6.0L truck engine question
Re: 6.0L truck engine question (kewlbrz)
Lets play with the numbers, but it seems like a budget superstroker long block could be done for parts at something like:
6.0 liter .060 over iron block - 600.00
Australian Nodular Iron Crank 4.0 stroke - 895.00
Rods/pistons - 1500.00
LQ9 Heads with stage I porting and 2.02/1.60 - 1500.00
Cam - 400
Misc parts (gaskets etc) - 1000.00
4.06x4.00 = 415ci
That should be good for 475+ RWHP depending on cam selection at under 6000.00
Add a 1DSC blower for 5000.00 and your around the $12K mark making 650+ RWHP
Cam - 400
4.06x4.00 = 415ci
yes...the reason i was asking was because i know when the silverado ss comes out. i was wondering what the engine potential was. if you already have the whole engine, im sure 6000 could possibly get it stroked with some nice internals and a nice heads and cam package as well
then we can all wave goodbye to the lightnings. :seeya
a lot of people think that chevy is behind in the horsepower wars but i think that chevy engines are great. who cares if the silverado ss is 345hp. it has the potential to get much better. and all with a readily available aftermarket. correct me if im wrong.
Re: 6.0L truck engine question (C5Noir)
Has anyone put a truck intake manifold in a C5? I read on LS1tech.com that it flows much better than even the 2001+ intake manifold, but is 4" taller and doesn't fit under a stock hood. Maybe an aftermarket hood for the Magnusson/LPE supercharger would work
Re: 6.0L truck engine question (Miles in Michigan)
kewlbrz,
You’ll need a complete fuel system, a lot of tuning with access to dyno with a wideband, most likely custom (bigger size) intercoolers not to mention a belt drive system to able to handle it (I’m not aware of one in existence so far :nonod: )
You do the math :eek: :eek:
BTW: most of the above is true for pretty much any motor (no necessarily a stroker) except maybe bone stock one.
Miles in Michigan
I’m curious about that too.
[Modified by EuG, 5:39 PM 7/17/2002]
Could you elaborate whats involved in putting a ATI on a stroker as opposed to a non-stroker?
Miles in Michigan
Cruise-In II Veteran
Cruise-In III Veteran
Re: 6.0L truck engine question (EuG)
Thanks EuG. I agree that would need to be done for a blower. But the NA parts pricing seems pretty close.
Miles, here is some info I have regarding the manifolds:
This is an older test, but the relationships are interesting.
<BLOCKQUOTE>code:<HR><PRE>Without Manifolds - Headflow Only:
Cylinder Head Intake Manifold .200" .300" .350" .400" .450" .500" .550" .600"
Stock LS1 N/A 137 187 207 223 228 237 242 243
Stock LS6 N/A 156 204 225 243 257 268 275 278
Ported LS1* N/A 144 200 225 245 261 272 283 292
Ported LS1** N/A 164 217 234 253 270 284 296 305
Ported LS6 N/A 159 212 236 255 272 300 307 314
With Manifolds:
Stock LS1 LS1 136 184 200 214 222 227 229 235
Stock LS1 LS6 136 186 206 223 227 236 241 242
Stock LS6 LS1 156 199 212 224 232 238 243 247
Stock LS6 LS6 154 204 220 235 247 257 263 265
Ported LS1** LS1 141 185 205 222 232 241 251 258
Ported LS1** Truck 163 206 224 237 249 262 265 270
Ported LS1** LS6 166 211 229 244 257 269 277 283
Ported LS6 LS1 156 199 217 230 242 253 263 268
Ported LS6 LS6 153 202 222 241 257 270 280 289</PRE>[/QUOTE]
"* Original Stage II heads from New Dog, Old Tricks; GMHTP May/July 2000
** Latest revision at time of publication."
With Manifolds:
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Re: 6.0L truck engine question (Phil97SVT)
[QUOTE]Well it has been a while since I was in college but here goes my best math skills:
6 liter truck block or 5.7 aluminum: $500
Stroker Crank: $1000-2200
Connecting Rods: $700
Pistons $750
Machine work: $500
Bearings/Rings $350
Studs and bolts: $400
Cost on parts less assembly $4200-5400
I can build the motor just need parts and my machine shop guy to bore,line hone, and clearance the block. :crazy: 427 here we come. :smash: :smash: :smash: :smash: :smash: :smash:
:eek: :cheers: :cool: :yesnod: :) :chevy :D
Its just a matter of time and i'm in, but i believe it would be a 415 cube and not 427, right?
Nitro
[Modified by Nitrovette, 4:21 PM 7/17/2002]
Pistons $750
Machine work: $500
Bearings/Rings $350
Nitro
You can bore the block to a .060 over, but most people only go to .030 (like myself :D ) for a nitrous of FI setup.
You won't get a forged crank for under $1900 yet either :( been trying to do that for some time :D
COME racing from down under has some castings and billet coming "soon." :rolleyes: Keep an eye on them. Hopefully press the prices down a lil. This is all on ls1tech.com
I have a set of fully ported and polished stage IV heads coming from SpeedDemon I will let you guys know about. They should kick some serious ****. :D
GM is starting to sell the 6.0 blocks now from what Pace tells me.
When COME racing comes out with a cast 4.00" crank for $800 or so you will have the ability to have a real nice budget stroker on your hands. Offset grinding could get you a lil more.
the weight difference btw the alum and 6.0 blocks are about 70lbs, really not that big of a deal. With the 6.0 block you won't have to worry about a sleeve dropping like some "other" hmmm anybody follow that one on ls1tech :D ??
Re: 6.0L truck engine question (intel55)
Yeah, GM sells just the blocks anyway. I can get them for $695+ shipping from TeamChevrolet ;).
I think a 409 CID 6.0L setup would be killer ;)
no way that truck intake would fit. My sheetmetal intake is less than 1/2 that increase and the hood JUST closes. Also the TB would be higher up. That truck intake is fairly large :D
hm wonder how much long those runners are....
:cheers:
:cheers:
Re: 6.0L truck engine question (Nitrovette)
[QUOTE]come. :smash: :smash: :smash: :smash: :smash: :smash:
Nitro
[QUOTE]
right Nitro :D 4.06 bore and 4.00 stroke would be a 415.
The 427 has a 4.06 bore and 4.125" carnk :D
gets kind of nutty....
how about this Nitro a 4.15 bore (alum. resleeve, MTI) and 4.25 crank!!! 460v... Joe Prince is doing resleeving also. I think with a 4.10 sleeve. However, I do not think he is using the cheap TRUCK sleeves.
Where do you think my soon to be extra alum. block is going :D :D :D ???
One iron 408 stroker and an "extra" super stroker :D :D
hey where did my money go??? :crazy: :crazy:
Jim call up Chris at SpeedDemon and run through with him what you want. If you need any help of course let me know :D :cheers:
Nitro
[QUOTE]
Or call SpeedDemon, even cheaper!! :seeya
#33
Are those blocks brand new?
http://www.paceparts.com/product.asp?0=243&1=245&3=994
part # 12551366
[Modified by intel55, 4:47 PM 7/17/2002]
#35
St. Jude Donor '06
Intel/Jim:
Thanks for the info buddy! :smash: These budget strokers are looking very interesting and exciting to me! :D
Can't wait till i free up some $ to move full steam ahead on this. My 4000yank prothruster and 3.73s go in today, Vararam in a couple of weeks, and the only missing link is my stroker engine making 600 crank ponies.:D Won't be long, but will never come soon enough!:D
Nitro
Nitro
