’t run into dangerously low wear protection if and when you end up with overheated oil at some point. But of course the oil will have already run into thermal breakdown and should be changed as soon as possible.
So, all this testing showed that the oil ranking positions did not change significantly even at higher temps. And that means that my “Wear Protection Ranking List” below, which was generated with oil temps at 230*F, is still representative of how the various oils compare to each other, even at the higher operating temperatures seen in certain locations of the engine.
The test procedure I use is a rubbing friction test under load, which generates a wear scar on a test specimen that is bathed in the oil being tested. The result is “pounds” of force being applied over the wear scar “area”, which is in square inches. Or in other words, pounds per square inch, which of course is just shortened to “psi”. The better an oil’s wear protection capability, the smaller the wear scar will be on the test specimen, and the higher the resulting psi value will be.
The motor oil “Dynamic Wear Testing Under Load” I performed to generate my “Wear Protection Ranking List”, is worst case torture testing, using oil testing equipment that is for the record, NOT a “One Armed Bandit” tester. My testing subjects the oil to far more severe loading than even the most wicked flat tappet race engine ever could. So, since my oil testing compares various oils under worst case conditions, absolutely no further testing is required in a running engine. If oils rank higher in my “Wear Protection Ranking List” than the oil you currently use, those higher ranked oils will provide a HIGHER LEVEL OF WEAR PROTECTION than your current oil. It’s really that simple.
My test equipment is NOT intended to duplicate an engine’s internal components. On the contrary, the test equipment is specifically designed to cause an oil to reach its failure point, in order to determine what its capability limit it is. And every oil I test is brought to its failure point, that’s how it works. The difference in the failure points, is what we compare. And in addition to that, my equipment’s calibration is checked and adjusted if required, each time the testing switches to a different oil. That keeps the final results accurate at all times.
You will NOT find this many oils tested on the exact same equipment, using the exact same procedure, using the exact same real world representative operating oil temperature, by the exact same operator, anywhere else. Therefore, this is the best apples to apples motor oil comparison you will ever find.
But, a running engine is designed to last indefinitely, and of course, they do not generally cause an oil to reach its failure point. So, due to the complete difference in design, the pressures in my test are completely different, and cannot be compared directly to an engine’s lobe/lifter interface pressure. That would be comparing apples to oranges, which makes no sense. My testing is so severe, that the oil fails at an earlier point. And that is why my test data psi values may appear lower than you might expect to see in some running engines. Keep in mind, I’m comparing OIL AGAINST OIL, and the procedure used is exactly the same for each oil tested. For better or worse, each oil stands on its own merit. And if oil A produces twice the psi value of oil B in my testing, then oil A will also offer twice the wear protection capability of oil B, in a running engine.
The “dynamic wear testing under load” I use, is intentionally designed to find the SPECIFIC LIMIT of each individual oil’s “Load carrying capacity/film strength”, at a representative operational temperature of 230*F. Or in other words, to determine each oil’s “wear protection capability” psi value, which can be compared to any other oil tested on the same equipment. The results that come out of my testing are NOT my opinion, and they are NOT my theory. They are the FACTS that come out of the Physics and Chemistry involved in the tests.
Performing “dynamic wear testing under load”, is the ONLY TYPE OF TESTING that will provide accurate data regarding an oil’s film strength. Dynamically testing motor oil under load, is the same concept as dynamically testing an engine under load on a dyno. That is the only way to truly find accurate performance data of a motor oil, or of an engine.
And obtaining accurate oil film strength data is ABSOLUTELY THE ONLY WAY to determine an oil’s wear protection capability, because an oil’s film strength is the last line of defense against metal to metal contact. In order to reach metal to metal contact, and subsequent wear or damage, you MUST penetrate the film strength of the oil. And oil thicker than a mere film becomes liquid oil. Of course liquids are NOT compressible, which is how hydraulics work. Since liquids cannot be compressed, ALL oils provide THE SAME wear protection when they are in liquid form, no matter if they cost $1.00 per quart or $20.00 per quart. So, oil film strength testing is the GOLD STANDARD for determining how capable an oil is at preventing wear, and how different oils directly compare to each other. In other words, the ONLY THING that separates one oil’s ability to prevent wear from another oil’s ability to prevent wear, is the difference in their individual film strength capabilities.
But, testing motor oil in a running engine CANNOT determine the EXACT SPECIFIC wear protection LIMIT of an oil, which is necessary, in order to make an accurate comparison between various oils. So, attempting to test various motor oils for comparison in a running engine, provides no meaningful data, other than perhaps that a given oil did not cause a failure in that particular engine combo. If you were to test say a half a dozen different oils in your engine combo, and you had no problems with any of them, how can you tell how they rank against each other? It’s a proven fact that all oils do not provide the same wear protection capability. That means you have no way of knowing which of those 6 oils provides you with the highest level of protection. Therefore, motor oil testing in a running engine, is a waste of time, effort and money, when it comes to gathering accurate data for comparison between various oils. And that is precisely why I perform all my testing with motor oil test equipment, rather than in an engine
And simply looking at an oil’s zinc level on its Lab Report is of no value at all, because some high zinc oils provide excellent wear protection, while other high zinc oils only provide poor wear protection. And you have no way to tell which is which by looking at the zinc level alone. An oil’s wear protection capability is determined by its base oil and its additive package “as a whole”, and NOT just by how much zinc is present.
The old claim that you must have a high level of zinc for a high level of protection, is only a MYTH that has been BUSTED. And no one anywhere, can provide any real world test data proving that high zinc levels will always protect your engine. Because zinc simply does NOT work that way, no matter what you’ve read and heard a million times. More zinc simply takes longer to be depleted as it is sacrificed and used up while helping protect heavily loaded parts. Therefore, more zinc provides “longer” wear protection, NOT “more” wear protection. So, if someone tells you that you must have a high level of zinc for sufficient wear protection, no matter who they are, or no matter what Company they may represent, DO NOT believe it. Because they are proving that they DO NOT understand how zinc really works, and are only repeating the same old wives’ tale with absolutely NOTHING to back it up.
And ZDDP DOES NOT build up on parts like some sort of plating process. ZDDP simply DOES NOT work that way. ZDDP that is present in the oil, is activated by heat and pressure, which is precisely what the oil is subjected to during my oil testing procedure. My testing DOES NOT discount ZDDP levels either. ZDDP is part of the additive package, and the additive package is what contains the extreme pressure anti-wear components. You cannot test oil film strength without also automatically testing the ZDDP included in that oil at the same time. Since ZDDP is an integral part of an oil’s additive package, and the additive package is primarily what creates an oil’s film strength, the ZDDP that is present, will be working as well as its chemical composition allows, during any film strength testing.
I’ve also “wear tested” a handful of used oils, both synthetic and conventional, that had 5,000 miles on them. And in every case, there was NO REDUCTION what so ever, in wear protection capability, even though the zinc levels had dropped by around 25% on average. So, this is even further proof that the zinc level is not tied to a motor oil’s wear protection capability.
Most major oil companies say to NEVER EVER add anything to their oils, because doing so will upset the oil’s carefully balanced additive package that was designed by their Chemical Engineers. I tested doing that very thing in several different oils, and found that adding zinc additives in every case, ruined the oils by SIGNIFICANTLY REDUCING their wear protection capability. That of course, is just the opposite of what people “think” they will be getting. So, those major oil Companies were absolutely correct about not adding anything to their oil. And people who insist on choosing an oil based on zinc level alone, are very likely shooting themselves in the foot, and ending up with far LESS wear protection than they THINK they have. It just depends on which particular oil they select. A number of popular traditional high zinc oils have proven to provide poor wear protection when actually put to the test.
In order for people to choose an oil that truly provides the best possible wear protection for their engine, they need to select an oil based on its “wear protection capability”, NOT its “zinc level”. Modern API certified oils have reduced zinc/phosphorus levels, and that now absent quantity of zinc/phosphorus has been replaced with alternate anti-wear components that are equal to, or better than zinc/phosphorus. In fact, many of the modern low zinc oils provide BETTER WEAR PROTECTION than many of the traditional high zinc oils, which you will see in the ranking list below.
Oil “wear protection” capability that was tested here, and an oil’s “friction reduction” capability, are two entirely different things. While the test data here provides excellent information about an oil’s ability to prevent wear, it says nothing about an oil’s ability to reduce friction. So, the data here will not provide any information regarding differences in HP potential.
It should also be noted that I do NOT get paid by any Oil Company, nor by any Motor Oil Retailer, nor do I sell anything myself. So, I have no vested interest in what oil people choose to run. Therefore, all the data here is totally independent, unbiased, and is reported exactly how the test results came out. I have no agenda here, other than simply sharing the FACTS with like-minded gear heads.
The ppm (parts per million) quantities of zinc, phosphorus, moly and in some cases titanium, shown in the ranking list below, are taken directly from the Lab Reports that came back from the Professional Lab “ALS Tribology” in Sparks, Nevada. Some oils have MORE ZINC than phosphorus, while other oils have MORE PHOSPHORUS than zinc. It just depends on the particular oil’s formulation. Either way, the numbers below are correct and are NOT typos.
The “Load Carrying Capacity/Film Strength” ranking list is from all the real world motor oil “Wear Testing” I’ve performed so far on new oils. The list includes modern API certified low zinc oils, traditional high zinc High Performance/Racing oils, Diesel oils, low zinc oils with zinc additives added in, and Break-In oils.
Test result differences between oils of less than 10% are not significant, and oils within that range can be considered approximately equivalent.
All oil bottles involved in the testing were thoroughly shaken before the samples were taken. This ensured that all the additive package components were distributed uniformly throughout all the oil in the bottle, and not settled to the bottom.
