What does it take to lower a C5?
Old Jul 15, 2002 | 10:31 PM
ChevyChad's Avatar
ChevyChad
Default What does it take to lower a C5?
I am a new Vette owner and I was wondering what all do I need to do to lower my 97 about an inch? Nothing too dramatic, just want it a little lower to take up some of that fender gap. I have heard that you can adjust the stock suspension to get it lowered up to an inch. If so, how? I am not sure which suspension package I have either. Does that matter? If so, how can I find out? TIA everyone.
Old Jul 15, 2002 | 11:23 PM
fins4284's Avatar
fins4284
Default Re: What does it take to lower a C5? (ChevyChadZ28)
check the Tech Tips section on top of this page...
Old Jul 15, 2002 | 11:42 PM
Patman36's Avatar
Patman36
Chad,
Sorry, should have sent those instructions to you...
https://www.corvetteforum.com/techti...D=27&TopicID=1
If you just want an inch, skip the part on cutting the bushings. If you turn the bolts as they say you should get roughly an inch drop. I am thinking about doing this soon..... :)
Patrick :cheers:
Old Jul 16, 2002 | 12:14 AM
Chris@SD's Avatar
Chris@SD
About an hour of work on a good day. :yesnod: Seriously, most of the cars that we drop, we do not cut the bushings. Very rarely to we have someone come back to go lower.
Good luck,
Old Jul 16, 2002 | 08:22 PM
ChevyChad's Avatar
ChevyChad
Default Re: What does it take to lower a C5? (Chris@SpeedDemon)
Thanks!! :cheers:
Old Jul 16, 2002 | 08:31 PM
johnny v's Avatar
johnny v
Out of curiosity did anyone check to see if lowering threw off the weight distribution of the car? Is there an easy way to do this other than scales or is the effect minimal that there should be no concern?
Old Jul 16, 2002 | 08:35 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Re: What does it take to lower a C5? (johnny v)
I just recently went to the track the first time after lowering the car and I lost .6 in the ¼. I am going to raise it back up this week. Looks AWESOME though, but I would rather not have $5k+ in a motor that only runs 13.2@108.99.
Also, I need to add I lowered it 2 3/4"
Just my .02, I know others have had better reaults.
[Modified by C5SilverBullet, 6:36 PM 7/16/2002]
To What does it take to lower a C5?
