Yes, I used a floor jack to relieve the pressure. The first time I didn't know to relieve the pressure. After reading about a jack under the spring I decided to try again. Thinking that two days of PB Blaster the bolts would move freely. No movement at all.
At vette shows my car higher than most. 28" at the top of the fender on both sides. 6" from the ground to the jacking point on the frame.
I used a piece of wood under the spring so I wouldn't crack the spring. I also removed the bottom bolts on the shock which allows you to get to the top of the bolt easier. I went slow with the jacking ,watching and feeling the bolt for movement. Hope this helps.
I had the lower control arm off. My car was a NJ winter driver and I wanted to clean everything, so I simply took it all apart.
You could just remove the lower shock bolts and disconnect the sway bar to get at it better.
I pretty much cheated.......
Funny thing was, after I got it out and replaced, and before I put it all back together, I bought a set of Z06 springs....and those bolts were stuck too!
I see you are in Roseburg. A bit too far to drive down and help.....
Take the spring out, it'll take about 15 minutes and make it so much easier to work on compared to fighting with it around the suspension. You do need the car about 2' off the ground on stands to do it. Mark the lower A-arm camber bolts so you can get the washers back in the same spot. Then, jack the spring just like you are doing and remove the lower a-arm bolts and pull the a-arm loose from the cradle. Lower the jack while you pull out the suspension to get the end of the spring below the arm. Then, move the jack to the end of the spring and jack it up once more before removing the 2 spring retaining plates. Then, lower the arm and you have the spring out. So easy you don't even need to remove the wheel on the one side. There is a write-up floating around where you have to almost rip the whole suspension apart on both sides to get the spring out which is ridiculous.
Once you have the spring out, clean the threaded end that sticks out above the spring. Then, heat the bolt a bit and you can easily get a hold of the big end with channel locks to turn the bolt right out of the spring. Clean the bolt again and the threaded insert in the spring before applying anti-seize and putting it back together.
Mine were stuck as well. I did what lionelhutz did and removed my spring. However I put the big pad end of the bolt into a vise and used the spring as my leverage handle. Worked great and they broke free pretty easily.
How did you get the car high enough? Do you have the torgue spec the bolts?
I actually took both tires off and had it as high as I could get it on jack stands. Worked well enough and I had room under the car to maneuver around under it. I don't remember the torque specs off hand but did find this pdf that has pretty much everything for the C5. Hope this helps.
