I did a search and checked the suggested #2 and BCM labeled fuses in the passenger footwell. They're all good.
I was changing the lamp when the clip holding the end came loose and touched the other terminal. Heard a pop and now my foot well lamps no longer work.
Any ideas?
Thanks.
Found out the mirror lamps can be switched on manually at the mirror but not with the dash **** or door opening.
Also the door switches light up along with the dash and radio/heat buttons just not the mirror or foot wells and hatch when the door is opened.
This was all just working before my led mod party.
I really hope I didn't fry some module.
Thanks for the info. I'm parked in a garage and it was turning on when I did the other lights.
If my only unfixable screw up is no foot well lights I'll take it.
I have the sensor accessed but don't know what kind of electrical test I can do with my fluke to see if it needs replaced or if there is a problem further down the line.
I swapped another relay and unplugged the battery with no change.
Hope its a cheap sensor.