Lower ranked oils are not necessarily “bad”, they simply don’t provide as much wear protection capability as higher ranked oils. If you have been running a low ranked oil in your engine without issue, that does not mean you have switch to a different oil, and it also does not mean you were using a great oil. It only means that your engine’s wear protection needs have not exceeded that oil’s capability. And as long as your engine’s needs don’t exceed that oil’s capability, you will never have a problem. But, if unexpected circumstances come up that make your engine’s needs exceed that oil’s capability, such as an overheating condition, an oiling condition, a loading condition, some parts heading south, or whatever, your engine can end up junk. But, if you’d been using an oil with a much higher capability, it could still provide enough extra protection to save your engine. So, each person has to decide for themselves, which motor oil provides the wear protection capability they are comfortable with, for any given engine build.
For the test results in the Ranking List, the HIGHER the psi value, the BETTER the wear protection. And this applies to ALL engines, including ANY High Performance flat tappet engine. An easy way to use this ranking list, is to find an oil you are familiar with, then look at the oils ranked higher, which provide better wear protection, and look at oils ranked lower, which provide less wear protection.
Until I started performing Tribology Research, and setup my motor oil “Wear Protection Capability Ranking List”, there was no good way to know which oils provided good wear protection, and which oils didn’t. Because it’s been proven over and over by a number of sources that zinc levels alone, cannot indicate which oils are good and which oils are not. The whole high zinc mindset is only Folklore that CANNOT BE PROVEN, and it DOES NOT stand up to any form of testing. So previously, all we could do was guess, or use trial and error to determine which oil was good enough, and which oil was not. And even then, we had no way of knowing how various “good enough” oils compared among themselves.
You cannot advance your knowledge into the future by clinging to the incorrect thinking of the past. This is the 21st Century, and we no longer have to guess or use trial and error to decide on which oil to use. Now, we have documented wear test data available. So the future is here, and all we have to do is look at the Ranking List, to choose an oil that provides a wear protection capability level we are comfortable with for any given build.
The “Wear Protection” test data here DIRECTLY APPLIES to flat tappet lobe/lifter interfaces (no matter how wicked the engine), pushrod tip/rocker arm interfaces, non-roller tip rocker arm/valve stem tip interfaces, distributor gear/cam gear interfaces, mechanical fuel pump pushrod tip/cam eccentric interfaces, and all highly loaded engine interfaces.
Here are some key points that you will see in the following test results:
* Synthetic oils rank between number 1 and number 128.
* Conventional oils rank between number 2 and number 129.
* Since the ranking of synthetic oils and conventional oils completely overlap, there is no clear distinction between their wear protection capabilities.
* I’ve also tested a number of both types of oil for the onset of thermal breakdown (not shown in the ranking list below). Individually, the synthetic oils that were tested, varied between 300* F and 210* F. But, on average, the onset of thermal breakdown for those synthetic oils was 278*F. Individually, the conventional oils varied between 280* F and 260* F, and the average for those conventional oils was 272*F. So, as you can see looking at the averages for each type of oil, there was only a 6* difference, meaning that overall, there is little to no difference in their abilities to withstand high temps. So, while some individual synthetic oils do well when subjected to high heat, overall they do not live up to the outrageous claims of some Internet articles. At the end of the day, the conventional oils tested here, were about the same regarding their ability to withstand heat, making them a lot better than many people think. And the average value for the onset of thermal breakdown for all these oils combined = 277* F.
* Also when comparing same viscosity synthetic oils vs conventional oils in a running engine, using synthetic oils will sometimes result in mechanically noisier engines. This is NOT a problem and has nothing to do with their wear protection capabilities, nor how much zinc is present in each oil. It is simply a characteristic difference that will sometimes show up between the two oil types.
* High zinc oils rank between number 7 and number 129, which VERY CLEARLY shows that simply having a high level of zinc is no guarantee of superior wear protection. If a high level of zinc was a guarantee of superior wear protection, then all high zinc oils would rank at the top of the list. But, that simply is NOT the case. And many wiped flat tappet lobes COULD HAVE BEEN AVOIDED if people had not blindly believed that all high zinc oils provide all the wear protection they need. Because nothing could be further from the truth.
* Low zinc oils rank between number 1 and number 104.
* Since the low zinc oils and the high zinc oils completely overlap, you can see that zinc does not play the primary role in determining an oil’s wear protection capability. An oil’s wear protection capability is determined by its base oil and its additive package “as a whole”, with the primary emphasis on the additive package, which contains the extreme pressure anti-wear components. And modern alternate extreme pressure components are equal to, or better than zinc. Tech Author David Vizard calls the use of zinc as the primary anti-wear component, outdated technology. And that is precisely what my motor oil “Dynamic Wear Testing Under Load” found as well.
* I’ve also tested ZDDPlus zinc additive in 3 low zinc oils, and I’ve tested Edelbrock Zinc additive in 3 different low zinc oils. In each case, the recommended amount of additive was used. And in all 6 cases, these high zinc additives ruined the oils and made them WORSE than they were before the extra zinc was added, by SIGNIFICANTLY reducing their wear protection capabilities. These additives did the opposite of what was promised. That is not surprising, because most major Oil Companies say to never add anything to their oils, because doing that will ruin the oil by upsetting the carefully balanced additive package that their Chemical Engineers designed into them. And that is precisely what was seen when using these high zinc additives.
* However, I have come across an exception to the warning about not adding anything to motor oil. I tested adding “Oil Extreme Concentrate” to ordinary 5W30 Pennzoil, API SN, conventional oil in the yellow bottle. This additive is calcium petroleum sulfontate based, rather than high zinc based. And after adding the recommended amount (for street applications) of that additive, it IMPROVED the wear protection capability of that oil by a whopping 30%.
I also added the recommended amount of “Oil Extreme Concentrate” (for racing applications) to 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional oil. And it IMPROVED the wear protection capability of that oil by a mind blowing 69%.
I also added the recommended amount of “Oil Extreme Concentrate” (for racing applications) to 10W30 Brad Penn, Penn Grade 1, semi-synthetic oil. And it IMPROVED the wear protection capability of that oil by a breath taking 56%.
I also added the recommended amount of “Oil Extreme Concentrate” (for racing applications) to 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend oil. And it IMPROVED the wear protection capability of that oil by a significant 24%.
I also added the recommended amount of “Oil Extreme Concentrate” (for racing applications) to 5W30 Royal Purple XPR (extreme performance racing oil) synthetic oil. And it IMPROVED the wear protection capability of that oil by 9%.
This Oil Extreme Concentrate ACTUALLY MAKES THE OIL BETTER in terms of wear protection, and works as advertised in that regard. Obviously, this additive being calcium petroleum sulfontate based, does not ruin the oil like high zinc based additives do.
There were however, limits to its improvement potential. When the testing was complete, the conclusion was that oils with “around” 80,000 psi capability or less, should experience a SIGNIFICANT BENEFIT from using the “Oil Extreme Concentrate Additive”, in terms of improved wear protection capability. But, oils with a higher capability psi, did not see a benefit.
Prolong Engine Treatment is another motor oil additive that testing showed significantly improves an oil’s wear protection capability. I tested it in a full synthetic oil, and two conventional oils, which as a group, had a wide range for their original ranking positions. The additive improved the wear protection capability of all 3 oils, on average by about 46%. But, keep in mind that I only test an oil’s “Wear Protection Capability”. That provides the information that people usually care about most. However, that data is limited to ONLY wear protection capability, and does NOT provide any information as to how compatible overall this product’s chlorine may be with a given oil’s additive package. Chlorine and additive package incompatibility has the potential to result in corrosion issues. Contact Prolong’s maker for more information on compatibility.
* Diesel oils rank overall between number 15 and 109. But, if you omit the highest ranked Diesel oil which is FAR, FAR MORE CAPABLE than all the other Diesel oils, the rest only rank between 58 and 109. The poor wear protection performance of all but the one particular top ranked Diesel oil, makes it very clear that in general, Diesel oils are a poor choice for High Performance gas engines.
* I’ve also tested synthetic and conventional Diesel oils for the onset of thermal breakdown (not shown in the ranking list below). Individually, the synthetic oils that were tested, varied between 285* F and 255* F. But, on average, the onset of thermal breakdown for those synthetic Diesel oils was 269*F. Individually, the conventional Diesel oils varied between 265* F and 250* F, and the average for those conventional oils was 255*F. The average value for the onset of thermal breakdown for all the tested Diesel oils combined = 261* F. Comparing the overall averages, you can see that these Diesel oils fell victim to heat about 12* F earlier than the gasoline engine oils that were tested. So, that is another reason why using Diesel oils in High Performance gas engines, is a poor choice.
* Break-In oils rank between number 72 and number 129. But, if you omit the highest ranked Break-In oil which is far more capable than the other Break-In oils, the rest only rank between 103 and 129. So, if you are looking for outstanding wear protection during break-in, you will be disappointed with these oils. Because they are not formulated to prevent wear, they are formulated to allow the parts to quickly “wear in”, which is totally unnecessary. You cannot stop parts from wearing-in on their own, no matter what oil you run. And we’ve seen that for many years with factory filled synthetic 5W30 Mobil 1 (which is one of the top ranked oils regarding wear protection capability) in countless thousands of brand new vehicles, that always break-in just fine. That makes so-called break-in oils unnecessary.
* 20 wt oils rank between number 20 and 121.
* 30 wt oils rank between number 1 and 129.
* 40 wt oils rank between number 58 and 120.
* 50 wt oils rank between number 13 and 113.
* So, as you can see, oil viscosity plays no particular role in an oil’s wear protection capability. As mentioned above, an oil’s wear protection capability is determined by its base oil and its additive package “as a whole”, with the primary emphasis on the additive package, which contains the extreme pressure anti-wear components.
* I generally recommend that people choose a motor oil that is highly ranked to begin with, that doesn’t need any additional help. And to use that oil just as it comes out of the bottle, with no additives at all. However, there is also data included below from testing a few different aftermarket motor oil additives, to provide information as to how these additives actually work.
* FOR THE RECORD, I am NOT connected in any way to the Oil or Oil Additive Industry. I have absolutely no interest in what products people choose to use. So, I DO NOT promote any particular oil or oil additive brand. I only report the results that come out of my testing, good or bad.
