Tie rod ends
Old Mar 23, 2014 | 12:40 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default Tie rod ends
In the process of upgrading the suspension on my 2000 coupe that included Stance coil overs, C6 Z06 sway bars, poly suspension bushings, and new 18x10/19x12 wheels, 275x35 front and 325x30 rear tires, the subject of new tie rod ends came up. The car will be lowered on the coil overs and some have suggested that there may not be enough thread on the stock tie rods ends to accommodate the lowered stance and get a proper alignment. I have looked at replacement ends and can only find the ones from Ecklers that state they have longer studs to accommodate a lowered stance. Has anyone used these ends and have any recommendations, on whether it is required or not, if Ecklers are a good brand or not, or are there any alternative brands. I have seen the Moog as well but it does not state if their studs are longer. Both however are greaseable ends. I would appreciate any information. Thanks.
Old Mar 23, 2014 | 01:14 PM
jac1979's Avatar
jac1979
I've used some ball joints and tie rod ends from Eckler for my C5 Z06 Overall quality was good but can't comment on the ones you are talking about for a lowered stance. Price was much less than local parts stores.
Old Mar 23, 2014 | 05:11 PM
jac1979's Avatar
jac1979
Ok I went back and looked at the p/n I ordered from Eckler. It was 44432 and the description does say that it is longer for lowered ride height. I didn't buy because of this reason. I just saw it on there and it was a good price.
I only bought one as that was all I needed. The Eckler part is 4-3/4" from start of thread to center of ball joint. The factory one is 4" measured to the same points.
In my case the one from Eckler was actually too long because I ran out of threads on the rod. The shop I brought it to for alignment was actually wanting to take the rack off the car and somehow adjust the cener position. I honesty don't think they knew what they were talking about. After I got the car home I took the wheels off and looked to see what they were talking about. They actually did align the car they just couldn't get the steering wheel centered, because of what I am describing here. After looking at it I realized the new tie rod was too long so ended up cutting 3/4" off the new one to make it the same length as the factory one.
Not sure if this would be the same with your suspension set up but hope this helps.
Old Mar 23, 2014 | 06:51 PM
jac1979's Avatar
jac1979
Update: I cut the tie rod from Eckler only to realize the inside depth of the hole was the problem. I went to a local Autozone and they had one for $39. The hole in it was much deeper than the one from Eckler. Now that I have another one to compare it to the one from Autozone is much smoother.
Old Mar 23, 2014 | 11:12 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
I have aligned many lowered vettes and never needed to get different tie rod ends.
Old Mar 24, 2014 | 03:54 AM
mrm13's Avatar
mrm13
Just to add to this….
I just installed the exact same setup the OP is talking about on my 2000 coupe. Stance coil overs, C6Z06 sway bars and links and I have the same size tires on OEM C6Z06 wheels. Stock tie rod ends are doing just fine and my car is sitting considerably lower than before. As a matter of fact I am thinking raising back up a little, because the rubber thingies on the front scrape almost everywhere.
Old Mar 24, 2014 | 05:54 AM
alxltd1's Avatar
alxltd1
Thanks, and good to hear. I will just go with the stock ones and wait to see if it becomes an issue.
Old Mar 24, 2014 | 12:50 PM
lionelhutz's Avatar
lionelhutz
Seriously, just image how badly the car would handle if the toe changed so much that a 3/4" longer rod end was needed to safely set the alignment once the car was lowered.
Old Mar 24, 2014 | 01:57 PM
alxltd1's Avatar
alxltd1
Agreed, but kept hearing that it could be an issue and is why I opened the thread to hear other opinions/experiences.
Old Mar 25, 2014 | 11:00 AM
ArtGle's Avatar
ArtGle
Veteran: Marine Corps
Thanks for the thread guys. Just bought the REAR tie rod ends (standard) from eckler's ...
Both cost less than ONE from the Dealer.
And places like Autozone didn't even know what I was talking about.
Oh, and downloaded their catalog in PDF format.
YAY
To Tie rod ends
