Car remains unstartable.
Old Jul 16, 2002 | 04:40 PM
Fast one's Avatar
Fast one
Default Car remains unstartable.
But at least I got to visit it. The dealer has no idea what is wrong and GM said to check the head ground which turned out to be OK. 50 error codes come up when starting is tried which means there is a bad ground or so I was told. I'll post the fix for this someday when it's found.
Old Jul 16, 2002 | 04:58 PM
pburant's Avatar
pburant
Default Re: Car remains unstartable. (Fast one)
That sux!! I spend so much time with my car that if I were in your position, I would have brought my cleaning stuff with me to the dealer and would have been detailing the interior until they forced me to leave!! :jester
Old Jul 16, 2002 | 05:27 PM
Fahtrim's Avatar
Fahtrim
Default Re: Car remains unstartable. (pburant)
Sorry to hear that for you!
Old Jul 22, 2002 | 02:11 PM
Fast one's Avatar
Fast one
Default Re: Car remains unstartable. (Speide)
The problem was traced to aftermarket wiring meaning my wiring on the pigtail feeds. A wire was shorted which blew out the 20 Amp cigar fuse and took the Body Control Module with it. The shop manual states that the BCM is robust and is protected against shorted loads or wires across battery potential. Either the BCM was destroyed by the short on the cigar circuit or it needed to be reprogrammed after the short was removed. The dealer replaced the BCM , reprogrammed it and removed the aftermarket wiring before the car could be started. I will add my own fuse block fed from the battery to avoid this situation in the future.
Old Jul 22, 2002 | 02:30 PM
edv2122's Avatar
edv2122
Glad to hear you back up and running. I get depressed if I can't drive my car for a day. :jester
To Car remains unstartable.