Wear protection reference categories are:
• Over 105,000 psi = INCREDIBLE wear protection
• 90,000 to 105,000 psi = OUTSTANDING wear protection
• 75,000 to 90,000 psi = GOOD wear protection
• 60,000 to 75,000 psi = MODEST wear protection
• Below 60,000 psi = UNDESIRABLE wear protection
All the oils were tested at a representative operational temperature of 230*F.
The HIGHER the psi value, the BETTER the Wear Protection.
1. Prolong Engine Treatment added to 5W30 Pennzoil Ultra, API SN synthetic = 136,658 psi
This oil on its own WITHOUT the Prolong Engine Treatment added to it, has a wear protection capability of 92,569 psi. With the recommended amount of Prolong added per qt, its wear protection capability “WENT UP 48%”. But, compared to the previous API “SM” version of this oil, this mixture’s capability went up 18%.
Prolong Engine Treatment motor oil additive worked amazingly well for increasing wear protection capability in all types of oils, at all ranking levels. But, for most people, it would be more cost effective to simply choose a highly ranked oil in the first place, and avoid using any additives at all. However, for heavily loaded race engines, flat tappet engines, and for flat tappet break-in, where the ultimate in wear protection is desired, this additive could be worth considering.
2. Prolong Engine Treatment added to 5W30 Castrol GTX, API SN conventional = 130,366 psi
This oil on its own WITHOUT the Prolong Engine Treatment added to it, has a wear protection capability of 95,392 psi. With the recommended amount of Prolong added per qt, its wear protection capability “WENT UP 37%”.
3. Prolong Engine Treatment added to 5W30 Pennzoil, API SN conventional yellow bottle = 117,028 psi
This oil on its own WITHOUT the Prolong Engine Treatment added to it, has a wear protection capability of 76,989 psi. With the recommended amount of Prolong added per qt, its wear protection capability “WENT UP 52%”.
NOTE:
5W30 Pennzoil Ultra, API SM synthetic = 115,612 psi
zinc = 806 ppm
phosphorus = 812 ppm
moly = 66 ppm
calcium = 3,011 ppm
TBN = 10.3
This oil was ranked in this position for about a year and a half. But, it is no longer ranked at all, because it has now been replaced by the newer API “SN” version. See below for the “SN” version’s ranking position.
4. “Oil Extreme concentrate” added to 5W30 Pennzoil Ultra, API SM synthetic = 111,570 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 115,612 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 3.5%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
calcium = TBD
TBN = TBD
5. “Oil Extreme concentrate” added to 10W30 Brad Penn, Penn Grade 1 semi-synthetic = 111,061psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 71,206 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP A BREATH TAKING 56%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
calcium = TBD
TBN = TBD
6. 5W30 Oil Extreme Motor Oil, API SM synthetic (per the Oil Company, even though synthetic wording is not shown on the label) = 110,286 psi
The Company claims this oil contains their proprietary formula of calcium petroleum sulfontate EP (Extreme Pressure) technology that is NOT found in any other motor oil. They also claim that it will provide 5 to 7 more HP, 7 to 10% better fuel mileage, cut engine wear in half, and will extend drain intervals two or three times safely. This oil is endorsed and promoted by Tech Author David Vizard. And he was so impressed by this oil’s performance that he also became a share holder in the Company. The results from the “Dynamic Wear Testing Under Load” performed here, fully supports their claim regarding wear protection. So, their hype about that, turned out to be absolutely true. And since this oil beat every high zinc oil I’ve ever tested, it also proved another one of their claims, that using zinc as the primary anti-wear component, is outdated technology.
zinc = 765 ppm
phosphorus = 624 ppm
moly = 52 ppm
calcium = 7,652 ppm
TBN = 23.2
7. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phosphorus = 3489 ppm
moly = 1764 ppm
calcium = 2,929 ppm
TBN = 9.0
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
8. CFS 0W30 NT Millers Nanodrive Racing Oil, API SM synthetic = 105,907 psi
This oil is from England, comes in liter bottles (slightly more than a quart), and it uses a nanotechnology formulation. At the time this oil was tested in fall 2013, it cost $22.45 per bottle. And with the shipping cost added to that, the final cost was about $28.00 per bottle (shipping was all inside the U.S.), making it THE most expensive oil I’ve ever tested.
zinc = TBD
phos = TBD
moly = TBD
calcium = TBD
TBN = TBD
9. 5W30 Mobil 1, API SN synthetic = 105,875 psi
zinc = 801 ppm
phosphorus = 842 ppm
moly = 112 ppm
calcium = 799 ppm
TBN = 7.5
10. “Oil Extreme concentrate” added to 10W30 Lucas Hot Rod & Classic Hi-Performance Oil conventional = 105,758 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 62,538 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP A MIND BLOWING 69%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
calcium = TBD
TBN = TBD
11. 0W30 Amsoil Signature Series 25,000 miles, API SN synthetic = 105,008 psi
zinc = 824 ppm
phosphorus = 960 ppm
moly = 161 ppm
calcium = 3,354 ppm
TBN = 11.4
12. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phosphorus = 1518 ppm
moly = 784 ppm
calcium = 1,607 ppm
TBN = 4.4
13. 5W50 Motorcraft, API SN synthetic = 103,517 psi
zinc = 606 ppm
phosphorus = 742 ppm
moly = 28 ppm
calcium = 1,710 ppm
TBN = 6.7
14. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phosphorus = 1544 ppm
moly = 3 ppm
calcium = 2,707 ppm
TBN = 7.6
15. 5W30 Amsoil Series 3000 Heavy Duty Diesel Oil synthetic, API CI-4 PLUS, CF, SL, ACEA A3/B3, E2, E3, E5, E7 = 102,642 psi
This is BY FAR, the highest ranked Diesel oil I have ever tested. This oil is Engineered for Diesel engines not equipped with Diesel particulate filters (DPF). Amsoil says this oil delivers better wear protection than other popular Diesel oils. And in this case, their hype is absolutely true. They also say it effectively reduces fuel consumption, with its advanced fuel efficient formula. This oil costs $11.15 per quart in the 2013 Amsoil Factory Direct Retail Catalog, which is 10% more than Amsoil’s 5W40 Premium Synthetic Diesel Oil. So, in this case, you pay only 10% more for the Amsoil Series 3000 Heavy Duty Diesel Oil, but you get a whopping 33% more wear protection than you get with the Amsoil’s 5W40 Premium Synthetic Diesel Oil. Money very well spent, if you run a Diesel oil intended for engines not equipped with Diesel particulate filters. The next highest ranked Diesel oil ranks far lower on the ranking list. So, this 5W30 Amsoil Series 3000 Heavy Duty Diesel Oil is in a class of its own, among all the Diesel oils I have tested.
zinc = TBD
phos = TBD
moly = TBD
16. “Oil Extreme concentrate” added to 5W30 Mobil 1, API SN synthetic = 102,059 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 105,875 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 3.6%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
calcium = TBD
TBN = TBD
17. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phosphorus = 1112 ppm
moly = 162 ppm
calcium = 2,664 ppm
TBN = 7.4
18. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 100,252 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 1.5 OZ of concentrate added per qt, which is the bottle’s instruction for street driven vehicles, its wear protection capability “WENT UP A WHOPPING 30%”.
zinc = 970 ppm
phosphorus = 749 ppm, this value is 91 ppm lower than the basic oil because the concentrate has less phosphorus in it, which diluted the overall ppm count of the mixture.
moly = 285 ppm
calcium = 4,443 ppm
TBN = 18.8
19. 5W30 Chevron Supreme, API SN conventional = 100,011 psi
This oil only cost $4.29 per quart at an Auto Parts Store when I bought it.
zinc = 1018 ppm
phos = 728 ppm
moly = 161 ppm
20. 5W20 Castrol Edge with Titanium, API SN synthetic = 99,983 psi
zinc = 1042 ppm
phos = 857 ppm
moly = 100 ppm
titanium = 49 ppm
21. 5W30 Pennzoil Platinum, API SN synthetic = 99,949 psi
zinc = TBD
phos = TBD
moly = TBD
22. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 99,529 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP 29%”.
zinc = TBD
phos = TBD
moly = TBD
23. “Oil Extreme concentrate” added to 5W30 Oil Extreme Motor Oil, API SM synthetic = 98,396 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 110,286 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 11%”.
zinc = TBD
phos = TBD.
moly = TBD
24. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 97,651 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 3.0 OZ of concentrate added per qt, its wear protection capability “WENT UP 27%”.
zinc = TBD
phos = TBD
moly = TBD
25. 10W30 Amsoil Dominator Racing Oil synthetic = 97,118 psi
zinc = 1613 ppm
phos = 1394 ppm
moly = 0 ppm
26. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 96,739 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 4.0 OZ of concentrate added per qt, its wear protection capability “WENT UP 26%”.
zinc = TBD
phos = TBD
moly = TBD
27. 20W50 Castrol GTX, API SN conventional = 96,514 psi
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
28. 30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
29. 0W20 Mobil 1 Advanced Fuel Economy, API SN synthetic = 96,364 psi
zinc = 742 ppm
phos = 677 ppm
moly = 81 ppm
30. 5W30 Quaker State Ultimate Durability, API SN synthetic = 95,920 psi
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
31. 5W30 Castrol Edge with Titanium, API SN synthetic = 95,717 psi
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
32. 10W30 Joe Gibbs XP3 NASCAR Racing Oil synthetic = 95,543 psi
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
33. 5W20 Castrol GTX, API SN conventional = 95,543 psi
zinc = TBD
phos = TBD
moly = TBD
NOTE: The two oils above were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same.
