Dropping engine, couple questions.
Old Mar 7, 2014 | 11:09 PM
sick_tight's Avatar
sick_tight
Default Dropping engine, couple questions.
So I'm ***** deep in dropping this driveline in my garage. Im almost ready to drop the motor but i still need to remove a couple more sensors.
anyone have a good step by step how to? Ive been using http://www.pcmforless.com/index.php?...ches&Itemid=56
the "cajundude" one is no longer available and some of the others ive found linked through out the forums. I just found the one ive been using a little vague at times.
my biggest problem is do i unbolt the ABS module from its bracket and let it hang or do i disconnect it from the master cylinder and drop it with the front cradle. The link i used said only unbolt the brakes from the caliper and then the GMHTP article said to drop all the brake lines
I dont want to drop all the brake lines. i am dropping the trans/torque tube/rear diff as well. is it recommended to remove everything at once or trans/diff/TqT then engine.
thanks for the replies and insight.
