Heads & Cam Decision Help
Old Mar 11, 2014 | 06:13 PM
XTRVette's Avatar
XTRVette
Default Heads & Cam Decision Help
Hello everyone,
I just hit 70K and I was wondering if it was wise to do a head a cam job with out doing the bottom end. Other choice is I buy an LS2 block and build that little by little and continue using the car. The heads that I have are casting #799 which I want to send to AI and get them flowing right.
Thank you in advance,
Mike
Old Mar 11, 2014 | 09:35 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
If you have good compression, good oil pressure, no smoke and it runs quiet, use your ls1. If not build the ls2. A lot of people have done heads/cam, N02 and blowers using engines with over 100,000 miles without problems.
Pulling the engine is a lot more work than heads/cam. You can still prep the ls2 so you have a backup.
Old Mar 12, 2014 | 09:39 PM
XTRVette's Avatar
XTRVette
Originally Posted by martysauto
If you have good compression, good oil pressure, no smoke and it runs quiet, use your ls1. If not build the ls2. A lot of people have done heads/cam, N02 and blowers using engines with over 100,000 miles without problems. Pulling the engine is a lot more work than heads/cam. You can still prep the ls2 so you have a backup.
Thank you, I will send the heads in for work and use my current eng. thank god I haven't have any issues on the eng just the harmonic balancer but I fixed that last week. I appreciated your help!
God bless
Mike
Old Mar 13, 2014 | 09:08 AM
chaase's Avatar
chaase
St. Jude Donor '12
The LS1 is a very stout engine. There are members with over 300k miles on them. As long as you maintain it properly, it will run a long time. 70k miles is just getting warmed up.
Old Mar 13, 2014 | 10:25 AM
Bill McCassey's Avatar
Bill McCassey
I did all of my mods between 158000 and 165000 miles on a stock bottom end and now have ~11.5:1 compression and still runs great.
Old Mar 13, 2014 | 04:15 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
Just make sure you have a cam that can match those heads and fit! We can help you out with that.
let us know if we can help!
coloradoSPEED
To Heads & Cam Decision Help