34. 5W30 Castrol GTX ,API SN conventional = 95,392 psi
zinc = 830 ppm
phos = 791 ppm
moly = 1 ppm
35. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
36. 5W30 Havoline, API SN conventional = 95,098 psi
zinc = TBD
phos = TBD
moly = TBD
37. 5W30 Valvoline SynPower, API SN synthetic = 94,942 psi
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
38. “Oil Extreme concentrate” added to 5W30 Chevron Supreme, API SN conventional = 94,864 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 100,011 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 5.1%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
39. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi
zinc = TBD
phos = TBD
moly = TBD
40. 5W20 Mobil 1, API SN synthetic = 94,663 psi
zinc = 764 ppm
phos = 698 ppm
moly = 76 ppm
41. 5W20 Valvoline SynPower, API SN synthetic = 94,460 psi
zinc = 1045 ppm
phos = 742 ppm
moly = 0 ppm
42. 5W30 Pennzoil Ultra, API SN synthetic = 92,569 psi
zinc = TBD
phos = TBD
moly = TBD
The older API “SM” version of this oil, produced a wear protection capability value of 115,612 psi.
43. 5W30 Lucas, API SN conventional = 92,073 psi
zinc = 992 ppm
phos = 760 ppm
moly = 0 ppm
44. 5W30 O’Reilly (house brand), API SN conventional = 91,433 psi
This oil only cost $3.99 per quart at an Auto Parts Store when I bought it.
zinc = 863 ppm
phos = 816 ppm
moly = 0 ppm
45. 5W30 Maxima RS530 Synthetic Racing Oil = 91,162 psi
zinc = 2162 ppm
phos = 2294 ppm
moly = 181 ppm
46. 5W30 Red Line, API SN synthetic = 91,028 psi
zinc = TBD
phos = TBD
moly = TBD
47. 5W20 Royal Purple API SN synthetic = 90,434 psi
zinc = 964 ppm
phos = 892 ppm
moly = 0 ppm
48. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
moly = 99 ppm
49. 10W60 Castrol TWS Motorsport, API SJ conventional = 90,163 psi
This oil is manufactured in Europe and is sold in the US for BMW models M3, M5, M6, Z4M, and Z8.
zinc = TBD
phos = TBD
moly = TBD
50. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi
zinc = TBD
phos = TBD
moly = TBD
51. “Oil Extreme concentrate” added to 5W30 Castrol GTX, API SN conventional = 89,659 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 95,392 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 6%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
52. 5W30 Havoline, API SN synthetic = 89,406 psi
zinc = TBD
phos = TBD
moly = TBD
53. 30 wt Castrol Heavy Duty, API SM conventional = 88,089 psi
zinc = 907 ppm
phos = 829 ppm
moly = 56 ppm
54. 20W50 LAT Synthetic Racing Oil, API SM = 87,930 psi
zinc = TBD
phos = TBD
moly = TBD
55. 5W30 Valvoline Nextgen 50% Recycled Oil, API SN conventional = 87,563 psi
zinc = 947 ppm
phos = 778 ppm
moly = 0 ppm
56. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
57. 5W20 Pennzoil Ultra, API SM synthetic = 86,034 psi
zinc = TBD
phos = TBD
moly = TBD
58. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
moly = 173 ppm
59. 5W30 Castrol Edge w/Syntec, API SN (formerly Castrol Syntec) black bottle, synthetic = 85,179 psi
zinc = TBD
phos = TBD
moly = TBD
60. 5W30 Royal Purple API SN synthetic = 84,009 psi
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
61. 20W50 Royal Purple API SN synthetic = 83,487 psi
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
62. 20W50 Kendall GT-1 High Performance with liquid titanium, API SN conventional = 83,365 psi
zinc = 991 ppm
phos = 1253 ppm
moly = 57 ppm
titanium = 84 ppm
63. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN synthetic = 83,263 psi
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
64. 0W20 Castrol Edge with Titanium, API SN synthetic = 82,867 psi
zinc = TBD
phos = TBD
moly = TBD
65. 0W40 Mobil 1, API SN, European Formula, made in the U.S., synthetic = 82,644 psi
zinc = TBD
phos = TBD
moly = TBD
66. 0W40 Pennzoil Ultra, API SN, synthetic = 81,863 psi
zinc = TBD
phos = TBD
moly = TBD
67. 5W30 LAT Synthetic Racing Oil, API SM = 81,800 psi
zinc = 1784 ppm
phos = 1539 ppm
moly = 598 ppm
68. “Oil Extreme concentrate” added to 5W30 Royal Purple XPR (extreme performance racing oil) synthetic = 81,723 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 74,860 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP 9%”.
zinc = TBD
phos = TBD.
moly = TBD
69. 0W30 Mobil 1, API SN, Advanced Fuel Economy, synthetic = 81,240 psi
zinc = TBD
phos = TBD.
moly = TBD
70. 5W30 Peak, API SN synthetic = 80,716 psi
zinc = TBD
phos = TBD
moly = TBD
71. 5W30 Edelbrock “Cat-Safe”, API SM synthetic = 78,609 psi
This oil is made for Edelbrock by Torco
zinc = 924 ppm
phos = 659 ppm
moly = 28 ppm
72. 30wt Amsoil Break-In Oil conventional = 78,192 psi
zinc = 2051 ppm
phos = 1917 ppm
moly = 0 ppm
73. 20W50 Resolute Racing Oil, API SN conventional = 77,554 psi
zinc = TBD
phos = TBD
moly = TBD
This oil cost only $2.49 per quart when bought for this test. It is a Regional Oil from the Mid-Western U.S. farm country.
74. 5W40 Amsoil Premium Diesel Oil synthetic, API CJ-4, CI-4 PLUS, CF, SN, SM, ACEA E7, E9 = 77,207 psi
zinc = TBD
phos = TBD
moly = TBD
75. 10W30 Renegade Pro Series Racing Oil, synthetic blend = 77,136 psi
zinc = TBD, but bottle claims over 3000 ppm
phos = TBD
moly = TBD
76. 15W40 ROYAL PURPLE Diesel Oil synthetic, API CJ-4 /SM, CI-4 PLUS, CH-4, CI-4 = 76,997 psi
zinc = TBD
phos = TBD
moly = TBD
77. 5W30 Pennzoil, API SN yellow bottle, conventional = 76,989 psi
zinc = 839 ppm
phos = 840 ppm
moly = 267 ppm
78. 10W40 Chevron Supreme, API SN conventional = 76,806 psi
zinc = TBD
phos = TBD
moly = TBD
79. 5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
moly = 0 ppm
80. 5W30 GM’s AC Delco dexos 1 API SN semi-synthetic = 76,501 psi
zinc = 878 ppm
phos = 758 ppm
moly = 72 ppm
81. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
moly = 71 ppm
82. “Oil Extreme concentrate” added to 10W30 Comp Cams Muscle Car & Street Rod Oil semi-synthetic = 74,874 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 60,413 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP AN IMPRESSIVE 24%”.
zinc = TBD
phosphorus = TBD.
moly = TBD
83. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
84. 15W40 Cenpeco (Central Petroleum Company) S-3 Diesel Oil, conventional, API CI-4, CH-4, CG-4, CF, CE, CD, SL, SJ, SH = 74,593 psi
zinc = TBD
phos = TBD
moly = TBD
85. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
86. 0W50 Mobil 1 Racing Oil = 73,811 psi
zinc = 1676 ppm
phos = 1637 ppm
moly = 1263 ppm
87. 5W30 Peak, API SN conventional = 73,690 psi
zinc = TBD
phos = TBD
moly = TBD
88. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
moly = 80 ppm
89. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
moly = 46 ppm
90. 15W40 Farm Rated Heavy Duty Performance Diesel Oil conventional CI-4, CH-4, CG-4, CF/SL, SJ = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
moly = 2 ppm
91. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
moly = 0 ppm
92. Brad Penn, Penn Grade 1 Nitro 70 Racing Oil semi-synthetic = 72,003 psi
zinc = TBD
phos = TBD
moly = TBD
93. 0W30 Mobil 1 Racing Oil = 71,923 psi
zinc = 1693 ppm
phos = 1667 ppm
moly = 1326 ppm
94. 0W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
moly = 0 ppm
95. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
moly = 0 ppm
Yes it’s true, the old Rotella actually has LESS zinc than the new Rotella.
96. 10W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
moly = 3 ppm
97. 15W40 VALVOLINE PREMIUM BLUE HEAVY DUTY DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF/SM = 70,869 psi
zinc = TBD
phos = TBD
moly = TBD
98. 15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1,133 ppm
phos = 1,168 ppm
moly = 83 ppm
99. 10W40 Resolute All Season Motor Oil, API SN conventional = 69,709 psi
zinc = TBD
phos = TBD
moly = TBD
This oil cost $2.49 per quart when bought for this test. It is a Regional Oil from the Mid-Western U.S. farm country.
100. 5W40 CHEVRON DELO 400LE Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, SL, SM = 69,631 psi
zinc = TBD
phos = TBD
moly = TBD
101. 0W40 Castrol Edge with Syntec (black bottle), API SN, European Formula, made in Belgium and sold in the U.S., synthetic = 69,307 psi
zinc = TBD
phos = TBD
moly = TBD
102. 0W30 Castrol Edge with Syntec (black bottle), API SL, European Formula, made in Germany and sold in the U.S., synthetic = 69,302 psi
zinc = TBD
phos = TBD
moly = TBD
103. 30wt Edelbrock Break-In Oil conventional = 69,160 psi
zinc = 1545 ppm
phos = 1465 ppm
moly = 4 ppm
104. 5W30 Motorcraft, API SN synthetic = 68,782 psi
zinc = 796 ppm
phos = 830 ppm
moly = 75 ppm
105. 10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
moly = 121 ppm
This oil is manufactured for Edelbrock by Torco.
106. 5W30 Toyota Motor Oil, API SN conventional = 68,069 psi
zinc = TBD
phos = TBD
moly = TBD
107. 5W40 SHELL ROTELLA T6 Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4, SM, SL = 67,804 psi
zinc = TBD
phos = TBD
moly = TBD
108. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
moly = 76 ppm
109. 15W40 CASTROL GTX DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4/SN = 66,323 psi
zinc = TBD
phos = TBD
moly = TBD
110. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
moly = 189 ppm
111. 10W40 Valvoline 4 Stroke Motorcycle Oil, API SJ conventional = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
moly = 0 ppm
112. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
moly = 339 ppm
113. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi
zinc = 2436 ppm (up 1848 ppm)
phos = 2053 ppm (up 1356 ppm)
moly = 2 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
114. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
moly = 0 ppm
115. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
moly = 871 ppm
116. 0W20 Klotz Estorlin Racing Oil, API SL synthetic = 60,941 psi
zinc = TBD
phos = TBD
moly = TBD
117. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi
zinc = 1673 ppm
phos = 1114 ppm
moly = 67 ppm
This oil is manufactured for Comp Cams by Endure.
118. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
moly = 227 ppm
119. 10W40 Summit Racing Premium Racing Oil, API SL = 59,483 psi
This oil is made for Summit by I.L.C.
zinc = TBD
phos = TBD
moly = TBD
NOTE: This oil line was discontinued in Spring 2013.
120. 10W40 Edelbrock conventional = 59,120 psi
zinc = TBD
phos = TBD
moly = TBD
121. 0W20 LAT Synthetic Racing Oil, API SM = 57,228 psi
zinc = TBD
phos = TBD
moly = TBD
122. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi
zinc = 2711 ppm (up 1848 ppm)
phos = 2172 ppm (up 1356 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
123. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi
zinc = 2955 ppm (up 1848 ppm)
phos = 2114 ppm (up 1356 ppm)
moly = 76 ppm (up 2 ppm)
The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
124. 0W Mobil 1 Racing Oil = 55,080 psi
zinc = 1952 ppm
phos = 1671 ppm
moly = 1743 ppm
125. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi
zinc = 1515 ppm (up 573 ppm)
phos = 1334 ppm (up 517 ppm)
moly = 15 ppm (up 15 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
126. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
moly = 180 ppm
127. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi
zinc = 1565 ppm (up 573 ppm)
phos = 1277 ppm (up 517 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
128. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi
zinc = 1680 ppm (up 573 ppm)
phos = 1275 ppm (up 517 ppm)
moly = 89 ppm (up 15 ppm)
The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised.
129. 30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
moly = 3 ppm
*************** MOTOR OIL VISCOSITY SELECTION **************
THE BENEFITS OF USING THINNER OIL:
• Thinner oil flows quicker at cold start-up to begin lubricating critical engine components much more quickly than thicker oil can. Most engine wear takes place during cold start-up before oil flow can reach all the components. So, quicker flowing thinner oil will help reduce start-up engine wear, which is actually reducing wear overall.
• The more free flowing thinner oil at cold start-up, is also much less likely to cause the oil filter bypass to open up, compared to thicker oil. Of course if the bypass opened up, that would allow unfiltered oil to be pumped through the engine. The colder the ambient temperature, and the more rpm used when the engine is cold, the more important this becomes.
• Thinner oil also flows more at normal operating temperatures. And oil FLOW is lubrication, but oil pressure is NOT lubrication. Oil pressure is only a measurement of resistance to flow. Running thicker oil just to up the oil pressure is the wrong thing to do, because that only reduces oil flow/lubrication. Oil pressure in and of itself, is NOT what we are after.
• The more free flowing thinner oil will also drain back to the oil pan quicker than thicker oil. So, thinner oil can help maintain a higher oil level in the oil pan during operation, which keeps the oil pump pickup from possibly sucking air during braking and cornering.
• The old rule of thumb that we should have at least 10 psi for every 1,000 rpm is perfectly fine. Running thicker oil to achieve more pressure than that, will simply reduce oil flow for no good reason. It is best to run the thinnest oil we can, that will still maintain at least the rule of thumb oil pressure. And one of the benefits of running a high volume oil pump, is that it will allow us to enjoy all the benefits of running thinner oil, while still maintaining sufficient oil pressure. A high volume oil pump/thinner oil combo is preferred over running a standard volume oil pump/thicker oil combo. Because oil “flow” is our goal for ideal oiling, NOT simply high oil pressure.
• Oil flow is what carries heat away from internal engine components. Those engine components are DIRECTLY oil cooled, but only INdirectly water cooled. And better flowing thinner oil will keep critical engine components cooler because it carries heat away faster. If you run thicker oil than needed, you will drive up engine component temps. For example: Plain bearings, such as rod and main bearings are lubricated by oil flow, not by oil pressure. Oil pressure is NOT what keeps these parts separated. Oil pressure serves only to supply the oil to this interface. The parts are kept apart by the incompressible hydrodynamic liquid oil wedge that is formed as the liquid oil is pulled in between the spinning parts. As long as sufficient oil is supplied, no wear can occur. In addition to this, the flow of oil through the bearings is what cools them. Here are some comparison numbers from an 830 HP road race engine on the track:
15W50 oil = 80 psi = 265* oil sump temperature
5W20 oil = 65 psi = 240* oil sump temperature
Here you can see how the thicker oil flowed more slowly through the bearings, thus getting hotter, driving up bearing temperatures and increasing sump temperatures. And the thinner oil flowed more freely and quickly through the bearings, thus cooling and lubricating them better than thicker oil, while also reducing sump temperatures. If an engine is running hot, use a thinner oil to increase flow, increase internal component cooling, and help keep sump temperatures down. Keeping oil temps down is important to help keep oil below the threshold of thermal breakdown.
• Thinner oil will typically increase HP because of less viscous drag and reduced pumping losses, compared to thicker oils. That is why very serious Race efforts will generally use watery thin oils in their engines. But, an exception to this increase in HP would be in high rpm hydraulic lifter engines, where thinner oil can allow the lifters to malfunction at very high rpm. In everyday street vehicles, where fuel consumption is a consideration, thinner oils will also typically increase fuel economy. The majority of new cars sold in the U.S. now call for 5W20 specifically for increased fuel economy. And now Diesel trucks are increasingly calling for 5W30, also for fuel economy improvement.
• With the exception of high rpm hydraulic lifter engines, almost no engine should ever need to run oil thicker than a multi-viscosity 30 weight. The lower the first number cold viscosity rating, the better the cold flow. For example, 0W30 flows WAY better cold than 20W50. And 0W30 flows WAY better cold than straight 30wt, which is horrible for cold start-up flow and should be avoided at all cost. And the lower the second number hot viscosity rating, the better the hot flow. For example, 0W30 flows WAY better hot than 20W50.
• Thicker oil DOES NOT automatically provide better wear protection than thinner oils. Extensive “dynamic wear testing under load” of over 100 motor oils, has shown that the base oil and its additive package “as a whole”, is what determines an oil’s wear protection capability, NOT its viscosity. For example, some 5W20 oils have proven to provide OUTSTANDING wear protection, while some 15W50 oils have only been able to provide MODEST wear protection. So, do not run thicker oil under the false assumption that it can provide better wear protection for our engines.
• BOTTOM LINE: Thinner oils are better for most engine lubrication needs.
540 RAT
U.S. Patent Holder
Member SAE (Society of Automotive Engineers)
Old Mar 8, 2014 | 06:51 PM
LSOHOLIC's Avatar
LSOHOLIC
High Temp motor oil Wear Testing-Myth vs Reality (very long)
Post by 540 RAT » Tue Jun 05, 2012 2:06 pm
I’ve increased the scope of my ongoing motor oil “Load Carrying Capacity/Film Strength” wear testing efforts. This testing is a motor oil torture test that subjects oil to a friction test under load, in a controllable and repeatable manner, while the wear specimens are bathed in oil. This test is significantly more severe on the oil than is an actual running engine. That way you can see how different oils directly compare to each other, without having to wait for 100,000 miles to see what happened. It allows you to quickly determine outstanding oils from ordinary oils.
The first time I tested 44 oils (then later added 3 more), all at a representative operating temperature of 230*F. Of course testing at a single temperature data point does not show the big picture overall. So, now I’ve re-tested a dozen of those oils at a higher temperature to get a better idea of how various oil types perform over a wider range of temperatures. The oils chosen this time consist of:
*** 10 different brands
*** 6 low zinc (below 1,000 ppm) oils
*** 6 high zinc (above 1,000 ppm) oils
*** Viscosities ranging from 5W20 to 20W50
*** 8 full synthetic oils
*** 3 conventional dino oils
*** 1 semi-synthetic oil
*** 6 Racing/High Performance oils
*** 6 Modern API certified oils
*** 6 Low detergent (less than 2.0 “detergent/zinc” ratio) oils
*** 6 High detergent (2.0 or higher “detergent/zinc” ratio) oils
Here are those 12 oils, ranked by their test result capabilities at 230*F:
1. 5W30 Pennzoil Ultra, API SM (synthetic)
115,612 psi “load carrying capacity”
2. 10W30 Lucas Racing Only (synthetic)
106,505 psi “load carrying capacity” (8% below no. 1)
3. 5W30 Mobil 1, API SN (synthetic)
105,875 psi “load carrying capacity” (8% below no. 1)
4. 5W50 Motorcraft, API SN (synthetic)
103,517 psi “load carrying capacity” (10% below no. 1)
5. 10W30 Valvoline VR1 Racing Oil silver bottle (conventional)
103,505 psi “load carrying capacity” (10% below no. 1)
6. 5W20 Castrol Edge w/Titanium, API SN (synthetic)
99,983 psi “load carrying capacity” (14% below no. 1)
7. 20W50 Castrol GTX, API SN (conventional)
96,514 psi “load carrying capacity” (17% below no. 1)
8. 10W30 Joe Gibbs XP3 NASCAR Racing Oil (synthetic)
95,543 psi “load carrying capacity” (17% below no. 1)
9. 5W30 Castrol GTX, API SN (conventional)
95,392 psi “load carrying capacity” (17% below no. 1)
10. 10W30 Amsoil Z-Rod Oil (synthetic)
95,360 psi “load carrying capacity” (18% below no. 1)
11. 5W30 Royal Purple XPR (synthetic)
74,860 psi “load carrying capacity” (35% below no. 1)
12. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic)
71,377 psi “load carrying capacity” (38% below no. 1)
Of these 12 oils, the top 10 were in the over 90,000 psi “OUTSTANDING PROTECTION CATEGORY”. And the last 2 were in the 60,000 to 75,000 psi “MODEST PROTECTION CATEGORY”. None of these oils were BAD oils, it’s just that some provided a higher margin of safety than others, regarding wear protection. Now let’s take a look at how things changed at a higher temperature.
