Column Lock Bypass Install
Old Jul 16, 2002 | 05:04 PM
Phil97SVT's Avatar
Phil97SVT
Default Column Lock Bypass Install
I just got around to installing the CLB and it was very easy and really only took 20 minutes. Here was the installation:
Remove the Temp sensor cover and hatch release
Unbolt 4 torx screws (2 on top and 2 on bottom)
Remove knee panel and set on center console infront of shifter
Unhook harness for CL
Use harness to unlock column lock
Install CLB
reinstall knee panel
I hope this helps!
Phillip :cheers:
Old Jul 16, 2002 | 05:25 PM
Fahtrim's Avatar
Fahtrim
Default Re: Column Lock Bypass Install (Phil97SVT)
Yepper that 's about it, I did this last year........
Old Jul 16, 2002 | 09:00 PM
TOPGUN9's Avatar
TOPGUN9
Default Re: Column Lock Bypass Install (Speide)
I installed mine in 1999 when I bought my coupe. Too many scare stories of getting stranded and having to be flat-bedded.
To Column Lock Bypass Install