Capability ranking at 275*F:
1. 5W30 Pennzoil Ultra, API SM = 97,955 psi (dropped 15% from its 230* value)
2. 5W30 Mobil 1, API SN = 96,323 psi (dropped 9% from its 230* value)
(2% below no. 1 here at 275*)
3. 10W30 Lucas Racing Only = 95,996 psi (dropped 10% from its 230* value)
4. 5W50 Motorcraft, API SN = 92,545 psi (dropped 11% from its 230* value)
(6% below no. 1 here at 275*)
5. 10W30 Amsoil Z-Rod Oil = 91,351 psi (dropped ONLY 4% from its 230* value)
(7% below no. 1 here at 275*)
6. 20W50 Castrol GTX, API SN = 85,815 psi (dropped 11% from its 230* value)
(12% below no. 1 here at 275*)
7. 5W20 Castrol Edge w/Titanium, API SN = 84,584 psi (dropped 15% from its 230* value)
(14% below no. 1 here at 275*)
8. 10W30 Joe Gibbs XP3 NASCAR Racing Oil = 80,957 psi (dropped 15% from its 230* value)
(17% below no. 1 here at 275*)
9. 5W30 Castrol GTX, API SN = 80,957 psi (dropped 15% from its 230* value)
NOTE: This is not a typo here, number 8 and 9 here just happened to have the same size wear scar, thus the same psi value.
10. 10W30 Valvoline VR1 Racing Oil, silver bottle = 75,116 psi (dropped 27% from its 230* value)
(23% below no. 1 here at 275*)
11. 0W30 Brad Penn, Penn Grade 1 = 68,768 psi (dropped ONLY 4% from its 230* value)
(30% below no. 1 here at 275*)
12. 5W30 Royal Purple XPR = 66,664 psi (dropped 11% from its 230* value)
(32% below no. 1 here at 275*)
As expected, the capability psi values dropped as the oils got hotter and thinner. But for most of the oils, the drop was not enormous. And the average psi drop for the whole group of 12 oils, was only about 12% from their 230* values.
You can see, there was some shuffling of the ranking order, but the original top 10, are still in the top 10. And there was no indication of the presence of slow burn zinc (requires more heat and load to become effective) that may have helped the low performing high zinc oils, do better at higher temps.
But, since engines oil won’t typically be running at just 230*F or at just 275*F, it makes the most sense to average the values from the relatively cool low temp and the relatively hot high temp, to arrive at values in the middle. This will provide a more real world reference overall.
The “average” capability ranking from 230*F and 275*F combined:
106,784 psi “load carrying capacity”
zinc = 806 ppm
total detergent = 3387 ppm
detergent ppm/zinc ppm ratio = 4.2, the higher this number, the higher the proportion of detergent, which can have the potential to try and clean away zinc
NOT SUITABLE FOR STREET USE
101,251 psi “load carrying capacity” (5% below no. 1)
zinc = 2642 ppm
total detergent = 2943 ppm
detergent ppm/zinc ppm ratio = 1.1
101,099 psi “load carrying capacity” (5% below no. 1)
zinc = 801 ppm
total detergent = 1489 ppm
detergent ppm/zinc ppm ratio = 1.9
98,031 psi “load carrying capacity” (8% below no. 1)
zinc = 606 ppm
total detergent = 2005 ppm
detergent ppm/zinc ppm ratio = 3.3
5. 10W30 Amsoil Z-Rod Oil (synthetic)
93,356 psi “load carrying capacity” (13% below no. 1)
zinc = 1431 ppm
total detergent = 2927 ppm
detergent ppm/zinc ppm ratio =2.0
92,284 psi “load carrying capacity” (14% below no. 1)
zinc = 1042 ppm
total detergent = 1952 ppm
91,165 psi “load carrying capacity” (15% below no. 1)
zinc = 610 ppm
total detergent = 2599 ppm
detergent ppm/zinc ppm ratio = 4.3
8. 10W30 Valvoline VR1 Racing Oil silver bottle (conventional)
89,311 psi “load carrying capacity” (16% below no. 1)
zinc = 1472 ppm
total detergent = 2787 ppm
9. 10W30 Joe Gibbs XP3 NASCAR Racing Oil (synthetic)
88,250 psi “load carrying capacity” (17% below no. 1)
zinc = 743 ppm
total detergent = 620 ppm
detergent ppm/zinc ppm ratio = .8
10. 5W30 Castrol GTX, API SN (conventional)
88,175 psi “load carrying capacity” (17% below no. 1)
zinc = 830 ppm
total detergent = 2648 ppm
detergent ppm/zinc ppm ratio = 3.2
70,762 psi “load carrying capacity” (34% below no. 1)
zinc = 1421 ppm
total detergent = 3050 ppm
detergent ppm/zinc ppm ratio = 2.1
70,073 psi “load carrying capacity” (34% below no. 1)
zinc = 1621 ppm
total detergent = 2939 ppm
detergent ppm/zinc ppm ratio = 1.8 (only 43% of the detergent concentration of no. 1)
Looking at these 230*F and 275*F combined “average values”, you can see the following:
*** Modern API certified oils ranked from number 1 to number 10
*** Racing/High Performance oils ranked from number 2 to number 12
*** High detergent oils ranked from number 1 to number 11
*** Low detergent oils ranked from number 2 to number 12
*** Synthetic oils ranked from number 1 to number 11
*** Conventional dino oils ranked from number 7 to number 10
*** Semi-synthetic oil ranked number 12
*** 20 wt type oil ranked number 6
*** 30 wt type oils ranked from number 1 to number 12
*** 50 wt type oils ranked from number 4 to number 7
So, it’s quite clear by looking at these results, that high zinc levels, high detergent levels, and heavy viscosities do NOT play any particular roll in how well a motor oil does or does not provide wear protection. The only thing that matters is the base oil and its additive package “as a whole”. Looking at zinc levels, detergent levels, and viscosities on an oil’s spec sheet, will NOT help you choose a motor oil that provides the best wear protection. If that is all you go by, you will be kidding yourself about how good any particular oil is.
And keep in mind that the oil industry is fully aware that there is alternate chemistry available besides zinc/phos, which can be used for extreme pressure wear protection, that is equal to or better than zinc/phos. And that alternate chemistry is just what they use to reduce the zinc/phos levels in modern API certified oils. So, you do NOT need to have high levels of zinc/phos in order to have outstanding wear protection.
In spite of what many Racers, Hotrodders and Gearheads have been lead to believe, only “wear testing” can provide the necessary data to help you choose a motor oil that will truly provide the best wear protection. It’s the same type of idea where we dyno test engines to see how they truly perform, rather than just looking at their spec sheets.
SYNTHETIC VS CONVENTIONAL OILS
Some of the most commonly claimed benefits of synthetics are:
1. Synthetics provide a higher level of wear protection.
2. Synthetics can withstand higher temperatures before thermal breakdown begins.
3. Synthetics provide superior flow under extremely cold conditions.
So, let’s see how the real world testing above, supports those claims. The synthetics above did show some advantage regarding wear protection, but NOT by a large amount. The highest ranked conventional oil ranked 7th out of 12, but was only 15% below the highest ranked synthetic oil. And this conventional oil ranked higher than other synthetic and semi-synthetic oils.
This shows that you cannot automatically assume that a synthetic oil will provide the best wear protection just because it is synthetic. Wear protection depends on the oil and its additive package “as a whole”. And it’s the additive package that contains the extreme pressure protection components, not the oil itself. And again, only “wear testing” can provide the data to help you choose an oil that provides the best wear protection.
THERMAL BREAKDOWN
I also heated the oils and observed the temperature at which they started to vaporize/smoke, which indicates the onset of thermal breakdown. Thermal breakdown is the point at which the composition of the oil begins to change due to the temperature it’s exposed to.
The official test for this is called the NOACK Volatility Test. In this test, the oil is heated to 302* F for one hour. The lighter oil fractions will vaporize, leaving thicker and heavier oil, contributing to poor circulation, reduced fuel economy, increased oil consumption, increased wear and increased emissions. The test reports results in the percentage, by weight, lost due to "volatilization."
Before July 1, 2001, 5W-30 motor oil in the United States could lose up to 22 percent of its weight and still be regarded as "passable." Now, with GF-4, the maximum NOACK volatility for API licensing is 15 percent. European standards limit high quality oils to a maximum of 13 percent loss.
Here are the approximate observed temperatures at which the various oils started to vaporize/smoke, which indicated the onset of thermal breakdown:
5W30 Pennzoil Ultra, API SM = 280*
5W30 Mobil 1, API SN = 265*
10W30 Lucas Racing Only = 290*
5W50 Motorcraft, API SN = 275*
10W30 Amsoil Z-Rod Oil = 300*, the BEST in this test
20W50 Castrol GTX, API SN = 275*
5W20 Castrol Edge w/Titanium, API SN = 280*
10W30 Joe Gibbs XP3 NASCAR Racing Oil = 280*
5W30 Castrol GTX, API SN = 280*
10W30 Valvoline VR1 Racing Oil, silver bottle = 260*, the WORST in this test
0W30 Brad Penn, Penn Grade 1 = 280*
5W30 Royal Purple XPR = 285*
Here are the “averages” for the onset of thermal breakdown with these 12 oils:
Full synthetic oils = 282*
Semi-synthetic oil = 280*
Conventional dino oils = 272*
These observations are perfectly consistent with the NOACK Volatility Test that is performed at 302*F. Oils have to be vaporizing/smoking by 300* in order to perform this official test. For the oils tested above, certain specific oils did show a significant difference, such as the synthetic Amsoil Z-Rod oil which had a 40* advantage over the conventional Valvoline VR1 Racing Oil.
But, as for overall averages, there was only a 10* difference between synthetic and conventional oils. So, the real world observation here does NOT support common internet oil info claims about synthetic oils having an unbelievably high temperature capability compared to conventional oil.
Don’t believe everything you read on the internet about motor oil. Because there is a lot of misinformation floating around, that has often been repeated over and over. Most sources never ever do any independent testing at all, they just repeat what others have already written. And it doesn’t matter how many times, different sources repeat the same wrong information, it will never magically become true.
Performing real world “wear testing” is only way to determine the true story about which oils actually do provide the best wear protection. And this is precisely why I decided to perform my own testing. That way I could see for myself what is real and what is not.
The above info also makes a good case for running an effective oil cooler setup, if one is needed to keep the oil safely below the threshold of thermal breakdown. But you may also need an oil cooler thermostat as part of that type of setup as well, so that the oil doesn’t end up too cool. You should keep oil temps above 212*F to keep the normal engine condensation quickly boiled off, rather than just slowly evaporated off. You don’t want to allow slowly evaporating water to have the chance to mix in with the oil and dilute it. Oil can only be thinned out by becoming diluted with coolant/water or fuel. And oil can only get thicker by getting overheated and vaporizing its lighter components. So, an ideal temperature range for most motor oils in general, would be between 220*F and 250*F. You get the idea, not too cold, not too hot, just right.
I did not test the cold flow capability of synthetic oils here. So, that claim’s validity remains to be seen. But I did perform one last test here, and that was testing at 325*F, to see what wear protection capability still exists during extreme heating conditions. I selected the highest ranked low zinc oil, 5W30 Pennzoil Ultra, API SM and the highest ranked high zinc oil, 10W30 Lucas Racing Only. Even though they were both vaporizing/smoking a lot at this temperature, here are the results at 325*F:
98,329 psi “load carrying capacity” (essentially no change from its 275* value)
97,561 psi “load carrying capacity” (essentially no change from its 275* value)
As you can see, their load carrying capacity leveled off and stayed approximately the same between 275* and 325*. So, it is comforting to know that you don’t run into dangerously low wear protection if and when you end up with overheated oil at some point. But of course the oil will have already run into thermal breakdown and should be changed as soon as possible.
At the end of the day, there are many outstanding motor oils available. And now you have even more oil performance data to consider. So, making an educated choice to suit your needs should not be too difficult.
Old Mar 8, 2014 | 07:07 PM
LSOHOLIC's Avatar
LSOHOLIC
Racing Oil lab tests - and others
Post by 540 RAT » Wed Sep 28, 2011 6:44 pm
All samples were taken from brand new, thoroughly shaken bottles of oil. And all tests were performed at ALS Tribology, formerly Staveley Labs, in Sparks, Nevada. The oil samples are put into a Spectrometer which generates the results. This prevents the possibility of a technician introducing human error.
Brief overview/comparison of High Performance and Racing Oil:
Lucas 10W30 Racing Only
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2943 ppm
Total anti-wear = 7895 ppm***
Redline 30 wt Race Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2059 ppm
Total anti-wear = 5494 ppm**
Joe Gibbs 10W30 XP3 Racing Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 620 ppm
Total anti-wear = 2670 ppm
Joe Gibbs 10W30 HR-4 Hot Rod Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 3134 ppm
Total anti-wear = 2408 ppm
Royal Purple 5W30 XPR (Extreme Performance Racing)
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 3050 ppm
Total anti-wear = 2963 ppm, plus their proprietary “Synerlec” extreme pressure additive that does not show up in basic lab tests
Note: This particular RP XPR oil info has been posted previously, but it is included here for comparison purposes.
Royal Purple 10W30 HPS (High Performance Street)
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 3676 ppm
Total anti-wear = 3310 ppm, plus their proprietary “Synerlec” extreme pressure additive that does not show up in basic lab tests
Note: This particular RP HPS oil info has been posted previously, but it is included here for comparison purposes.
Valvoline NSL (Not Street Legal) 10W30 conventional Racing Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 1618 ppm
Total anti-wear = 3971 ppm
Valvoline VR1 10W30 Racing Oil (Silver Bottle)
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2787 ppm
Total anti-wear = 3019 ppm
Valvoline VR1 10W30 "SYNTHETIC" Racing Oil API SL (Black Bottle)
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2683 ppm
Total anti-wear = 2454 ppm
Brad Penn 10W30 Penn-Grade 1 High Performance Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 3173 ppm
Total anti-wear = 3211 ppm
Brad Penn 0W30 Penn-Grade 1 High Performance Oil
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2939 ppm
Total anti-wear = 3058 ppm
Brief overview/comparison of Mainstream Oil:
Mobil 1 5W30 API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 1489 ppm
Total anti-wear = 1755 ppm
Mobil 1 5W30 Extended Performance - 15,000 miles API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 1697 ppm
Total anti-wear = 1813 ppm
Quaker State 5W30 Ultimate Durability API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2845 ppm
Total anti-wear = 1870 ppm
Valvoline 5W30 SYNPower API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2628 ppm
Total anti-wear = 1730 ppm
Castrol 5W30 Edge w/ Titanium API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 1810 ppm
Total anti-wear = 1835 ppm
Pennzoil 5W30 Ultra API SM
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 3387 ppm
Total anti-wear = 1684 ppm
Royal Purple 5W30 API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2834 ppm
Total anti-wear = 1759 ppm, plus their proprietary Synerlec extreme pressure additive that does not show up in basic lab tests
Royal Purple 5W20 API SN
Total detergent/dispersant (anti-deposit buildup/anti-sludge) = 2875 ppm
Total anti-wear = 1856 ppm, plus their proprietary Synerlec extreme pressure additive that does not show up in basic lab tests
Detailed info of High Performance and Racing Oil:
Lucas 10W30 Racing Only (lab tested 2011)
Silicon = 18 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Boron = <5 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 1 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2929 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 9 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 2642 ppm (anti-wear)
Phos = 3489 ppm (anti-wear)
Moly = 1764 ppm (anti-wear)
Potassium = <5 ppm (anti-freeze inhibitor)
Sodium = 9 ppm (anti-freeze inhibitor)
Tin = 23 ppm (from bearings, bronze parts and piston coatings, but this is brand new oil……..)
TBN = 9.0 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 11.5 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
***NOTE: The zinc and phosphorus anti-wear levels of all oil in this list, are elemental values, which are NOT the same as ZDDP values. Earlier oil industry testing found that above .14% or 1,400 ppm, ZDDP INCREASED long term wear, even though break-in wear was reduced. And it was also found that .20% or 2,000 ppm ZDDP started attacking the grain boundaries in the iron, resulting in camshaft spalling.
But the correlation between elemental values and ZDDP values varies by motor oil manufacturer, and they do NOT publish their ZDDP values. That makes it difficult to impossible for the consumer to know how elemental and ZDDP values actually compare for any particular oil. However, these elemental values are so extremely high here, that this oil really is only suited for short life dedicated racing engines, as the name implies. Using zinc/phos levels this high in other engines could be cause for concern, since excessively high levels, used for more than just break-in, can “cause” engine damage rather than “prevent” it.
This by Brad Penn:
There is such a thing as too much ZDDP.
ZDDP is surface aggressive, and too much can be a detriment.
ZDDP fights for the surface, blocking other additive performance.
Acids generated due to excessive ZDDP contact will “tie-up” detergents thus encouraging corrosive wear.
ZDDP effectiveness plateaus, more does NOT translate into more protection. Only so much is utilized.
We don’t need to saturate our oil with ZDDP.
Redline 30wt Race Oil (lab tested 2011)
Silicon = 23 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Boron = 70 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 4 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 1982 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 3 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 2207 ppm (anti-wear)
Phos = 2052 ppm (anti-wear)
Moly = 1235 ppm (anti-wear)
Sodium = 20 ppm (anti-freeze inhibitor)
Tin = 18 ppm (from bearings, bronze parts and piston coatings, but this is brand new oil…….)
TBN = 5.0* (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 9.9 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
But the correlation between elemental values and ZDDP values varies by motor oil manufacturer, and they do NOT publish their ZDDP values. That makes it difficult to impossible for the consumer to know how elemental and ZDDP values actually compare for any particular oil. However, these elemental values are high enough here, that this oil really is only suited for short life dedicated racing engines, as the name implies. Using zinc/phos levels this high in other engines could be cause for concern, since excessively high levels, used for more than just break-in, can “cause” engine damage rather than “prevent” it.
This by Brad Penn:
*NOTE: The low TBN value in this Redline oil is also consistent with short term use only.
Joe Gibbs 10W30 XP3 Racing Oil (lab tested 2011)
NOTE: Some of the numbers here were so unusual and unexpected, that I had the lab re-test the oil sample on another day, after other oil tests showed normal results, just to ensure that the original test was valid. And the re –test came back with the exact same numbers. So, the numbers here, are what they are. But we know this line of oil works incredibly well. Because it was developed for, and is used by, winning Sprint Cup NASCAR teams.
Silicon = 4 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Boron = 259 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 356 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 4 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 743 ppm (anti-wear)
Phos = 802 ppm (anti-wear)
Moly = 1125 ppm (anti-wear)
Potassium = 5 ppm (anti-freeze inhibitor)
Sodium = 5 ppm (anti-freeze inhibitor)
TBN = 1.8 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 12.2 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
The detergent and TBN levels are so very low here, that this oil should most likely be changed after every outing, before those components are totally exhausted.
This oil line is one of the leading oils used in NASCAR Sprint Cup endurance engines, yet it has very low levels of zinc/phos, about the same as modern API SN oils. So, this is one example of a textbook case showing that you cannot really depend on elemental zinc/phos numbers alone, to predict how well an oil can protect against wear in high HP, high RPM engines. If you looked at the zinc/phos levels alone, like so many folks do, you’d think this oil should only be used in granny’s late model grocery getter.
This is something that the Royal Purple folks have said all along as well. Because their proprietary “Synerlec” additive is their primary extreme pressure additive, and their zinc/phos levels are only icing on the cake and do not need to be as high as it does with other oils.
The only way to really know how oils compare to each other with regard to preventing metal to metal contact, is to perform lab testing (quickest and most controlled method, particularly when testing a large number of oils) or real world on the road or on the track testing (time consuming, not well controlled, and perhaps impractical if a lot of oils are involved). This way you can test the whole additive package along with its base oil, to see how the overall product actually works. Simply looking at an oil lab test printout, is not enough information to always give you the right answer.
It’s the same thing with a new engine. You don’t just look at its build sheet to really see how well it will perform. You test it on the dyno and/or on the track (or road), to see the real deal.
So, with all that in mind, I’ve ordered an oil wear tester. And in the coming months, I’ll be performing impartial testing of all the oils on this list, and maybe a few others, to see how they rank against each other. I don’t really care which one wins or how they rank. I just want to “KNOW” which one wins and how they rank, so that I can make a better informed decision as to which oil I want to run in my own motors. I have no problem switching brands if the test results show the need to do so. Once I put all that data together, I’ll post the results for anyone interested in seeing it.
Joe Gibbs 10W30 HR-4 Hot Rod Oil (lab tested 2011)
Boron = 6 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 164 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2964 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 0 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1247 ppm (anti-wear)
Phos = 1137 ppm (anti-wear)
Moly = 24 ppm (anti-wear)
Sodium = 2 ppm (anti-freeze inhibitor)
TBN = 9.4 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 11.6 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Royal Purple 5W30 XPR (Extreme Performance Racing) (lab tested 2008)
Boron = 1 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 10 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 3039 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1421 ppm (anti-wear)
Phos = 1338 ppm (anti-wear)
Moly = 204 ppm (anti-wear)
Total anti-wear = 2963 ppm, plus their proprietary Synerlec extreme pressure additive that does not show up on basic lab tests
Potassium = 0 ppm (anti-freeze inhibitor)
Sodium = 0 ppm (anti-freeze inhibitor)
TBN = 10.9 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Note: This RP XPR oil info has been posted previously, but it is included here for comparison purposes.
Royal Purple 10W30 HPS (High Performance Street) (lab tested 2011)
Silicon = 7 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 46 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 3626 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = <1 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1774 ppm (anti-wear)
Phos = 1347 ppm (anti-wear)
Moly = 189 ppm (anti-wear)
Total anti-wear = 3310 ppm, plus their proprietary Synerlec extreme pressure additive that does not show up in basic lab tests
Potassium = 11 ppm (anti-freeze inhibitor)
TBN = 10.2 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 11.3 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Note: This RP HPS oil info has been posted previously, but it is included here for comparison purposes.
Valvoline NSL (Not Street Legal) 10W30 conventional Racing Oil (lab tested 2011)
Silicon = 6 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 5 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 1607 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 2 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1669 ppm (anti-wear)
Phos = 1518 ppm (anti-wear)
Moly = 784 ppm (anti-wear)
Potassium = 7 ppm (anti-freeze inhibitor)
Sodium = 190 ppm (anti-freeze inhibitor)
Tin = 13 ppm (from bearings, bronze parts and piston coatings, but this is brand new oil……..)
TBN = 4.4**** (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 9.8 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
****NOTE: The very low TBN value in this NSL oil would require increased oil change frequency, to avoid acid build-up. And Valvoline has said that their NSL oils should be changed at least every 500 miles.
Valvoline VR1 10W30 Racing Oil (Silver Bottle, lab tested 2011)
This one does NOT have the API symbol, but its text says it exceeds API SM
Silicon = 10 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 73 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2707 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1472 ppm (anti-wear)
Phos = 1544 ppm (anti-wear)
Moly = 3 ppm (anti-wear)
Potassium = 6 ppm (anti-freeze inhibitor)
Sodium = 380 ppm (anti-freeze inhibitor)
TBN = 7.6 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 11.0 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Valvoline VR1 10W30 “SYNTHETIC” Racing Oil API SL (Black Bottle, lab tested 2011)
Silicon = 8 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 15 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2664 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1180 ppm (anti-wear)
Phos = 1112 ppm (anti-wear)
Moly = 162 ppm (anti-wear)
Sodium = 195 ppm (anti-freeze inhibitor)
TBN = 7.4 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 10.4 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Brad Penn 10W30 Penn Grade 1 High Performance Oil ( lab tested 2011)
This oil is from Bradford, Pennsylvania, thus the name Brad Penn.
Silicon = 9 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 646 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2518 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 5 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1557 ppm (anti-wear)
Phos = 1651 ppm (anti-wear)
Sodium = 450 ppm (anti-freeze inhibitor)
TBN = 8.7 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 10.3 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Brad Penn 0W30 Penn Grade 1 High Performance Oil ( lab tested 2011)
Magnesium = 13 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2922 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 1621 ppm (anti-wear)
Phos = 1437 ppm (anti-wear)
Moly = 0 ppm (anti-wear)
Viscosity (cSt at 100*C) = 10.5 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
The High Performance and Racing Oils on this list that have acceptable levels of all that is needed, and are suitable for High HP Street Hotrods and Street/Strip cars, as well as many dedicated race cars (including flat tappets and bronze dist gears) are:
Joe Gibbs Hot Rod Oil
Valvoline VR1 Racing Oil (Silver Bottle)
Valvoline VR1 “SYNTHETIC” Racing Oil API SL (Black Bottle)
Brad Penn, Penn Grade 1, High Performance Oil
NOTE: Joe Gibbs oil can be ordered directly from JoeGibbsDriven.com or Amazon.com
These Royal Purple oils can be ordered from Summit or Jegs
These Valvoline oils can be found with limits at some regular Auto Parts Stores, or can be ordered from Jegs, but NOT Summit, as I recall
The Brad Penn oil can be ordered from Amazon.com or from Summit as Howards Cam’s Brad Penn oil
And there are a variety of local shops, etc that carry some of these oils as well
Detailed info of Mainstream Oil:
Mobil 1 5W30 API SN (lab tested 2011)
Boron = 87 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 603 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 799 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 801 ppm (anti-wear)
Phos = 842 ppm (anti-wear)
Moly = 112 ppm (anti-wear)
Sodium = 6 ppm (anti-freeze inhibitor)
TBN = 7.5 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Mobil 1 5W30 Extended Performance (15,000 miles) API SN (lab tested 2011)
Silicon = 5 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Boron = 89 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 666 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 942 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 890 ppm (anti-wear)
Phos = 819 ppm (anti-wear)
Moly = 104 ppm (anti-wear)
TBN = 7.9 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
The detergent, anti-wear and TBN components of this Extended Performance oil are either about average or below average for typical API SN oils (even though some of the components are a little higher than in its standard Mobil 1 counterpart). TBN eventually becomes depleted as miles accumulate on oil in service. That’s “one” of the primary reasons for changing oil in the first place, to replenish the exhausted additive package. And it’s not unusual to see TBN values drop by as much as 60% from the original value, in only 5,000 miles. And with this oil starting out with a fairly low TBN value to begin with, it would seem very unlikely it could ever go a whopping 15,000 miles without having the TBN totally depleted well before reaching that 15,000 mile mark. So, this extended mileage claim appears to be only an unsupported marketing gimmick.
But, for those interested in long drain intervals, I’d suggest sending in a sample of this oil and having it lab tested at about the half way mark of 7,500 miles to see how much, if any, TBN remains. But, of course motor oil is typically already dark, dirty, contaminated and in need of changing by 5,000 miles anyway.
Quaker State 5W30 Ultimate Durability API SN (lab tested 2011)
Silicon = 3 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Calcium = 2831 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 877 ppm (anti-wear)
Phos = 921 ppm (anti-wear)
Moly = 72 ppm (anti-wear)
NOTE: This bottle’s plastic was so paper thin and flimsy, that just gripping the bottle with the cap off, squeezed oil up, out and all over the place. So, use extra care with this one.
Valvoline 5W30 SYNPower API SN ( lab tested 2011)
Magnesium = 19 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2605 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 969 ppm (anti-wear)
Phos = 761 ppm (anti-wear)
Sodium = 205 ppm (anti-freeze inhibitor)
TBN = 7.1 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Castrol 5W30 Edge w/ Titanium API SN (lab tested 2011)
Boron = 55 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Magnesium = 1176 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 577 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 818 ppm (anti-wear)
Phos = 883 ppm (anti-wear)
Moly = 90 ppm (anti-wear)
Titanium = 44 ppm (anti-wear)
TBN = 10.1 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 10.6 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Pennzoil 5W30 Ultra API SM (lab tested 2011)
Boron = 363 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 3011 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 806 ppm (anti-wear)
Phos = 812 ppm (anti-wear)
Moly = 66 ppm (anti-wear)
TBN = 10.3 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Viscosity (cSt at 100*C) = 10.8 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
Royal Purple 5W30 API SN ( lab tested 2011)
Magnesium = 8 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2822 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 942 ppm (anti-wear)
Phos = 817 ppm (anti-wear)
Sodium = 424 ppm (anti-freeze inhibitor)
TBN = 7.7 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9. And in use, this becomes depleted over time as mileage accumulates)
Royal Purple 5W20 API SN (lab tested 2011)
Silicon = 2 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Magnesium = 9 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 2862 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 964 ppm (anti-wear)
Phos = 892 ppm (anti-wear)
Sodium = 267 ppm (anti-freeze inhibitor)
Viscosity (cSt at 100*C) = 8.7 (cSt range for SAE 20 is 5.6 to 9.2) And cSt (centistokes) in general terms, represents an oil’s thickness.
540 RAT
U.S. Patent Holder
Member: SAE (Society of Automotive Engineers)
Old Mar 9, 2014 | 01:47 AM
IRON MAIDEN's Avatar
IRON MAIDEN
I tried RP when I only had about 30K on my C5. My motor was louder for sure. Noticed it the first time I fired it until I changed back to Mobil 1 on my next change. I still looked good when I drained it, as my Mobil 1 always does. But my valvetrain runs quieter on the Mobil 1 so I'm sticking with it.
